Help with GEEETECH A30 printer
I'm having problems creating the SD card content for the GEEETECH A30 I've already used the RRF Config Tool and I'm not working anything mem the motors nor the end stops switch mem the filament detector nor fans nor the IR Probe .
Or sega I'm more than 1 month trying and I'm asking for help my DUET2 WiFi card didn't have SD card, so I'm completely lost.
I don't have much experience in tinkering with programming yet.
If you can help me, I would be very grateful. -
@luis-filipe Looking at the GEEETECH A30 information, it doesn't look like that printer uses a DUET2 board. (I'm ready to be wrong about this, I just took a quick look to see if they had any links to DUET2 configurations and I didn't find any.)
Did you replace the original controller board with a DUET2 yourself?
Can you connect to the machine using a web browser?
If so, what is working on the machine?
Can you go to the "Console" tab and type M115 and post the results here so we can see what firmware is installed?
That will be a good start.
There will be a lot more questions from people willing to help you get your machine working.
@alankilian Yes, I was the one who replaced the motherboard because I was having a lot of problems with the original one.
Yes, I can connect via RRF Duet 2 WiFi through the browser, and I can heat up the hot end and the hot bed, nothing else works.
Is someone who has managed to get the GEEETECH A30 to work with the DUET2 WiFi that shares the config.g file. -
@alankilian So here is my config.g file.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jul 14 2021 18:36:15 GMT+0100 (Hora de verão da Europa Ocidental); General preferences
M550 P"Duet 2 WiFi" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; Initialize SD card
M21 P1 ; Mount SD card number (default 0); Drives
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y320 Z420 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 ; report the process parameters for heater 0
M307 H1 A346.2 C140 D5.3 B0 S0.8 V23.8 ; set process parameters for heater 1, use PID, and limit heater 1
PWM to 80%
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S290 ; set temperature limit for heater 1 to 290C; Fans
M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M575 P1 S1 B57600 ; enable support for PanelDue -
@luis-filipe OK, that's great so far. Good work getting the board installed.
I'm not a gonfig.g expert, but everything looks good to me in there also.
Now, we'll try to get motion working.
- Type in M115 and post the results here.
- Does clicking the "Home" button do anything?
- Post your homeall.g, homex.g homey.g and homez.g files so we can take a look at them.
Here's a detailed commissioning guide for a similar cartesian printer. It's not exactly the same but it might give you an idea of what's all involved and how to test things.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
@phaedrux Thank you I will take a look
@luis-filipe Hello Luis, hello Duet users. I have the Duet3 wifi5+ board that I am now in the RRF Config Tool state. I would appreciate if someone could share the config files for the Geeetech A30 printer.
Thank you,
Catalin
