Controlling two fans at the same time
I found out that PWM is not working properly when connecting two fans in parallel to one port. I have two electronics bay fans, would like to connect them seperately to two ports but it would be very nice if I still can control them parellel. Is that anyhow possible?
Thx.
@martinnyhc
Yes....Find it in the example
https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_toolEdit:
Maybe I misunderstood you, the example is for 2 fans on the printhead -
In my case the fans are tool independent because they are for the electronics bay.
One possibility would be to do this with conditional GCode.
Another would be to use fans that loop through the PWM signal.
Search for PWM Sharing (PST)
In the PC I have some from Arctic . -
What about them doesn't work? The usable frequency range may be reduced, but it should still work. Unless the fans are particularly picky.
I use 2 sunon 40mm fans in parallel for my electronics enclosure with this setup and it works ok.
M950 F2 C"fan2" Q15000 ; create fan 2 on pin fan2 and set its frequency M106 P2 S0.33 H1:0 T45 B0.5 ; set fan 2 value. Thermostatic control is turned on
@martinnyhc said in Controlling two fans at the same time:
Thx.
2-wire fans are not designed to work with PWM. It's a miracle that so many of them do.
If you connect two dissimilar fans in parallel, then I am not surprised of they behave oddly when you PWM them. But if they are identical fans, I would expect a parallel connection to work.
