    I am trying to setup a pwm controlled on-off switch
    • Szwalkiewicz
      Szwalkiewicz last edited by
      On RRF 2.05.1
      I am trying to setup a pwm controlled on-off switch for Led's on heater 4
      So I placed a "M307 H4 A-1 C-1 D-1" at the bottom of the config.g
      and if I try to use the pin with a command like "M280 P4 S160 I1"
      It will not work and I get an error message of
      M98 P"0:/macros/LED/LED off"
      Error: M280: Invalid servo index 4 in M280 command
      And i know the switch works because if i put the signal wire for the Pwm switch on heater 3 (My bltouch pwm signal) it works perfect. so i'm missing a step in the process to get this working
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @Szwalkiewicz last edited by
        @szwalkiewicz
        What controller are we talking about?
        You might have a FET behind Heater3, but not behind Heater4. Because heater 4 is only a GPIO pin leading to a sub-controller like DUEX...
          Are you sure you're on RRF 2.05.1?
          Do you have a config-override.g that contains another heater command M307 H4?
          Szwalkiewicz 1 Reply Last reply Reply Quote 0
          • Szwalkiewicz
            Szwalkiewicz @Phaedrux last edited by
            @phaedrux
            Thanks u nailed it 🙂 a config override was auto generated with M307’s for all heater’s. For some reason setting a probe type for a heater overrides the M307 with blank pid’s in config override which is why the bl touch worked and pwm switch did not.....I guess?
