    Start / Stop S3D SCRIPT / G-CODE
    2.5k
    • fcwiltundefined
      fcwilt @noblebran
      @noblebran said in Start / Stop S3D SCRIPT / G-CODE:
      Config.g? You mean the main config.g?
      Yes sir.
      How can you be waiting for hotends/bed to reach temps when you cannot, as a practical matter, set them in config.g?
      noblebranundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • noblebranundefined
        noblebran @fcwilt
        @fcwilt said in Start / Stop S3D SCRIPT / G-CODE:
        Yes sir.
        It must be done in the slicer? I choose the bed and temp setting, after I slice it in S3D, it has the code in the file (part GCODE file).
        I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
        • fcwiltundefined
          fcwilt @noblebran
          No, it does not have to be done in the slicer.
          I do it using the filament handling feature in the DWC.
          I have entered in a number of different filaments that I use into the DWC.
          For each filament entered there is a special config.g file created.
          My start code is in a file named print_begin.g and is invoked from the slicer with M98 P"print_begin.g"
          In that file I have (among other things) this:
          T0							; select tool 0 so extruder commands below will work
          M703							; configure selected filament (sets bed/extruder temps, extrusion multiplier)
          ; some other unrelated commands
          M116							; wait for temps to reach set points
          That M703 command invokes the special config.g file for the currently selected filament and in that file I have any commands I want unique to that filament and in that file I set, at a minimum, the bed temp, the hotend temp and the extrusion multiplier.
          I have found this to be an effective way to set my temps and I can use different slicers easily as the start code is on the Duet, not in the slicer.
          But this is just my way. You should do it in whatever way suits you the best.
          noblebranundefined 1 Reply Last reply Reply Quote 0
            noblebran @fcwilt
            Thank you sir, I find I like to 'master' one slicer and I guess I almost put all my eggs in one basket so to speak. I will certainly take advantage of the way you are doing it but I want to get successful at printing the way I am now. I can say my load and unload macros work, ha ha... baby steps 🙂
            Again thank you for helping!
              Phaedrux Moderator @fcwilt
              Well, you can set the nozzle and have it take effect with a G10 and T0 to select the tool you can get it to heat right at boot. Whether or not you SHOULD is another matter entirely.
              fcwiltundefined 1 Reply Last reply Reply Quote 1
              • fcwiltundefined
                fcwilt @Phaedrux
                @phaedrux said in Start / Stop S3D SCRIPT / G-CODE:
                Which is why I said practical. Editing config.g just to specify different temperatures is not what I would call practical.
                But that's just me.
                  @fcwilt In that case, yes you're completely right. It's very impractical and ill advised.
                  noblebranundefined 1 Reply Last reply Reply Quote 1
                    noblebran @Phaedrux
                    @phaedrux @fcwilt
                    Thank you both!
                    • fcwiltundefined
                      fcwilt @noblebran
                      @phaedrux @fcwilt
                      Thank you both!
                      Glad to help in anyway we can.
                      And if we cannot help we will try our best not to mess things up too badly. 😉
                        noblebran @fcwilt
                        @phaedrux @fcwilt
                        Thank you both!
                        ha ha thats all I can ask for!
                        Now it is just fine tuning...
