    BL-Touch works for Z home but not for bed leveling?
    Using Duet Controllers
    82
    • miller-spec
      miller-spec last edited by
      So I've upgraded my CR-10S with a Duet 2 WiFi, 24V power supply, BL Touch, etc. Over the last week I've been working on the config; finally got it to home with the BL Touch (no z switch) and complete a decent calibration cube print. BUT...
      When I try to perform either a G29 "Run mesh compensation" or G32 "True bed leveling"
      I get "error : Z probe was not triggered during probing move"
      Any Ideas? it does deploy with the m280 p0 s10, and retract with m280 p0 s90.
      If any other G code files are needed let me know ill post them quickly.
      Thanks!
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 30 2021 22:04:22 GMT-0700
      G29 ; probe the bed and enable compensation
      ; config-override.g file generated in response to M500 at 2021-05-31 18:36
      ; Heater model parameters
      M307 H0 A204.9 C265.4 D1.1 S1.00 V24.1 B0
      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 30 2021 22:04:22 GMT-0700 (Mountain Standard Time)
      M550 P"Miller-Spec Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z400.00 E140.00 ; set steps per mm
      M566 X450 Y450 Z350 E2000 ;Jerk
      M203 X12000 Y12000 Z1500 E5000 ; max speed
      M201 X900 Y900 Z300 E5000 ;Acceleration
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-4 Y-6 Z0 S1 ; set axis minima
      M208 X302 Y302 Z400 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H0 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-43 Y-7 Z3.67 ; set Z probe trigger value, offset and trigger height
      M557 X20:282 Y20:282 S16.375 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4983 C1.647829e-7 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S300 ; set temperature limit for heater 0 to 300C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4983 C1.647829e-7 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M106 P0 S0.5 H-1 ; set fan 0 value. Thermostatic control is turned off
      M106 P1 S0.5 H-1 ; set fan 1 value. Thermostatic control is turned off
      M106 P2 S0.5 H1 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
      G10 P0 X-4 Y-6 Z0 ; set tool 0 axis offsets
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
        Post your homeall/homez as well.
        Does M401 and M402 work to deploy/retract the pin?
        Please also post the results of M122 and M98 P"config.g"
        miller-spec 1 Reply Last reply Reply Quote 0
        • miller-spec
          miller-spec @Phaedrux last edited by
          @phaedrux
          Thank you for taking the time to check this out! I really appreciate it.
          When sending M401 it does deploy; and retract with M402
          Home all and Home Z is posted under these results.
          Result of M98 P"config.g"
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
          6/1/2021, 1:15:17 PM m122
          Results of M122 - "response too long" but in console I get...
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S4-6J9F6-3S46T-1U0AL
          Used output buffers: 3 of 24 (10 max)
          Static ram: 27980
          Dynamic ram: 93992 of which 24 recycled
          Exception stack ram used: 496
          Never used ram: 8580
          Tasks: NETWORK(ready,316) HEAT(blocked,1224) MAIN(running,1896) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:23:54 ago, cause: power up
          Last software reset at 2021-05-31 18:02, reason: User, spinning module GCodes, available RAM 8556 bytes (slot 0)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 26.4, current 37.2, max 37.5
          Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 121/419
          Driver 1: standstill, SG min/max 105/268
          Driver 2: standstill, SG min/max 0/554
          Date/time: 2021-06-01 13:14:56
          Cache data hit count 2524443450
          Slowest loop: 9.40ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.2ms, write time 2.1ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 1204431ms
          === MainDDARing ===
          Scheduled moves: 8, completed moves: 8, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 29.95ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address e0:98:06:22:e6:14
            WiFi Vcc 3.34, reset reason Unknown
            WiFi flash size 4194304, free heap 20408
            WiFi IP address 192.168.1.14
            WiFi signal strength -54dBm, reconnections 0, sleep mode modem
          ; homeall.g
          ; called to home all axes
          G91 ; relative positioning
          G1 H2 Z5 F9000 ; lift Z relative to current position
          G1 H1 X-311 Y-313 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F9000 ; go back a few mm
          G1 H1 X-311 Y-313 F600 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X63 Y27 F9000 ; go to first bed probe point and home Z
          M558 A1 F100
          G1 Z5 F150 ; lift Z relative to current position
          ; homez.g
          ; called to home the Z axis
          G1 H2 Z5 F900 ; lift Z relative to current position
          G1 X63 Y27 F900 ; go to first probe point
          M558 A1 F100
          ;M558 A10 F120
          ;G30
            Phaedrux Moderator @miller-spec last edited by
            @miller-spec said in BL-Touch works for Z home but not for bed leveling?:
            Why do you have your dive height as 0? It should be at least slightly higher than your trigger height. So try H5.
            You should also update your firmware. Upload this zip file to the system tab in DWC.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
            • DIY-O-Sphere
              DIY-O-Sphere last edited by
              ; bed.g
              To run G32 you have to define probing points in bed.g
              https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_How_it_works
              And the layout of the z-axis
              M671
              is missing in config.g
              (UTC+1)
              • miller-spec
                @phaedrux
                Thanks, I Changed my dive height to 5 and updated the firmware. Now I'm able to run mesh compensation and see my height map.
                • miller-spec
                  miller-spec @DIY-O-Sphere last edited by
                  @diy-o-sphere
                  I'm guessing I cant use G32 because I have my motors wired in series. G32 would allow the controller to adjust the bed right? which isn't possible wired like that. So that's my bad didn't do any research on that command. Thank you though, I appreciate the response.
                  DIY-O-Sphere droftarts 2 Replies Last reply Reply Quote 0
                  • DIY-O-Sphere
                    DIY-O-Sphere @miller-spec last edited by DIY-O-Sphere
                    @miller-spec
                    You can use G32 to level the bed by adjusting the level screw by hand.
                    G32 reports the deviations for each point, so it is much easier to do that....
                    I have used that for a long time before switching to double Z....
                    (UTC+1)
                    • droftarts
                      droftarts Moderator @miller-spec last edited by
                      @miller-spec you have a spare motor driver, so you could split the Z motors and connect each to their own driver, for auto bed levelling (though just left/right). See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                      • miller-spec
                        @diy-o-sphere
                        True, Ill try that. I've been using my digi caliper to probe the gantry to the bed on its extreme ends and twisting the lead screws till they're close, then releveling haha. Thanks, gonna see what G32 does now.
                        • miller-spec
                          miller-spec @droftarts last edited by
                          @droftarts
                          Once I figure out a way to neatly enclose all this new hardware I'll definitely do that. Right now its all bolted to the old CR-10 enclosure skeleton haha..
