    Multiple tools Accelerometer
    • BeosDocundefined
      BeosDoc
      Would you need a separate accelerometer data for each tool (on a CoreXY tool changer system)? Tools could be different, but usually are the same.
      If so is, is the plans to add a per tool ringing frequencies in future versions?
      I'm trying to determine if I should just replace one toolboard with V1.1 or mount an accelerometer to the X carriage.
      I wonder if anybody has tested to see how much weight difference does there need to be before it effects the ringing frequencies.
      Glad ringing using an accelerometer is being added. Didn't want to switch to Klipper
      Thanks
      Mitch
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @BeosDoc
        @beosdoc I believe it will be per tool
          dc42 administrators @BeosDoc
          @beosdoc if the tools are very similar then the resonant frequencies should be the same too. If they are very different (e.g. Hemera vs. Bowden tool on a E3D Tool Changer) then the frequencies are likely to be somewhat different too.
          If other things are equal, the resonant frequency should be inversely proportional to the square root of the relevant mass.
          BeosDocundefined 1 Reply Last reply Reply Quote 0
          • BeosDocundefined
            BeosDoc @dc42
            Will there be support for ringing frequencies for multiple tools in the future or just load a corresponding script when changing tools, if possible?
            Thank you for your time
            • chrishammundefined
              chrishamm administrators @BeosDoc
              @beosdoc If you actually get different ringing frequencies per tool, I think you could set different values in your tpre/tpost macros.
              Duet software engineer
