    PID Tuning
    1.0k
    • noblebranundefined
      noblebran @jay_s_uk
      @jay_s_uk its all e3d volcano, just replaced everything with this build. Granted it is extremely warm and humid where I am right now.
      This is what I am using for the thermistor:
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      I believe that is correct?
      I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
        jay_s_uk @noblebran
        @noblebran if you're using an E3D thermistor, no
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8
        Can you confirm what you purchased?
        noblebranundefined 1 Reply Last reply Reply Quote 0
          noblebran @jay_s_uk
          @jay_s_uk
          @noblebran said in PID Tuning:
          I do not have the e3d thermistor then. It is just a regular type k thermistor. I will order a new one, but I ran it on smoothieware for years and never had an issue. odd I how I don't have a problem now, I am buying a new block that allows the use of a cartridge but the one I have now isn't big enough for a cartridge.
          Do you know of anyway to compensate or reduce the power to the cartridge to allow it to heat up less?
          The cartridge is 12v also, not sure if that matters. I would think if it is 24v (set up that way) wouldn't it burn up?
            Phaedrux Moderator @noblebran
            type k thermistor.
            Do you mean type k thermocouple?
            M307 H1 B0 R3.539 C260.4 D14.22 S1.00 V23.1
            Yikes, yes it does. It looks like you're running a 12v heater at 24v. Hence the insanely fast heat up. DO NOT DO THIS. Replace the heater with 24v immediately and don't use it until you do.
            noblebranundefined 2 Replies Last reply Reply Quote 1
              noblebran @Phaedrux
              @phaedrux
              @phaedrux said in PID Tuning:
              Okay, thank you!
                noblebran @Phaedrux
                @phaedrux
                type k thermistor.
                Can't believe I overlooked that!
