    6HC limit switch connections
    • jens55undefined
      jens55
      Silly question but I would rather do it right to begin with.
      The i/o connector on the 6HC board has 3.3V, 5V, GND, iox.in and iox.out.
      Assuming a standard on/off type limit switch, do I connect the switch between io in and io out?
      • fcwiltundefined
        fcwilt @jens55
        @jens55 said in 6HC limit switch connections:
        What do you mean by a "standard on/off type limit switch"?
        If you were using a non-powered micro-switch with a NC connection you would likely connect the switch from IN to GND and specify that the input pullup should be enabled.
        jens55undefined 1 Reply Last reply Reply Quote 1
        • jens55undefined
          jens55 @fcwilt
          @fcwilt, yes, I mean a standard NC non powered micro switch.
          OK, I did not see that coming .... in to gnd ... what is the 'out' line generally used for?
          Thanks!
          • fcwiltundefined
            fcwilt @jens55
            Thanks!
            It's an multiple purpose output - one use is to drive the signal input of a servo to move the servo to the desired position.
            • jens55undefined
              jens55 @fcwilt
              @fcwilt, cool, I had no idea!
              Thanks!
