Suddenly Skipping Steps
@dc42 Have you gotten a chance to look at this at all?
I did more testing by making a reduced version of the gcode file to test, with no heater or fan calls, and skipping ahead to Z24.4
What I found so far:
The issue does not repeat every single time. Even with no changes to the settings or code, the issue may or may not happen.
Increasing my XY jerk from 6 mm/s to 15 mm/s made no improvement, maybe slightly worse.
Starting from Z24.4, then pausing at the first skipped step tends to happen at Z24.7. But, if I strip out the beginning code and start right at Z24.7, the glitch does not occur in the same spot. So, this isn't some bad instruction alone. It must be a combination of a code sequence, and a specific condition the motion controller is in.
Lowering the travel acceleration has the capacity to avoid the issue. Instead of my normal M204 P2660 T4000, if I run at P2000 T2000 I haven't reproduced the issue. It seems possible that this is just buying the motion controller more time to catch up.
The attached gcode should be safe for anyone else to test, just look at the intro code, to make sure the homing sequence is compatible with your setup, or modify to match your machine. I don't want anyone driving a nozzle into their bed for me!
@CCS86 I think he's deep into input shaping atm, but I will pass on your updates, and I will see if I can run your test gcode, but I don't have a maestro running atm.
@phaedrux said in Suddenly Skipping Steps:
I would gladly put this issue on ice for chance at input shaping working on a Maestro board!
@ccs86 your M122 report indicates a possible problem with the rate of execution of moves:
Scheduled moves 15909, completed moves 15909, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 1, 1], CDDA state -1
The first underrun number is the number of lookahead underruns, i.e. there were not enough spaces available in the move queue to do full lookahead. This type of underrun causes movement to be slower when there are very many short decelerating segments in succession.
The second figure is the number of prepare underruns. This indicates that the step interrupt service routine wanted another move, but although there was one it had not been prepared for execution. I think this caused the symptom you reported.
The third figure is the number of "no move" underruns. This indicates that the step interrupt routine wanted another move but none was available. It is normal to get one of these in certain situations, for example at the end of a print.
So the question is, why did a prepare underrun occur. It can only mean that the Move task either was not scheduled at an appropriate point, or the CPU was too busy servicing interrupts or executing higher priority tasks to attend to it. I will investigate it.
@ccs86 until I have a fix, I think a workaround may be to increase the movement queue length using M595. Try M595 P60 or M595 P80. Increasing the movement queue length will reduce the amount of RAM available, which you can check with M122. Look at the value of "Never used RAM" when the machine has been printing.
Awesome, thank you!
@ccs86 please check whether this issue is fixed (using the original movement queue length) in RRF 3.4.0beta2.
@dc42 said in Suddenly Skipping Steps:
Just tested in 3.4.0B2 and still skip steps with the gcode test I provided, after a fresh boot.
The weird thing is, after asserting even a M595 P40, which returns the same values as a fresh boot, it does not skip steps.
