    Bed leveling by manual method like CR-10
    548
    • Handymanpa54undefined
      Handymanpa54
      Hello All,
      I have a CR-10s that I've highly modified. I've crossed over to Duet Wifi2 and have most things working. At this point I want to level the bed. I'm not understand how to set up coordinates of x and y so it will go to those points. If i can level the bed manually and print a Pinda holder then I can upgrade to automatic leveling.
      Mark
      jay_s_ukundefined dc42undefined cosmowaveundefined 3 Replies Last reply Reply Quote 0
        jay_s_uk @Handymanpa54
        @handymanpa54 this is the macro I use for manually levelling my ender 3
        M671 x15:250:15:250 y25:25:260:260 P0.5                             ; The location of the four bed securing screws
        ; M558 P0												; Uncomment this if you don't have a Z Probe
        G28 Z                                                               ; Home Z
        G30 P0 X15 Y25 Z-99999 ; probe near an adjusting screw              ; Front left screw
        G30 P1 X240 Y25 Z-99999 ; probe near an adjusting screw             ; Front right screw
        G30 P2 X15 Y255 Z-99999 ; probe near an adjusting screw             ; Rear left screw
        G30 P3 X240 Y255 Z-99999 S4 ; probe near an adjusting screw         ; Rear right screw
        G28 Z                                                               ; Home Z
        I do use a z probe but if you don't have one, set M558 P0 and then RRF will walk you through it.
        You'll need to adjust the M671 values to suit the location of your screws and each G30 to match
          jay_s_uk @jay_s_uk
          I should add I just have this as a macro in the macros folder
            dc42 administrators @Handymanpa54
            @handymanpa54 have you read https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant ?
            Handymanpa54undefined 1 Reply Last reply Reply Quote 0
              Or this? https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
              Handymanpa54undefined 2 Replies Last reply Reply Quote 0
              • cosmowaveundefined
                cosmowave @Handymanpa54
                @handymanpa54 I use a macro for manually leveling the bed.
                The macro moves to the 4 corners, 20mm away from max.
                ; LevelAssist macro
                ; this macro helps for manually leveling the bed, it moves the nozzle to 4 probing points (20mm away from min/max area)
                ; the macro will automatically aborted if no user action during 120s
                var EntryTime = state.upTime												; set start time
                var ReturnTime = 120														; set abort time
                if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed		; axles homed ?
                	M291 P"axles not homed! perform homing ?" R"LevelAssist" S3
                	G28																		; homing
                ; loop beginn
                while state.upTime < {var.EntryTime + var.ReturnTime}								; loop until cancel or abort time
                	M291 P"move to Point1 ?" R"LevelAssist" S3								; message
                	G0 Z4																	; Z +
                	G0 X{move.axes[0].min + 20} Y{move.axes[1].min + 20}					; move XY to Point1
                	G0 Z0																	; Z -
                	set var.EntryTime = state.upTime										; reset start time
                	M291 P"move to Point2 ?" R"LevelAssist" S3								; message
                	G0 Z4																	; Z +
                	G0 X{move.axes[0].min + 20} Y{move.axes[1].max - 20}					; move XY to Point2
                	G0 Z0																	; Z -
                	M291 P"move to Point3 ?" R"LevelAssist" S3								; message
                	G0 Z4																	; Z +
                	G0 X{move.axes[0].max - 20} Y{move.axes[1].max - 20}					; move XY to Point3
                	G0 Z0																	; Z -
                	M291 P"move to Point4 ?" R"LevelAssist" S3								; message
                	G0 Z4																	; Z +
                	G0 X{move.axes[0].max - 20} Y{move.axes[1].min + 20}					; move XY to Point4
                	G0 Z0																	; Z -
                	M291 P"once again or cancel ?" R"LevelAssist" S3						; once again?
                Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                  Handymanpa54 @dc42
                  @dc42 Hi,
                  I checked the link earlier and again. I have questions where to modify the code? In conig.g or in bed.g
                  I'll be using paper feeler method.
                    Handymanpa54 @Phaedrux
                    @phaedrux
                    I did check out that link earlier, but thought it no appropriate for me not having BL touch or Pinda or such. I was hoping to go to positionn1 and adjust thumb screw to bring the bed so there is friction on paper, then do the other corners like wise and last in the center. Pretty much like it's done on CR-10.
                      Yes if you don't have a probe and independent Z motors that won't be the best option for you.
                      The macro that @cosmowave posted is an option. Here's another:
                      https://github.com/Duet3D/RRF-machine-config-files/blob/master/DBotCoreXY/x0r-wifi-RRF3/macros/Calibration/Bed Leveling/0_Auto Bed Level Assist.g
                      Modify to suit.
                        @phaedrux I wrote a little macro that works much like the CR-10 Bed leveling.
                        ; bed.g
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 18 2021 18:18:06 GMT-0400 (Eastern Daylight Time)
                        ;G29  ; probe the bed and enable compensation
                        M671 x15:15:250:250 y25:250:250:25 P0.5
                        G1 X25 Y25 Z0 						; probe near an adjusting screw              ; Front left screw
                        G4 S20
                        G1 Z5
                        G1 X25 Y250
                        G1 Z0
                        G4 S20
                        G1 Z5
                        G1 X250 Y250
                        G1 Z0
                        G4 S20
                        G1 Z5
                        G1 X250 Y25
                        G1 Z0
                        G4 S20
                         G1 Z5
                        G1 X150 Y150
                        G1 Z0
                        G4 S20
                        G1 Z5
                        undefined
