total number of layers issue
Duet Web Control
  • undefined
    ukwebb
    just found a slight bug in dwc 3.3.0 on duet 3 mini5+
    when my model is sliced with prusa slicer 2.3.2 it shows 80 layers
    but dwc shows 66. however it then gets to a point of doing more than the 66 layers ! ie layer 70 of 66 !
    waiting for it to finish - it did actually get to layer 80
    • undefined
      What gcode flavor are you using in prusa slicer?
      And can you share the gcode file in question?
      Are you using variable layer heights or supports with a different layer height than the main part?
      undefined 1 Reply Last reply 20 Jul 2021, 19:28 Reply Quote 0
      • undefined
        ukwebb @Phaedrux
        @phaedrux
        reprap/sprinter firmware
        I am using "Synchronize with object layers " turned off - ie not sync'd
        i did wonder if this was the reason, but it looks very odd when it starts showing now on layer 70 of 66 !
        i've made a simpler layergcode.gcode example gcode file, which has the same effect with 76 layers according to Prusa.
        undefined 1 Reply Last reply 20 Jul 2021, 19:30 Reply Quote 0
        • undefined
          jay_s_uk @ukwebb
          @ukwebb use reprapfirmware and add ;LAYER:[layer_num] to the custom gcode tab under the before layer change g-code section
          undefined 1 Reply Last reply 20 Jul 2021, 19:34 Reply Quote 0
          • undefined
            ukwebb @jay_s_uk
            @jay_s_uk said in total number of layers issue:
            ;LAYER:[layer_num]
            sorry bud - no difference
            1 out of 5
