    XY Movement pauses mid movement.
    686
    • BlueDustundefined
      BlueDust
      I have been having trouble with this for awhile and just now see the issue again, not during a print and remembered to take a video. I took the video in slow motion to make it is easier to see.
      The X or Y movement stops and starts again for no reason in mid movement.
      Make sure to have your speakers on, as the audio is also helpful as you can hear the movement stop/start with the motion.
      This is a Duet2 still running on 2.05.1 software.
      The problem goes away after rebooting the printer.
      I forgot to take a M122 before I rebooted the printer to make sure the problem goes away for this post. Will try to share M122 it next time it happens. But I am hoping someone has seen this before and can just tell me what the fix is.
      I do plan to upgrade this printer to 3.x software, and if you suggest that, please tell me that your suggesting it as a troubleshooting step or if your suggesting it because you know for sure it fixes the problem.
      Also note, Z is running on a Duex5 for 3 point bed leveling and doesn't have this problem.
      Thanks!
      https://photos.app.goo.gl/ZpFB6YBzgEZ1M16f9
      Fun, that 3 letter word with "u" in the middle.
      • fcwiltundefined
        fcwilt @BlueDust
        @bluedust
        When you say "reboot" do you mean
        • cycle power
        • execute M999
        • execute M98 P"config.g"
        Thanks.
        BlueDustundefined 1 Reply Last reply Reply Quote 1
        • BlueDustundefined
          BlueDust @fcwilt
          @fcwilt
          Ahhh... yes... I should have been more specific.
          Emergency Stop.
          I generally press the Emergency Stop button as a convenient way to reboot/power cycle the printer.
          Thanks!
          • fcwiltundefined
            fcwilt @BlueDust
            @bluedust said in XY Movement pauses mid movement.:
            @fcwilt
            Emergency Stop.
            Thanks!
            I asked because they may have different effects. For instance, Cycling power versus M98 P"config.g".
            If it doesn't happen during printing and you have the option try them in this order to see which clears the problem:
            • M98 P"config.g"
            • M999
            • Cycle Power
            BlueDustundefined 1 Reply Last reply Reply Quote 0
            • BlueDustundefined
              BlueDust @fcwilt
              @fcwilt
              Thanks. I will try that next time I notice it (when it's not printing).
              It does happen during printing.
              • fcwiltundefined
                fcwilt @BlueDust
                @fcwilt
                Since hitting emergency stop clears the problem then testing after that will, of course, tell us nothing.
                • BlueDustundefined
                  BlueDust @fcwilt
                  @fcwilt
                  The first time I noticed this happening was during a print months ago. Like today, after the print finishes, I will have an opportunity to confirm it's occuring by moving the carriage 100mm again. I can then do the suggestions you mentioned. I will also try to remember to run M122 too.
                  Thanks for the help!
                    Config.g and M122 please.
                    Sometimes stuttering movement like this can be caused by having mesh compensation enabled and a low Z jerk configured. Could that be the case?
                    BlueDustundefined 2 Replies Last reply Reply Quote 0
                    • BlueDustundefined
                      BlueDust @Phaedrux
                      It happened again.
                      	m122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later + DueX5
                      Board ID: 08DGM-9T6BU-FG3S0-7JTDL-3SN6N-TS6VG
                      Used output buffers: 3 of 24 (24 max)
                      Static ram: 25712
                      Dynamic ram: 93836 of which 0 recycled
                      Exception stack ram used: 632
                      Never used ram: 10892
                      Tasks: NETWORK(ready,676) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,1300) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 10:07:57 ago, cause: power up
                      Last software reset at 2021-06-27 14:32, reason: User, spinning module GCodes, available RAM 11064 bytes (slot 0)
                      Error status: 0
                      Free file entries: 9
                      SD card longest block write time: 15.0ms, max retries 0
                      MCU temperature: min 19.5, current 35.7, max 39.3
                      Supply voltage: min 23.6, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, SG min/max 0/272
                      Driver 1: standstill, SG min/max 0/260
                      Driver 3: standstill, SG min/max 0/1023
                      Driver 5: standstill, SG min/max not available
                      Driver 6: standstill, SG min/max not available
                      Driver 7: standstill, SG min/max 0/192
                      Driver 8: standstill, SG min/max 0/153
                      Driver 9: standstill, SG min/max 0/177
                      Date/time: 2021-06-28 22:53:48
                      Slowest loop: 479.98ms; fastest: 0.07ms
                      Hiccups: 770128, FreeDm: 160, MinFreeDm: 148, MaxWait: 5990516ms
                      === DDARing ===
                      Scheduled moves: 32, completed moves: 32, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Heater 0 is on, I-accum = 0.3
                      Heater 1 is on, I-accum = 0.7
                      Segments left: 0
                      Stack records: 3 allocated, 0 in use
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 804.98ms; fastest: 0.02ms
                      HTTP sessions: 1 of 8
                      Interface state 5, link 100Mbps full duplex
                      === Filament sensors ===
                      Extruder 0: no data received
                      • BlueDustundefined
                        BlueDust
                        Submitting M98 P"config.g" to the console didn't fix it, but M999 did resolve the issue.
                        M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is enabled on port 21
                        TELNET is disabled
                        Driver 0: stall threshold 3, filter off, steps/sec 400, coolstep 0, action: none
                        Driver 1: stall threshold 3, filter off, steps/sec 400, coolstep 0, action: none
                        Driver 2: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 3: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 4: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 5: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 6: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 7: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 8: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: none
                        Driver 9: stall threshold 1, filter off, steps/sec 200, coolstep 0, action: noneDuet3D magnetic filament monitor on input 3, disabled, sensitivity 25.01mm/rev, allow 85% to 125%, check every 6.0mm, no data received
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 226C.
                        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 574C.
                          Phaedrux Moderator @BlueDust
                          Hiccups: 770128
                          That's a lot of hiccups.
                          Are you using x256 microstepping on all axis?
                          • BlueDustundefined
                            BlueDust @Phaedrux
                            @phaedrux
                            ; generated by RepRapFirmware Configuration Tool on Fri Aug 31 2018 18:58:38 GMT-0400 (Eastern Daylight Time)
                            M929 S1				; Logging Enabled
                            G90                              ; Send absolute coordinates...
                            M83                              ; ...but relative extruder moves
                            ;M555 P1                          ; Set firmware compatibility to look like RepRapFirmare
                            M555 P2                          ; Set firmware to work like Marlin, with responses after every command and needed for OctoPrint/Palette2 setup
                            M667 S1                          ; Select CoreXY mode
                            M550 P"v-Core"                    ; Set machine name
                            M552 S1                          ; Enable network
                            M586 P0 S1                       ; Enable HTTP
                            M586 P1 S1                       ; Disable FTP ENABLED
                            M586 P2 S0                       ; Disable Telnet
                            M569 P0 S0                       ; Drive 0 goes forwards
                            M569 P1 S0                       ; Drive 1 goes forwards
                            M569 P3 S1                       ; Drive 3 goes forwords
                            M569 P7 S1
                            M569 P8 S1
                            M569 P9 S1
                            M584 X0 Y1 E3 Z9:7:8 ; three Z motors connected to driver outputs 9, 7 and 8
                            M671 X6:163:315 Y-7:300:-7 S10
                            M350 X16 Y16 I1
                            M350 Z256 I0
                            M350 E16 I1                              ; Configure microstepping with interpolation
                            M915
                            M92 X160 Y160 Z12800 E813.768		;w/o Interpolation Z = pitch of 2mm w Gear 4:1 ratio
                            M591 D0 P3 C3 R85:125 E6.0 L25.01 S0 	; Magnetic Filament Sensor - currently off
                            M591 D0                       		; display filament sensor parameters for extruder drive 0
                            M566 X300 Y300 Z4 E1000		; Have ghosting, and testing lower Jerk.  Also testing lower Z jerk because of issues on Z.
                            M203 X8000 Y8000 Z1000 E1000
                            M201 X800 Y800 Z100 E3000	; Lowered this for testing because.... Have ghosting, and testing lower Jerk.  Also testing lower Z jerk because of issues on Z.
                            M906 X1200 Y1200 Z1200 E1200 I30
                            M84 S30                          ; Set idle timeout
                            M572 D0 S0.06			 ; Pressure Advance this was M572 D0 S0.08 but testing with 4
                            M208 X0 Y0 Z0 S1                 ; Set axis minima
                            M208 X305 Y296 Z245 S0           ; Set axis maxima
                            M574 X1 Y1 S3			; for stall guard
                            M574 Z1 S2                       ; Set endstops controlled by probe - Works for IR and BLTouch Probes
                            M558 P9 F100 H5 R0.2 T6000 A5 B0
                            G31 P25 X-34.5 Y-14.5 Z4.0
                            M557 X15:300 Y0:230 P10
                            M307 H0 B0 S1.00                 ; Disable bang-bang mode for the bed heater and set PWM limit
                            M305 P0 T100000 B4138 C0 R4700   ; Set thermistor + ADC parameters for heater 0
                            M143 H0 S140                     ; Set temperature limit for heater 0 to 120C BED
                            M305 P1 B4725 C7.060000e-8
                            M143 H1 S280                     ; Set temperature limit for heater 1 to 280C HOTEND
                            ; BLTouch - Heaters
                            M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                            ;M307 H6 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                            M106 P0 S0.3 I0 F500 H-1         ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                            M106 P1 S1 I0 F500 H1 T45        ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            ;M106 P1 T40 H1
                            M106 P2 H100:101:102 T39:40 L0.0 ; Motherboard FAN Turns on at 38C, MAX @ 40C, L0.0 = always run @ low 0% fan
                            M563 P0 D0 H1                    ; Define tool 0
                            G10 P0 X0 Y0 Z0                  ; Set tool 0 axis offsets
                            G10 P0 R0 S0                     ; Set initial tool 0 active and standby temperatures to 0C
                            ; Automatic power saving
                            M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                            M501 ; Enables auto save of config to config-override.g
                            Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • BlueDustundefined
                              BlueDust @Phaedrux
                              @phaedrux
                              Nope. I enabled on Z a few months ago to try and fix a quality problem I have been having and haven't put it back because I didn't notice any changes (and just forgot about it).
                              But that is a good catch. I completely forgot about that being something to look at.
                              M350 X16 Y16 I1
                              M350 Z256 I0
                              M350 E16 I1
                                Z12800
                                Yeah that's a lot of steps. Do you also have mesh compensation active to make it move up and down quickly during XY movement?
                                Also do you normally run with logging enabled? Might wanna turn that off to test.
                                  M566 X300 Y300 Z4
                                  Lower Z jerk could be part of the problem, as mentioned earlier.
                                  M566 Z60
                                  M201 Z200
                                  Should be pretty safe.
                                  • BlueDustundefined
                                    BlueDust @Phaedrux
                                    @phaedrux
                                    Yes I log. I don't do it as often as I used to, but generally use it to compare print times when testing changes to prints when testing/calibrating.
                                    • BlueDustundefined
                                      BlueDust @Phaedrux
                                      @phaedrux
                                      I changed the settings. Will follow up next time I see the problem.
                                      Thanks!
                                      • BlueDustundefined
                                        BlueDust
                                        I have only been running small prints... mostly less than an hour or two and so far haven't noticed any problems, or seen anything more then 1 hiccup after a print. When I mentioned this as an issue I was completing longer prints. Saying that, I am still currently under the impression that the excessive hiccups were the problem. (or just very hopeful)
                                        Thanks!
                                        • BlueDustundefined
                                          BlueDust @BlueDust
                                          @Phaedrux
                                          Made the suggested changes and I haven't seen any more problems with random pausing.
                                          That includes changing the extruder back to x16 microstepping.
                                          Thanks!
