Duet Wifi 100c
Hi all,
I haven't been able to touch my printers since I moved in January so Im just getting to this.. I email DC back in January with this issue and said to bring it to the forum…
I turned my printer on one day and found the hotend temp reading 100C constantly.. it does not change... Any ideas?
Thanks!
Chad
If you unplug the thermistor from the E0 thermistor connector, does the reading change? I am assuming you are using a thermistor for temperature sensing, not a PT100 or a thermocouple.
It does not change. Its always 100c
What M305 P1 line do you have in config.g?
I do not have the board currently installed, I swapped to my Duet 0.8.5….. I can reinstall it if needed...
Thanks!
Chad -
You should be able to get get this info by just plugging in the duet to the computer and connecting to via the browser as you did before. You should still be able to read all the files off the board that way. May be simpler.
M305 P1 T100000 B4267 R4700 H0 L0
Sorry for the delay I have been away from home
