    [3.3.0] strange behavior after fresh start printer
    Using Duet Controllers
    288
    • SIamundefined
      SIam
      My printer have always some new ideas 😉 I have switched on my Printer and heated it up to change the nozzle. Here i've got the first problem Heater fault because it was heating too slow (here i should do a new PID tuning) After reset the heater i was able to heat it up without error.
      After the nozzle change, i started the bed compensation:
      G90
      M83
      g28
      M106 P2 S0.50
      ;Bett und Hotend auf Kalibrierungs Temperatur bringen
      M140 S70; set bed temp, no wait
      M104 S140; set extruder temp, no wait
      M190 S70  ; wait for bed temp
      M109 S140 ; wait for extruder temp
      M300 S500 P300
      M291 P"Bitte die Nozzle überprüfen und ggf. Filament Reste entfernen. Ok or Cancel?" R"Achtung" S3 ; User must click OK or cancel.
      G32
      G0 X15 Y15 Z15 F2000
      M106 P2 S0
      Here i've got again the heater fault, This i wanted reset again but no reaction on click the Thermistor reset button.
      Here i tried to click on the emergency stop button, here again no reaction. Now i have changed the Browser but here the same issue.
      The last thing i have done was to reset the printer over the console and here i've got the following error:
      At this point, i have switched off the printer and switched it back on now it seems that the printer runs normal. I have done again bed compensation and started a new print without any heater fault.
      greets
      Andy
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
        Could you share your full config.g and the results of sending M122 and M98 P"config.g" please?
        SIamundefined 2 Replies Last reply Reply Quote 0
        • SIamundefined
          SIam @Phaedrux
          @phaedrux here we go 😉
          M122
          18.6.2021, 23:10:58	m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
          Used output buffers: 3 of 24 (22 max)
          Static ram: 23876
          Dynamic ram: 78140 of which 12 recycled
          Never used RAM 9532, free system stack 112 words
          Tasks: NETWORK(ready,13.9%,244) ACCEL(notifyWait,0.0%,334) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,277) DUEX(notifyWait,0.0%,24) MAIN(running,85.9%,443) IDLE(ready,0.1%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:53:33 ago, cause: power up
          Last software reset at 2021-06-13 13:20, reason: User, GCodes spinning, available RAM 9532, slot 1
          Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 31.5, current 36.5, max 38.4
          Supply voltage: min 24.0, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/934/934, gc cycles 0
          Driver 0: position 22368, standstill, SG min/max 0/199
          Driver 1: position 880, ok, SG min/max 0/196
          Driver 2: position 1459, ok, SG min/max 0/1023
          Driver 3: position 0, ok, SG min/max 0/1023
          Driver 4: position 0, ok, SG min/max 0/1023
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, ok, SG min/max 0/126
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-06-18 23:10:53
          Slowest loop: 196.37ms; fastest: 0.11ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 11.1ms, write time 107.1ms, max retries 0
          DMs created 83, maxWait 1302124ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 1677, completed moves 1672, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.1
          Heater 1 is on, I-accum = 0.5
          Segments left: 2
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 3
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: ok
          === DueX ===
          Read count 1, 0.02 reads/min
          === Network ===
          Slowest loop: 658.06ms; fastest: 0.00ms
          HTTP sessions: 2 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.26
          WiFi MAC address 2c:3a:e8:0b:06:33
          WiFi Vcc 3.44, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 22800
          WiFi IP address 192.168.188.142
          WiFi signal strength -46dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          Socket states: 0 2 0 0 0 0 0 0
          config.g
          ;jerk z achse af 50 von 20
          ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 16:17:09 GMT+0100 (Mitteleuropäische Normalzeit)
          ;pwm auf ausgang 5
          ;M555 P2												; Marlin emulation
          G90                                                 ; send absolute coordinates...
          M83                                                 ; ...but relative extruder moves
          M550 P"hypercube"                                   ; set printer name
          M554 P192.168.188.1                                 ;set gateway
          M553 P255.255.255.0
          M669 K1                                        ; select CoreXY mode
          M552 S1                                             ; enable network
          M586 P0 S1                                          ; enable HTTP
          M586 P1 S1                                          ; disable FTP
          M586 P2 S1                                          ; disable Telnet
          M553 P255.255.255.0
          M569 P0 S0                                          ; physical drive 0 = X goes backwards
          M569 P1 S0                                          ; physical drive 1 = Y goes backwards
          M569 P2 S1                                          ; physical drive 2 = Z goes forwards
          M569 P3 S1                                          ; physical drive 3 = Z goes forwards
          M569 P4 S1                                          ; physical drive 4 = Z goes forwards
          M569 P5 S0                                          ; physical drive 5 =  nc
          M569 P6 S0                                          ; physical drive 6 =  orbiter direct
          M569 P7 S1                                          ; physical drive 7 = E0 goes forwards bmg bowden
          M569 P8 S1                                          ; physical drive 8 = nc
          M569 P9 S0                                          ; physical drive 9 = g5 flex
          M584 X0 Y1 Z2:3:4 E6                                ; set drive mapping orbiter
          M350 X16 Y16 Z16 E16 I1                          ; configure microstepping with interpolation
          M671 X0:390:0 Y30:160:304 S3 F1.0                    ; Leitspindeln links und rechts von der X-Achse
          M92 X80 Y80 Z802 E692 ;z790.6 E1175 ;E1420 ;E714 ;E2143 ;E2124 ;E1900 ;4246 ;2123                     ; set steps per mm G5 Flex 2145 ohne dda 782.40
          ;M92 X80 Y80 Z802.46 E4286
          ; G5 Flex
          ; jerk
          ;M566 X600.00 Y600.00 Z300.00 E300 ;E150         ; set maximum instantaneous speed changes (mm/min) x/y 600 original
          M566 X300.00 Y300.00 Z100.00 E300 ;E300 last z = 150 xy=600 zwar 50
          M203 X30000.00 Y30000.00 Z2400.00 E3600.00     ; set maximum speeds (mm/min)
          ;M201 X4000.00 Y4000.00 Z1000.00 E600 ;E120;E180.00          ; set accelerations (mm/s^2) x/y 2000 z 500 original
          M201 X1500.00 Y1500.00 Z200.00 e600 ;E600 last z= 250 xy=1000
          M204 P1200 T4000
          ;19.3.2021, 18:30:31	m201 e3000
          ;19.3.2021, 18:30:16	m566 e1500
          ;19.3.2021, 18:29:55	m572 d0 s0.07
          ; x/y Nema 17 42BYGHW811 2.5Amp 4800Torque
          ; Z Nema 17 Bipolar 1.8deg 65Ncm 2.1A 3.36V 17HS24-2104S
          ; E bondtech bowden Nema 17 Schrittmotor 1.7A 40Ncm 1.8 Deg
          M906 X2500.00 Y2500.00 E500.00 Z2100.00 I30       ; set motor currents
          ; g5 flex
          M913 X80 Y80 Z90 E100 ;E50  							;reduce stepperpower z war 95
          M208 X-1 Y0 Z0 S1                                  		; set axis minima
          M208 X390 Y350 Z415 S0                              	; set axis maxima
          M574 X1 S1 P"xstop"                                 	; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                                 	; configure active-high endstop for low end on Y via pin ystop
          M591 D0 P2 C"zstop" S1									; Z entstop als filament sensor aktivieren
          M950 J1 C"duex.e5stop" 									; Jnn = Input pin number (RRF 3.01RC2 and later only)/ C"name" Pin name(s) and optional inversion status.
          M581 P1 T2 S1 R1 ; P1
          M558 P8 R1.5 C"^!zprobe.in+zprobe.mod" H5 F600 T12000 	;A3 S0.01;
          G31 P500 X0 Y0 Z0;-0.1; 2 ;Z-0.2 ;24               ; V6 mit HC2 z-0.075
          M557 X0:390 Y0:350 P7:7 ;S75                            ; define mesh grid X0:383 Y0:361 P7:7 ;S75
          ;https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings
          M308 S0 P"bedtemp" Y"thermistor" A"Heizbett" T100000 B3950 H12     ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                               	; create bed heater output on bedheat and map it to sensor 0
          M140 H0
          M143 H0 S115                                        	; set temperature limit for heater 0 to 100C
          M307 H0 B0 S1.00                                    	; disable bang-bang mode for the nozzle heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 H10 L-3;B4276       ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                                	; create nozzle heater output on e0heat and map it to sensor 1
          ;M308 S2 P"mcu-temp" Y"mcu-temp" A"MCU"					; set virtual heater for MCU
          M308 S2 Y"mcu-temp" A"CPU"					; set virtual heater for MCU
          ;M308 S3 Y"drivers" A"Duet-Treiber"
          ;M308 S4 Y"drivers-duex" A"Duex-Treiber"
          M143 H1 S290                                        	; set temperature limit for heater 1 to 280C
          M307 H1 B0 S1.00                                    	; disable bang-bang mode for the nozzle heater and set PWM limit
          ;M950 F0 C"fan0" Q25500 ;H-1                            ; create fan 0 on pin fan0 and set its frequency
          ;M106 P0 S0 H-1 C"Bauteilkühlung"                       ; set fan 0 value. Thermostatic control is turned on
          M950 F0 C"fan0" Q500;H-1                              	; create fan 0 on pin fan0 and set its frequency
          M950 F1 C"fan1" Q500 ;H1                              	; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45 C"Hotend"                                    ; set fan 1 value. Thermostatic control is turned off
          M950 F2 C"fan2" Q250 ;H-1                              	; create fan 2 on pin fan2 and set its frequency
          M106 P2 S0 H-1 F250 C"LED"                                  ; set fan 2 value. Thermostatic control is turned off
          M563 P0 S"Orbiter" D0 H1 F0                               ; define tool 0              *****
          ;M563 P1 S"Rechts" D1 H1 F0                             ; define tool 1              *****
          G10 P0 X0 Y0 Z0                                    		; set tool 0 axis offsets
          ;G10 P1 X0 Y0 Z0                                     	; set tool 1 axis offsets
          G10 P0 R0 S0                                        	; set initial tool 0 active and standby temperatures to 0C
          ;G10 P1 R0 S0                                        	; set initial tool 1 active and standby temperatures to 0C
          M912 P0 S-6.9											; MCU Temp. korrecktur
          M501                                                	; load saved parameters from non-volatile memory
          M911 S22.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" 	;auto save on loss of power
          M572 D0 S0.12 ;12;4									    ;Pressure advance
          M593 F33 ;Dynamic Acceleration Adjustment
          M955 P0 C"spi.cs3+spi.cs4" S4800 Q10000000 R12 I20
          ;m592 D0 A0.0122865 B-0.001164296
          ;m592 D0 A0.003538564 B-6.21548E-05
          ;m592 D0 A0.000719029 B0.001242184 						; nonlinear extrusion
          ;M572 D0 s0.02											;extruder pressure advance
          T0                                                  	; select first tool
          ;M207 S4.0 F4800 z0.8									;Set retract length
          ;M290 S0.15 R0 ;
          M98 P"config.g" is at the moment not possible because the printer is printing
          • o_lampeundefined
            o_lampe @SIam
            @siam
            you got heater PID issues because you updated from RRF??? to RRF3.3.0?
            Where did you store the former M307 lines? In config.g or config-override?
            Do you know if they were invalid or 'not found' due to the new 'firmware folder' thing?
            SIamundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @Phaedrux
              @phaedrux and the output from m98
              19.6.2021, 10:52:25	m98 P"config.g"
              HTTP is enabled on port 80
              FTP is enabled on port 21
              TELNET is enabled on port 23
              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 193C
              Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 783C
              Accelerometer 0 with orientation 20 samples at 1344Hz with 12-bit resolution
              • SIamundefined
                SIam @o_lampe
                @o_lampe said in [3.3.0] strange behavior after fresh start printer:
                RRF 3.3.0 RC3
                It's stored in config-override, but i don't think that the problem is in the config-override because at the moment the printer works as it should.
                I know nothing is impossible but in this case and due to the error message "Could run code because the buffer space has been exhausted" i think it was a issue with the software or maybe a hardware problem
                • chrishammundefined
                  chrishamm administrators @SIam
                  @siam You seem to have two devices connected over HTTP to the Duet, is it possible that one client isn't DWC and doesn't query rr_reply frequently? That could lead to buffer starvation.
                  Duet software engineer
                  • SIamundefined
                    SIam @chrishamm
                    @chrishamm said in [3.3.0] strange behavior after fresh start printer:
                    After this error messages in the console, i have started Firefox as second DCW client to watch if it is a browser Problem, the first instance was the Chrome Browser
