    Where to Buy Duet3 to RPi Ribbon Cable in USA????
    • Pickettundefined
      Pickett
      I can not seem to find a place to purchase the Duet 3 to Raspberry Pi (40pin to 26pin) Ribbon Cable from as I am having what seems to be a difficult time trying to find where to buy said cable and I am getting frustrated cause I really need one as to eliminate why I cant get my Raspberry Pi 4b to communicate with the Duet 3 Mini 5+ board? I have updated everything, I am on DWC 3.3.0, Firmware Version is 3.3.0, DSF is the latest version so I am thinking that it has to do with the ribbon cable cause the RPi updates itself to all of the latest and greatest everything which is 3.3.0 across the board for all of the everything that the RPi updates itself to when enabled. Anyways help for either would be much appreciated as I am getting frustrated and am actually installing Klipper at the moment cause I can not seem to get RepRap up and running for my machine which is an Anycubic Chiron which I got specifically t mod due to its large build volume and then sell it for a decent profit all the while gaining more and more experience. Thanks in Advance!!!!!!!
      • Nuramoriundefined
        Nuramori
        Here you go.
        From Adafruit
        Pickettundefined 1 Reply Last reply Reply Quote 2
        • Pickettundefined
          Pickett @Nuramori
          @nuramori hello, thank you for that I actually just found that on Amazon USA that same item. Anyways on the website it says it is only for the A+ and B+ models of RPi and I have the RPi 4b but am not sure if it is the + variety though it also notes that:
          Cable is 6" long, and pin #1 is marked with a white wire. This cable is not compatible with the Raspberry Pi Model A or B - It's for the A+ and B+ only!
          Note: The Raspberry Pi Model A+, Raspberry Pi 2 and Raspberry Pi 3 are also compatible with this product!
          So anyways please do let me know what you think as I am trying to eliminate anything that could hinder my D3M5+ from talking to my RPi 4b!!!! Thanks again please do let me know thanks!!!!
          Nuramoriundefined 1 Reply Last reply Reply Quote 0
          • Nuramoriundefined
            Nuramori @Pickett
            @pickett the older pi were 26 pin connections. The newer ones (I don’t recall off hand when it changed) went to 40 pin but are backwards compatible for the first 26. The cable I linked will work for you.
