    is a delayed triggering of the filament sensor possible?
    • CR3Dundefined
      CR3D
      Hi dear community,
      I wanted to ask if someone has an idea to start an action after 50cm after triggering the filament sensor.
      The reason for this is that we installed the filament sensor on the back of the printer and we have a customer who uses very expensive metal filaments. And so we would like to use the rest of the material.
      Sure we could try to bring the sensor close to the extruder, but first I thought of a software solution 🙂
      Firmware is RRF 3.3
      Thank you in advance 🙂
      Regards Christian (CR-3D)
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      cosmowaveundefined o_lampeundefined 2 Replies Last reply Reply Quote 1
      • cosmowaveundefined
        cosmowave @CR3D
        @cr3d I don't know which macro is called when the filament out sensor triggers...
        But in that macro you can "store" the actual Extruder Value in a variable, make your math, and call another macro after 50cm of extruding.
        Eventually is daemon.g also a good option to put the code in...
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • o_lampeundefined
          o_lampe @CR3D
          @cr3d
          ...what cosmowave said.
          You can trigger your own filament-out macro with the filament sensor, which in the end toggles a different I/O pin. This pin is the 'official' filament-out pin defined in config.g
          CR3Dundefined 1 Reply Last reply Reply Quote 2
          • CR3Dundefined
            CR3D @o_lampe
            @o_lampe
            @cosmowave
            Thank you! 🙂
            Do you have a example perhabs?
            Homepage:
            www.cr-3d.de
            Facebook:
            Our Discord Server
            cosmowaveundefined 1 Reply Last reply Reply Quote 0
              cosmowave @CR3D
              @cr3d No, i have no working example at the moment. And i'm not at the machine, so no access to the object model.
              Normally when i try to write some code out of my head, then it will have some errors... 😵
              I'm specialist for coding some small mistakes. I allways need some iterations for a working code. 😇
