    Toolboard v1.1 Accelerometer Orientation and Setup
    695
    • Frederik
      Frederik @dc42 last edited by
      @dc42 thank you, it worked.
      what could it be that my printer is loosing his PA setting at the start of a print ?
      noticed it since the update to RRF 3.3RC3
      G90                                                          ; send absolute coordinates...
      M83                                                          ; ...but relative extruder moves
      M550 P"vcore"                                                ; set printer name
      M669 K1                                                      ; select CoreXY mode
      G4 S1														 ; wait for Toolboard Synchronisation
      M569 P0.0 S1
      M569 P0.1 S1
      M569 P0.2 S1
      M569 P0.3 S1
      M569 P0.4 S1
      ;M569 P0.5 S1
      M569 P121.0 S1
      M584 X0.1 Y0.0 Z0.2:0.3:0.4 E121.0
      M350 X16 Y16 Z16 E16 I1                                      ; configure microstepping with interpolation
      M92 X160.80 Y160.80 Z811.00 E859.00                          ; set steps per mm
      M566 X500.00 Y500.00 Z25.00 E2500.00                         ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z2300.00 E5000.00                    ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z75.00 E2500.00                        ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1500 E800 I50                             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                                             ; set axis minima
      M208 X410 Y395 Z390 S0                                       ; set axis maxima
      ; Position of Leadscrews
      M671 X1:215:429 Y1:429:1 S50 					;Position of Leadscrews
      M574 X1 S1 P"121.io2.in"                                     ; configure active-high endstop for low end on X via pin 121.io2.in
      M574 Y2 S1 P"io0.in"                                         ; configure active-high endstop for high end on Y via pin io0.in
      M574 Z1 S2                                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                       ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H2.5 F140 T9000 ;R0.5 ; A10 B0                ; set Z probe type to bltouch and the dive height + speeds
      G31 P1000 X-28 Y-22 Z3.68                                    ; set Z probe trigger value, offset and trigger height
      ; Mesh Grid
      M557 X1:382 Y1:368 P5:5 ; define mesh grid (Abstand X:Y in mm - Sx:x / Punkte X:Y - Px:x)
      ; Volumetric Extrusion Filament Diameter (D)
      M200 D1.75:1.75
      ; Print Monitor - Filament (N) and Nozzle diameter (D)
      M404 N1.75 D0.4
      ; Bed Compensation Taper
      M376 H0 													; Height (mm) over which to taper off the bed compensation should be min 20x Times the mean error / 0 or
      ; Extrusion Override Factor to 90 %
      M221 S095 D0:1
      ; Axis Skew Compensation
      ;M556 S100 X0.7 Y-0.2 Z0.6
      ; Ringing Frequenz
      M593 F46.51				;62.24 46.51 55.86 40.5 40 											 ; F-Freuenz P-Type 0_none 1_ZVD 2_ZVDD 3_EI2 4_DAA S-DampingFactor_ default 0.2
      ; Duet Laser Filament Monitor
      M591 D0 P5 C"121.io1.in" R20:185 E5.0 A0 S0 				 ; Extruder0 Tolerance 20 to 150%, 5mm comparison length, diabled
      M308 S0 P"temp0" Y"thermistor" T100000 B4138                 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out7" T0                                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                      ; map heated bed to heater 0
      M143 H0 S200                                                 ; set temperature limit for heater 0 to 160C
      M308 S1 P"121.temp0" Y"pt1000" 	                  ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                                ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
      M141 H1
      M143 H1 S275                                          ; set temperature limit for heater 1 to 500C
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8        ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"out8" T2                                           ; create chamber heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                             ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                                      ; map chamber to heater 2
      M143 H2 S125                                                 ; set temperature limit for heater 2 to 120C
      M308 S3 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8        ; configure sensor 2 as thermistor on pin temp1
      ;M950 H3 C"
      ;M141 H3
      ; PID Parameters Bed for 100°C
      M307 H0 R0.680 C321.3 D2.40 S1.00 V24.1
      ; PID Parameters Nozzle for 225°C
      M307 H1 B0 R2.391 C190.9:158.3 D7.17 S1.00 V22.4
      ; PID Parameters for ChamberHeater 50°C
      M307 H2 R0.211 C426.7 D40.54 S1.00 V24.1
      M950 F0 C"121.out2" Q500                                     ; create fan 0 on pin 121.out2 and set its frequency
      M106 P0 C"Mosquito" S100 H1 T45                              	 ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"121.out1" Q500                                     ; create fan 1 on pin 121.out1 and set its frequency
      M106 P1 C"Bauteil" S0 H-1                                    ; set fan 1 name and value. Thermostatic control is turned off
      ; Air Pump Control on SSR_3
      M950 F2 C"out9" Q500 										 ; create fan 1 on pin 121.out1 and set its frequency
      M106 P2 C"Druckluft" S0 H-1 								 ; set fan 1 name and value. Thermostatic control is turned off
      ;Led Beleuchtung
      ; Zone 1
      M950 F3 C"out2" Q500 										 ; create a output for led zone1 on out3
      M106 P3 C"LED_1" S0.1 									 ; set output default to on
      ; Zone 2
      M950 F4 C"out3" Q500 										 ; create a fan output for led zone2 on out4
      M106 P4 C"Ausgang 3" S0 									 ; set output default to off
      ; Toolboard Buttons
      ;button0 LC1.121
      ;M950 J4 C"121.button0" 									 ; Input 4 uses io4 pin, inverted
      ;M581 P4 S1 C0 T2 R0 										 ; configure button for LED ON
      ; button1 LC1.121
      ;M950 J5 C"121.button1" 									 ; Input 5 uses io5 pin, inverted
      ;M581 P5 S1 C0 T3 R0 										 ; configure push button for LED OFF
      M563 P0 S"Mosquito" D0 H1 F0:1                               ; define tool 0
      G10 P0 X0 Y0 Z0                                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                                 ; set initial tool 0 active and standby temperatures to 0C
      M207 S0.6 F2400 Z0.00										 ; FW Retraction Mosquito (S)-Retraction Dist. (F) Speed , (Z) ZHopHeight
      ; BMG Pressure Advance
      M572 D0 S0.050
      M501                                                         ; load saved parameters from non-volatile memory
      M912 P0 S-15.8 							   	 				 ; MCU Temperature Calibration
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"           ; set voltage thresholds and actions to run on power loss
      T0                                                           ; select first tool
        dc42 administrators @Frederik last edited by
        @frederik what does M572 D0 report immediately before starting the print?
        What does M572 D0 report if you start the print, wait for actual printing to start, and then send M572 D0?
        Frederik 1 Reply Last reply Reply Quote 0
        • Frederik
          Frederik @dc42 last edited by Frederik
          @dc42 when i observed today correct, then it reportet before the print and after a initial power up the correct value of 0.050. At that Time the M572 was in line 43.
          After starting the Print the extruder 0 showed 0.000 and the extruder 2 the correct value of 0.050
          after manual triggering the command wiht 0.050 over the console again, it worked during the print. will test at the evening what happens when i restart a print without restarting the printer.
          in my cura startcode is nothing except 3 lines for priming the extruder , nothing else
          using firmware retraction
          there i noticed that sometimes the retraction speed is at 1mm/s after a printer restart, even if the config setting is 2400mm/min.
          at the moment a 6 hour print is running. after that i could start testing again
          in cura are no Printer settings regarding the motion control like jerk, acceleration or linear advance. only priming and FW retract
          • Nuramori
            Nuramori @Frederik last edited by
            @frederik your value based on the picture should be I06
            • Frederik
              Frederik @Nuramori last edited by Frederik
              @nuramori Thanks , i will try it with this values:
              P121.0 I06 S1000 R12
              Today i had a little bit time to investigate further with the PA Settings Problem.
              After a reboot, the Printer shows the right value of 0.050 after sending M572 D0 over the console.
              When starting a print in Cura 4.9.1 , i send the M572 D0 again and get a Value of 0.000 ???
              Now i switched the PA command back up to Line 61 and will try how it behaves at the next small print.
              config g at the moment:
              M569 P0.0 S1
              M569 P0.1 S1
              M569 P0.2 S1
              M569 P0.3 S1
              M569 P0.4 S1
              M569 P121.0 S1
              M566 X500.00 Y500.00 Z25.00 E1500.00                         ; set maximum instantaneous speed changes (mm/min)
              ; Mesh Grid
              M557 X1:382 Y1:368 P12:12 									; define mesh grid (Abstand X:Y in mm - Sx:x / Punkte X:Y - Px:x)
              M200 D1.75
              M404 N1.75 D0.4
              M221 D0 S95
              M572 D0 S0.045
              ;Accelerometer Board- Orientation - sample frequenz in Hz - Resolution 8,10,12
              M955 P121.0 I06 S1000 R12
              ; Ringing Frequenz
              M141 H1
              ;M950 H3
              ;M141 H3
              ;Led Beleuchtung
              ; Zone 1
              ; Zone 2
              ; Toolboard Buttons
              ;button0 LC1.121
              ; button1 LC1.121
              T0
              M563 P0 S"Mosquito" D0 H1 F1                  ; define tool 0
              M207 S0.65 F2400 Z0.00				 ; FW Retraction Mosquito S-Dist F-Speed Z-HHeight
              ;M572 D0 S0.065
              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"           ; set params for PowerLoss
              M122 and M122 B122 after rebooting and Homing the board:
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
              Used output buffers: 4 of 40 (11 max)
              Static ram: 150784
              Dynamic ram: 62736 of which 12 recycled
              Never used RAM 140660, free system stack 126 words
              Tasks: SBC(ready,6.7%,298) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,59) MAIN(running,85.0%,922) IDLE(ready,0.1%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:03:30 ago, cause: software
              Last software reset at 2021-06-02 21:27, reason: User, none spinning, available RAM 140660, slot 2
              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              Aux1 errors 0,0,0
              Step timer max interval 132
              MCU temperature: min 38.2, current 38.4, max 54.7
              Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
              Driver 0: position 69144, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/235
              Driver 1: position 60461, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/242
              Driver 2: position 5012, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/128
              Driver 3: position 0, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/132
              Driver 4: position 0, standstill, reads 52829, writes 23 timeouts 0, SG min/max 0/126
              Driver 5: position 0, standstill, reads 52842, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2021-06-02 21:31:10
              Slowest loop: 174.76ms; fastest: 0.03ms
              === Storage ===
              Free file entries: 10
              DMs created 125, maxWait 65943ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 39, completed moves 39, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
              === AuxDDARing ===
              Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
              Heater 0 is on, I-accum = 0.3
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Filament sensors ===
              Extruder 0: no data received
              === CAN ===
              Messages queued 1953, send timeouts 0, received 2731, lost 0, longest wait 2ms for reply type 6048, peak Tx sync delay 206, free buffers 49 (min 48), ts 1052/1051/0
              === SBC interface ===
              State: 4, failed transfers: 0
              Last transfer: 3ms ago
              RX/TX seq numbers: 7616/7616
              SPI underruns 0, overruns 0
              Number of disconnects: 0, IAP RAM available 0x2c8bc
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.3-rc3
              Code buffer space: 4096
              Configured SPI speed: 8000000 Hz
              Full transfers per second: 36.71
              Codes per second: 0.87
              Maximum length of RX/TX data transfers: 4192/888
              6/2/2021, 9:30:49 PM	M572
              Extruder pressure advance: 0.045
              M122 B121
              Diagnostics for board 121:
              Duet TOOL1LC firmware version 3.3RC3 (2021-05-26 12:30:20)
              Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1)
              Never used RAM 3164, free system stack 2743 words
              Tasks: Move(notifyWait,1.4%,91) HEAT(delaying,3.5%,99) CanAsync(notifyWait,0.0%,55) CanRecv(notifyWait,0.5%,75) CanClock(notifyWait,0.5%,66) TMC(notifyWait,73.1%,57) MAIN(running,306.3%,343) IDLE(ready,0.0%,40) AIN(delaying,126.9%,142), total 512.1%
              Last reset 09:55:49 ago, cause: power up
              Last software reset time unknown, reason: AssertionFailed, available RAM 4592, slot 1
              Software reset code 0x0120 ICSR 0x00000000 SP 0x20003cac Task   Freestk 130 bad marker
              Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 20000ed0 00000000 00000001 0000828d 200071c8 200071c8 200071e0 00000000 20000f50 000116b3 00022530 000225e8 00021c40 00019c55 200071c8 200071c8 20000f50 00008405 200071d8 000009c6
              Driver 0: position 2749860, 859.0 steps/mm, standstill, SG min/max 0/496, read errors 0, write errors 0, ifcnt 35, reads 41677, writes 35, timeouts 0, DMA errors 0, steps req 6992002 done 6992002
              Moves scheduled 43088, completed 43088, in progress 0, hiccups 0, step errors 0, maxPrep 788, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
              Peak sync jitter 0/6, peak Rx sync delay 240, resyncs 0/4, no step interrupt scheduled
              VIN: 24.1V
              MCU temperature: min 19.9C, current 63.7C, max 91.8C
              Ticks since heat task active 214, ADC conversions started 35621485, completed 35621484, timed out 0, errs 0
              Last sensors broadcast 0x00000002 found 1 219 ticks ago, loop time 0
              CAN messages queued 448969, send timeouts 0, received 366694, lost 0, free buffers 37, min 35, error reg 440000
              dup 0, oos 0/0/0/0, bm 0, wbm 0
              Accelerometer detected: no
              I2C bus errors 4481, naks 4481, other errors 4481
              Interrupt 5726621 to 0us, poll 8 to 3604us
              Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              The same M122 right now after starting the Print:
                @frederik please share the Cura-generated print file.
                Frederik 2 Replies Last reply Reply Quote 0
                • Frederik
                  UniversalFace_with FW Retraction.gcode
                  UniversalFace_without FW Retraction.gcode
                  it is the same base STL only the checkbox FW Retraction is enabled or disabled
                  • Frederik
                    @dc42 I think i foäund the Problem, i didnt even know that there was a seperate plugin installed calle Linear Advance Feature. The checkbox was hidden under the Material Tab 😞
                    I deinstalled the plugin and slice the file again to check if the Value will be overwritten again
                      Phaedrux Moderator @Frederik last edited by
                      @frederik Glad you found it.
                      M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin
                      • Frederik
                        Frederik @Phaedrux last edited by
                        @phaedrux Yeah, as i saw that line i was a little bit shocked, because as i switched to FW Retract, i double checked every settings in the Printer Settings Menu, and was happy that it worked, but musst have overlooked that Line 🙂
                        • Frederik
                          @nuramori
                          You did a really nice Job with that Guide, thanks for that. Is that your Printer in the Pictures ?
                          What is that for a design ? your own or something publicly available ?
                          Kindly Regards
                          Frederik
                          Nuramori 1 Reply Last reply Reply Quote 0
                          • Frederik
                            Frederik @Phaedrux last edited by Frederik
                            @phaedrux i dont know if it is worth to open a new thread for this:
                            Is it possible with the Toolboard v1.1 , that i can programm the 2 buttons on the front for different actions like:
                            Button 1 Extrude
                            Button 2 Retract
                            Button 1 heater output 2 on/off
                            Button 2 heater output 3 on/off
                            Button 1 call makro 1.g (load Filamaent)
                            Button 2 call makro 2.g (unload)
                            only for example purposes 🙂
                            Power Distribution on the V1.1
                            I would like to test a inductive Probe on my flexsteel plates that would need 24V (VIN) , because i slowly getting problems with deformed probing pins because of the temps when printing PC at 120°C bed and 70°C chamber 🙂
                            it is a Normal Open switching on.
                            how should i wire it to the IOs ?
                            could i get the + from VIN and only use the signal wire / - for the trigger ?
                            TIA Frederik
                            martin7404 1 Reply Last reply Reply Quote 0
                            • martin7404
                              martin7404 @Frederik last edited by
                              @frederik you may consider Pinda probe , it is 5 v
                              Muldex IDEX 3d printer Duet2+Duex5+Paneldue 7i
                              Custom CoreXY 600x400 Hemera , Duet3+toolboard v1.1, Paneldue 7i
                              Mod Sapphire Pro with Duet2 ,Expansion Board with closed-loop motors
                              voron v0.1 and cr10s both running klipper; stock Bambu lab X1CC
                              Frederik 1 Reply Last reply Reply Quote 1
                              • Nuramori
                                Nuramori @Frederik last edited by Nuramori
                                @frederik that’s my printer. It originally started out as a BLV cube, but I’ve done many modifications even from the onset, with blind joints and structural improvements. The extruder is my own design, as is the triple independent z axis implementation. Quite of a few aspects of it are shared, especially the extruder design on GitHub.
                                • Frederik
                                  @nuramori thansk for the answer 🙂 looking good
                                  is that a mosquito aqua in combination with a orbiter ? a few people use also the combination from mosquito air and the orbiter on the EVA Carriage System. They work really well. Do you also use a single 120mm radiator with fan for you cooling loop ? i´m thinking what would the best way to integrate the Extruder STepper Motor and Toolboard somehow to the cooling loop. Printing the most Time at around 75°C in the chamber PC , Abs or Abs-PC Parts. Until now i didnt get any Errors or Warnings regarding the temps. Im real curious how long they will last
                                  • Frederik
                                    Frederik @martin7404 last edited by
                                    @martin7404 i will have a look at the specs. since im using a Lc1 v1.1, i already have 24v,12v and even 5v to choose from, but i wanted to run the probe with 24V so i get a little bit better readings and distance
                                    • Nuramori
                                      @frederik it’s not an orbiter. It’s a ground up design I worked on, though it does use a planetary gear as part of the design. Lorinz and I have often talked about design and 3D, and one late night discussion seemingly drove us to explore similar things, but implemented in different ways. Mine is fairly specific to the BLV, though I made a more generic version for coreXY type designs. Mine also uses more generic nema11 motors like those from moons and offsets it so the extruder itself sits much lower and on top of the hotend for minimal filament travel.
                                      • Frederik
                                        @nuramori Thanks for the Info. Looking real nice ! What buildvolumoe do you have ? my vcore Pro is around 430x430x400mm and until now, i managed up to 410mm/s wiht a genuine BMG and a mosuqito magnum with 0.4mm Nozzle at 0.25mm Lh and 0.46mm Lw
