    Toolboard V1.1
    Beta Firmware
    222
    • empi00
      empi00 last edited by
      Any timeframe, when I will be able to use the Accelerometer in combination with a SBC in a (Beta)Firmware?
      Thanks
      jay_s_uk dc42 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @empi00 last edited by
        @empi00 apart from gather data in standalone mode, no one can make use of the accelerometer.
        It will start to get utilised as part of the 3.4 beta releases
          dc42 administrators @empi00 last edited by
          @empi00 with firmware 3.3 you can use it in standalone mode to collect data, from which you can determine the best frequency to use for DAA. Then in one of the early 3.4beta releases you will be able to use the data to tune more advanced forms of input shaping. Support for accelerometers in conjunction with SBC will also appear in firmware 3.4.
          jbarros 1 Reply Last reply Reply Quote 1
          • jbarros
            jbarros @dc42 last edited by
            @dc42 for those of us with several Toolboards v1.0:
            Will the accelerometer be used/required to be installed permanently or it's sample, change the config and take it out?
            I got the accelerometer, just wondering if I should consider the upgrade from Toolboards 1.0 to 1.1, which are also handier for fan voltages != 12V
              dc42 administrators @jbarros last edited by
              @jbarros the accelerometer does not need to be installed permanently.
              tecno 1 Reply Last reply Reply Quote 1
              • tecno
                tecno @dc42 last edited by
                Can I use ADXL345 in 'future' ?
                  dc42 administrators @tecno last edited by
                  @tecno we don't have any plans to support that accelerometer.
                  tecno 1 Reply Last reply Reply Quote 0
                  • tecno
                    OK, so what accelerometer do I need to get to my Toolboard V1.0 for X axis or is it so that it needs to be connected directly to Mini5+ ? Need another for Y axis.
                    • jay_s_uk
                      jay_s_uk @tecno last edited by
                      @tecno it's used for input shaping, primarily on moving masses. As the toolboard is generally aimed at extruders, it would be to reduce the effect of ghosting
                        @tecno said in Toolboard V1.1:
                        See https://duet3d.dozuki.com/Wiki/Accelerometers. If your printer is a bed slinger then you can use a single accelerometer if you can move it between the print carriage and the bed.
                        • tecno
                          Thank you !
