    BLTouch question: "Alarm mode"
    • kb58undefined
      kb58
      I was messing around with bed leveling and at one point had the nozzle fairly close, due to issuing a G30 S-1 command to see what the offset was. I forgot how close it was and commanded another probe, so the BLTouch was unable to extend its probe to full length, and it started flashing red.
      No problem, I knew what caused it, but then was puzzled how to make it stop flashing. It ignored new commands, and I ended up having to cycle printer power. Is there any other way to reset it?
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @kb58
        @kb58 one for you macro list reset bltouch M280 P0 S160
        then rehome which should drop the bed 5mm or so before the probe.
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        kb58undefined 1 Reply Last reply Reply Quote 1
        • kb58undefined
          kb58 @peter247
          @peter247 Thank you sir, another one to add to the list!
            https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3/macros
            You might find some good examples in there as well.
