    Thermistor,PT100, PT1000
    1.1k
      Can you send M115 and M115 B121 and confirm that the firmware version on both the mainboard and toolboard match?
      Auréundefined 1 Reply Last reply Reply Quote 0
      • Auréundefined
        Auré @Phaedrux
        @phaedrux said in Thermistor,PT100, PT1000:
        M115 B121
        Yep:
        Console:
        M115 B121:
        Reprap core XY, Ender 3 upgraded.
        If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
        A quote from Jacques Rouxel
          jay_s_uk @Auré
          @auré you're running out of sync firmware. Try running M997 B121
          • Auréundefined
            Auré @jay_s_uk
            @jay_s_uk said in Thermistor,PT100, PT1000:
            M997 B121
            Ok I send M997 B121:
            The thermistore not work
            I would like stop the fan and I have new error:
            • Auréundefined
              Auré
              For the fan I found this post
              I add F1:
              M563 P0 D0 H1 F0 F1 ; define tool 0
              And now the fan control work.
              But not the thermistor.
              I don't know why but now the thermistor on the toolboard work.....
              I have only add F1
                jay_s_uk @Auré
                @auré post your full config and send M115 B121 to confirm 3.2.2 is on the toolboard
                  Phaedrux Moderator @jay_s_uk
                  Looks like he is now.
                  Full config.g would be nice.
                  • Auréundefined
                    Auré
                    I post tomorrow the config.g thank you for your help good night 🙂
                    • Auréundefined
                      Auré
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 20:14:20 GMT+0200 (heure d’été d’Europe centrale)
                      M550 P"Duet 3" ; set printer name
                      M552 S1
                      M669 K1 ; select CoreXY mode
                      G4 S1 ;wait for expansion boards to start
                      M569 P0.0 S0 ; physical drive 0.0 goes forwards
                      M569 P0.1 S0 ; physical drive 0.1 goes forwards
                      M569 P0.3 S0 ; physical drive 0.3 goes forwards
                      M569 P0.4 S0 ; physical drive 0.4 goes forwards
                      M569 P0.5 S0 ; physical drive 0.5 goes forwards
                      M569 P121.0 S1 ; physical drive 121.0 goes forwards
                      M584 X0.0 Y0.1 Z0.3:0.4:0.5 E121.0 ; set drive mapping
                      M671 X-30,109:171.1:372.309 Y-10,413:367,797:-10,413 S50
                      M92 X160.00 Y160.00 Z800.00 E335.40 ; set steps per mm
                      M566 X1200.00 Y1200.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X18000.00 Y18000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
                      M201 X1600.00 Y1600.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1200 E840 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X365 Y365 Z335 S0 ; set axis maxima
                      M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 121.io1.in
                      M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                      M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
                      M558 P9 C"^121.io0.in" H15 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X3 Y-41 Z2.5 ; set Z probe trigger value, offset and trigger height
                      M557 X15:215 Y15:195 S20 ; define mesh grid
                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                      M143 H0 S100 ; set temperature limit for heater 0 to 100C
                      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
                      M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
                      M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
                      M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
                      M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
                      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                        jay_s_uk @Auré
                        @auré said in Thermistor,PT100, PT1000:
                        can you try increasing the G4 S1 to G4 S4 to give it a bit longer for the toolboard to be ready?
                        • Auréundefined
                          Auré @jay_s_uk
                          Yes thank you, I told myself that I had to extend the time because when I start the printer with DWC open, sometimes I have error communication of bus, but I forgot.
                          I think you're right 4 second it's ok.
