Small UI BUG
  • undefined
    Tinchus
    Hi. I just noticed this today. THe DWC analize the loaded gcode and give this information in the JOB INFORMATION section:
    Job Information
    Height: 400.00 mm
    Layer Height: 0.20 mm
    Filament Usage: 9203.90 mm
    Height is reported as 400mm, but the print has only 9 mm tall. There is a G1 Z400 at the end of the end gcode, and the DWC is reading it as if this is part of the model. Suggestion would be that this analisys should be done TILL the end gcode, so this gcodes are not taken into account.
    undefined undefined undefined 3 Replies Last reply 1 Jul 2021, 13:41 Reply Quote 0
    • undefined
      fcwilt @Tinchus
      @tinchus said in Small UI BUG:
      Is this in the gcode file being printed?
      What generated this command?
      Thanks.
      undefined 1 Reply Last reply 2 Jul 2021, 13:52 Reply Quote 0
      • undefined
        jay_s_uk @Tinchus
        @tinchus which version of RRF and DWC are you running?
        • undefined
          cosmowave @Tinchus
          @tinchus I think you can solve the problem with putting an ";E" after the comment semi-colon, like this:
          G1 Z400 ;E drop the print bed (E to exclude from layer count)
          (Obviously, you need to be in absolute positioning mode for this to work)
          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          undefined 1 Reply Last reply 2 Jul 2021, 13:57 Reply Quote 2
          • undefined
            Tinchus @fcwilt
            @fcwilt this command is part of my custom END GCODE
            • undefined
              Tinchus @jay_s_uk
              @jay_s_uk Version 3.3.0
              • undefined
                Tinchus @cosmowave
                @cosmowave This solved "the issue". I didnt knew about the "E" command
                5 out of 7
