Unsolved Detachable Probes and Probing
@dc42 I think I have noticed a pattern that may highlight the probe pickp/retract issue. I am using Duet3 Ethernet, RRF version 3.2.2
Case 1: Printer is homed. Probe is detached. Carraige is at X,Y of 100,100
Issue G30 S-1 command to perform a single probe. The expectation is probe will occur at 100,100.
Printer will execute M401 and sucessfuly deply the probe EXCEPT that instead of probing the original position of 100,100, it will execute the probe at the final positiion of the deployprobe.g macro.Expectation is that the printer would have returned to the position (100,100) to perform the probe.
Case 2: Priner is homed, Probe is detached.
Issue M401 P0 command, printer picks up the probe.
G1 move to the point 100,100 and then issue
G30 S-1
and it executes the single probe at the point.EDIT- Case 3 Printer is homed, Probe is detached
Issue G30 X100 Y100 S-1 command, priner will sucessfuly deply the probe and will execute the probe at the final positiion of the deployprobe.g macro instead of the X100 Y100 coordinate.Bothe cases: issuing M402 P0 errors and reports back probe is not present.
Which is because of my gcode metal logic of sensing the presence of the probe via the probe's actual value of 0 or 1000 (open circuit vs closed vircuit).
As the machine stops Z motion at the probe trigger, the probe is still triggered, NC having gone open.
Moving the Z away from the probe will reset the probe back to the NC state and then the M402 script will execute. -
I wonder if you could use G60 to store the location and then use G1 R to restore to that location.
https://duet3d.dozuki.com/Wiki/Gcode#Section_G60_Save_current_position_to_slot
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G0_G1_Move -
@phaedrux you could, but that seems like that would not be nescessary.
The wiki says that if the G30 -S1 command is issued without X or Y coordinates, the probe would occur at that point. To me, that means it will probe the X,Y where the command was issued.
I could just issue a G30 X100 Y100 S-1 but that is different than giving the G30 by itself. I don't remember the results of that offhand and have to redo it when the machine is not in use.
The system realizes that if there is no probe attached, it goes to deploy it. The G30 then seems to occur when the moves of the deploy macro are complete. It has forgotten the starting point.
EDIT: I updated the case of giving a G30 with coordiantes to the original post.
@dc42 @T3P3Tony I am pretty certain that something is up with the deploy and retract scheme. The system does not realize that the probe is picked up, even though it has sucessfully picked up the probe.
The approach that I am trying to used is to change the probe pin inversion and do homing moves instead of using one probe type and incremental moves.
Can you answer these questions and offer any guidance?-
Does changing the probe pin inversion reset the probe pickup state?
What is the token in the object model that represents the probe deployment state? I can not tell from the OM Browser. Screen snip at the end.
Here is a video of my machine tying to deploy the probe using a G1 move command instead of a controlled incremental move. And for good measure, the macros and config in a zip file if you want to delve deeper.
Here is the commented deployprobe.g file that is running in the video.
; *********************************************************** ; deployprobe.g ; config.g is M558 K0 P8 C"^zprobe.in" H10 R0.5 F240:120 T9000 A3 S0.03 ; *********************************************************** echo "Running deployprobe.g" echo "Reset Probe to NC" M558 K0 P8 C"^zprobe.in" H10 R0.5 F240:120 T9000 A3 S0.03 G91 M564 H0 S0 ; allow movement while not homed G1 Z17 F6000 ; move Z 15 for clearance above dock. ; need to figure out some safety check on this G90 echo "First logic check" echo "Probe State Value" ^sensors.probes[0].value[0] if sensors.probes[0].value[0]!=1000 ; if sensor is value other than 1000 do this abort "deployprobe start value Probe already picked up. Manually return probe to the dock" ; echo sensors.probes[0].value[0] ; if we're here we know it's becasue the above is true which I assume is because you have an NC switch as a probe. echo "Pass first logic test" echo "Move to doc" G1 X0.0 Y-27 F6000 ; move above probe dock location G91 G1 Z-10 G90 M400 ; wait for moves to finish echo "Redefine probe type" M558 K0 P8 C"^!zprobe.in" H10 R0.5 F240:120 T9000 A3 S0.03 echo "M558 Inverted" G4 S1 echo "Probe Pickup while loop running" ; while sensors.probes[0].value[0]=1000 echo "Probe State Value" ^sensors.probes[0].value[0] while sensors.probes[0].value[0]=0 G91 ; G1 Z-0.5 F600 ; was controled move in previous scheme G1 Z-100 H1 F300 ; move in -Z to trigger endstop via G1 H1 M400 G90 ; echo sensors.probes[0].value[0] ; echo iterations ; if iterations=100 ; break echo "Probe Pickup while loop complete" G91 ; relative coords G1 Z-0.5 F600 ; move bed up 0.5 to clear probe from dock since mags pull it up M400 ; wait for move to finish G90 G1 X50 F3000 ; move right so probe moves out of the dock M400 G1 Z12 F3000 ; move bed to clear probe from glass build surface G1 X100 F6000 ; G90 ; absolute coords M400 ; wait for moves to finish G4 S2 ; wait 1 second echo "Probe State Value " ^sensors.probes[0].value[0] echo "Restore probe type" M558 K0 P8 C"^zprobe.in" H10 R0.5 F240:120 T9000 A3 S0.03 echo "Probe State Value " ^sensors.probes[0].value[0] M400 G4 S2 echo "Last Logic Check" echo "Probe State " ^sensors.probes[0].value[0] if sensors.probes[0].value[0]!=0 abort "Abort deployprobe endvalue not 0 Probe not picked up! Print cancelled." echo "deployprobe.g complete"
@sinned6915 said in Detachable Probes and Probing:
How are you commanding the probe to be picked up? The system should realise it is picked up if and only if you use M401 to pick it up.
@dc42 I am explicitly calling M401 to deploy the probe in the homez.g file. Line 13 of the homez.g file
it's already picked up and in position when the G30 command in issued in the bed.g file (4 point leveling, 3 Z screws).
The error message that the system reports from the gcode meta command comes from the M401 file.
If you watch the youtube video, you will see the console messages with the carriage movements.
Console & Machine Video - https://www.youtube.com/watch?v=0A3sT0sjbHsYou can see where in the homez.g macro, where the pritner has has picked up the probe and successfully completed M401, it returns and calls the bed.g macro. Taht is where the M401 is called again and i errs out becasue the probe is already picked up.
; *********************************************************** ; homez.g ; *********************************************************** if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it M98 P"0:/sys/homexy.g" M561 ; clear any bed transform M290 S0 R0 ; clear baby steps per Wes C G91 ; relative positioning M400 ; G1 H2 Z6 F6000 ; lift Z relative to current position G90 ; absolute positioning echo "Call deployprobe.g macro" M401 P0 ; This runs macro file deployprobe echo "returned from deployprobe.g" echo "Go to center of bed & probe" G1 X145 Y162.5 F3000 ; go to bed center M400 ; echo "Perform G30 S-2 Command" ; G30 ; Probe the bed at the current XY position. When the probe is triggered, ; adjust the Z offset of the current tool to make the current position Z=0. echo "Perform G1 Z-10 H1 Command" G1 Z-10 H1 ; Move and terminate the move when the endstop switch is triggered and set the axis position to echo "Perform G92 Z2.6 Command" G92 Z2.6 ; Set the Z axis to the probe offset height M400 G91 ; Relative Coordinates G1 Z1 F6000 M400 G90 ; Absolute Coordinates G1 Z10 F6000 M400 G4 P500 echo "Call bed4point.g macro" M98 P"0:/sys/bed4point.g" ; tram bed ; echo "Return from 4-point macro" echo "Re-probe to set Z incase it drifted" G1 X145 Y165 F9000 ; go back to the first probe point and reprobe 0 in case it moved G30 echo "Call retractprobe.g macro" M402 P0 ; retract probe echo "Return from M402" G1 Z10 F600 ; lift Z relative to current position G90 ; absolute positioning M564 S1 H0 ; G1 X150 Y0 F9000 ; move carraige to center front
@sinned6915 use conditional gcode in the bed file to check whether the probe has already been picked up or not.
sensors.probes[0].deployedByUser
that object should do it for you.
so something likeif sensors.probes[0].deployedByUser == 0 M401
@jay_s_uk ok, i will try using that as a token to report the status.
i could not tell what that token was telling me.
What error message? I didn't see an error message in your video.
@dc42: i am sorry if i mis-spoke.
I wrote the echo comment to read
Bottom line, I can not determine why the system seems to loose track of the probe pickup token.
Do you have any ideas? Can you offer any help?
I have been fighitng this for weeks, months really if you go back to my other thread on trying to pick up the probe from the bed.
