    Z Babystepping Not Working Properly
    190
    • 3DMakerKid
      3DMakerKid last edited by
      I posted a few weeks ago here about getting sensorless homing working, which I have gotten working now. However, now, Z babystepping is not working properly. When I use .05mm babystepping, it appears to not work at all, when I tried setting it to 5mm, when I told it to babystep 5mm, it only moves about one. My steps/mm are correct, I'm not sure what could be causing this. Thanks in advance for any help!
      Here's my current config.g, let me know if you need any other files.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 30 2021 18:28:51 GMT-0400 (Eastern Daylight Time)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Hermione"                   ; set printer name
      M552 S1                                      ; enable network
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.0 S0 V20                                 ; physical drive 0.0 goes forwards
      M569 P0.1 S1 V20                                ; physical drive 0.1 goes forwards
      M569 P0.2 S0 V20                                ; physical drive 0.2 goes forwards
      M569 P0.3 S0 V20                                ; physical drive 0.3 goes forwards
      M569 P0.4 S0 V20
      M584 X0 Y1 Z2:4 E3                           ; two Z motors connected to driver outputs Z and E1
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E409.00         ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X1250.00 Y1000.00 Z120.00 E250.00          ; set accelerations (mm/s^2)
      M906 X600 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X240 Y205 Z210 S0                       ; set axis maxima
      M574 X1 S3                                   ; configure sensorless endstop for low end on X
      M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
      M915 X S3 R1 F0 ;
      M915 Y S3 R1 F0 ;
      M558 P5 C"^io2.out" H1 F1000 T6000 A3              				; Prusa PindaV2 Endstop
      M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950      		; Prusa PindaV2 Thermistor
      G31 P1000 X35.75 Y18.7 Z.2                                  				; Nozzle offset
      M574 Z1 S2                                                 			; Set Z axis endstop, controlled by probe
      M557 X35.75:204 Y18.7:200 P3                                    			; Define mesh grid for probing
      M376 H5																; Fade height 5mm
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120								 ; set temperature limit for heater 0 to 120C
       M307 H0 R0.295 C369.7 D10.32 S1.00 V23.8    ; control parameters for H0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"out5" Q500 ;
      M106 P0 C"Part Cooling" S0 H-1 ;
      M950 F1 C"out6" Q500 ;
      M106 P1 C"Hotend" S1 H1 T45 ;
      M563 P0 D0 H1 F0                           ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      ; Dual Z steppers
      M671 X 10:240 Y0:0 S1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      ; Custom settings are not defined```
      jay_s_uk o_lampe 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @3DMakerKid last edited by
        @3dmakerkid is this baby stepping beneath the build surface?
        you can't go below the Z minima you've set in the firmware, which in this case is M208 X0 Y0 Z0 S1
        Set it to Z-1 and you should be able to go lower
        3DMakerKid 1 Reply Last reply Reply Quote 0
        • o_lampe
          o_lampe @3DMakerKid last edited by
          @3dmakerkid said in Z Babystepping Not Working Properly:
          OT:
          Is the left leadscrew 10mm 'inside' the printable area? Or should it be X -10:240?
          • 3DMakerKid
            3DMakerKid @jay_s_uk last edited by
            @jay_s_uk It's happening when I try to babystep up and down, no matter what my Z position is at that time. I'll switch that and see if it helps though.
              If you need much babystepping, I have to ask, is your trigger height correct?
              • 3DMakerKid
                3DMakerKid @Phaedrux last edited by
                @phaedrux I'm starting to wonder if it is, because now the Z probe isn't even triggering during probing moves during G29.
                  A 0.2mm trigger height is pretty low. The nozzle would be just about to hit the bed. Do you have the probe mounted too high perhaps?
                  • 3DMakerKid
                    @phaedrux That could be it, I'll look into trying to fix that.
