    How to wire / setup Neopixel on the Duet 2 Wifi?
    2.4k
    • tekstyleundefined
      tekstyle @TheBasedDoge
      @thebaseddoge
      Can you Share the source of the sketch you used for your arduino?
      • A Former User?
        A Former User @tekstyle
        @tekstyle said in How to wire / setup Neopixel on the Duet 2 Wifi?:
        @thebaseddoge
        I'm interested too!
        • A Former User?
          A Former User @dc42
          @dc42 said in How to wire / setup Neopixel on the Duet 2 Wifi?:
          74HCT08
          Just for confimation, you mean that I have to connect the AND input to the Duet and the related AND out to adafruit, right? It's not clear for me if an Arduino is needed or not....in case how to interface it with the Duet?
            dc42 administrators @A Former User
            @thedragonlord you don't need the Arduino if you use firmware 3.3 and the level shifter. However, there is the limitation that on Duet 2 the print will be suspended for small fraction of a second whenever you use M150 to change the colours. So if you change the colours frequently while the machine is printing, then print quality could be affected.
            • A Former User?
              A Former User @dc42
              Uh ok....well, for now I wanted to use the RGBW ring (not strip) just to make a sort of "progress bar" for the heating before printing...I was als thinking to use it during the print to make always a sort of progress bar for the printing process but I have to study the object browser to see what information are available...I was thinking to base the progress on the actual layer number/total layers number but I still don't know if and where those informations are available...in any case I'll change colors only once per layer group..My rgbw ring has 24 LEDs so any LED would represent the 4,17% of the whole...
                @thedragonlord if you can arrange to change the colours while the filament is retracted, perhaps in a layer change script, then there should be no impact on print quality.
                • A Former User?
                  A Former User @dc42
                  yes, that's exactly what I meant to do, thanks!
                  • zaptaundefined
                    zapta @dc42
                    @dc42, is it OK to Have two 60 led stripes fed in parallel from the duet signal out? Or any other serial / parallel "tree"?
                    • mattyoundefined
                      mattyo
                      Would some one be able to give me a simple diagram on how to wire a 74HCT08 I am a noob with electronics at this level. I would really appreciate some guidance. I won’t to hook up some neo pixels to a duet wifi. But I have no idea how to use a level shifter. Thanks very much Matt.
                        dc42 administrators @zapta
                        @zapta said in How to wire / setup Neopixel on the Duet 2 Wifi?:
                        Yes, assuming your have sufficient 5V power to run both strips.
