    Duet3 6hc malfunction?
    • Heartleander81undefined
      Heartleander81
      Today I had the problem that I had the message VSSA Vault. After that, the diagnosis LED had shone red continuously. After I had removed the thermistors and restarted it took a moment and the diagnosis led flashed as usual. Thermistors back on and everything back as before, only with V12 I only have 9.6V. is the board broken now or is there just a problem with the cables.
      M122
      === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6JTDG-3SJ6P-KB0UG
      Used output buffers: 1 of 40 (15 max)
      Static ram: 150904
      Dynamic ram: 62360 of which 76 recycled
      Never used RAM 140852, free system stack 216 words
      Tasks: SBC(ready,4.3%,349) HEAT(delaying,0.0%,350) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,342) TMC(notifyWait,0.0%,105)
      MAIN(running,95.6%,974) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:12:28 ago, cause: power up
      Last software reset at 2021-07-30 20:35, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 140852, slot 1
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000038 SP 0x2041b178 Task MAIN Freestk 1661 ok
      Stack: 00000000 00000001 00000001 00000000 00000000 0047a515 0047a16c 610f0000 00000000 0047a51f 00000000 00000000 baef53bb 0000000a d7b71d43 2042b7f0 20419728 2042d10c 00000000 00000001
      00000000 0047a1d7 2042d10c fffc0000 003fffff ffffffff ffffffff
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 751
      MCU temperature: min 39.4, current 39.7, max 39.9
      Supply voltage: min 24.8, current 24.8, max 24.9, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 9.5, current 9.6, max 9.6, under voltage events: 0
      Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Date/time: 2021-07-30 20:48:11
      Slowest loop: 1.03ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 2047, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 1137/0/0
      Tx timeouts 0,0,1137,0,0,910 last cancelled message type 4514 dest 127
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 0ms ago
      RX/TX seq numbers: 27002/27002
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0 Code buffer space: 4072
      Configured SPI speed: 8000000Hz
      Full transfers per second: 35.52, max wait times: 27.4ms/0.0ms
      Codes per second: 0.00
      Maximum length of RX/TX data transfers: 3668/816
        Heartleander81
        After I have the Accelerometer turn off from the Bord, have I 16V on the 12V side. Have anyone a tip for me?
          Can you show us your wiring? Did you perhaps short something out?
          Perhaps remove all wiring and check the board with only USB connected first and then start adding back components one at a time.
          Heartleander81undefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @Heartleander81
            @Heartleander81 after you have checked that it is working as far as expected with just USB power connected, please remove the USB power, connect just VIN power, and run M122 to see what it reports for the VIN and 12V rails.
            The driver error reports are probably caused by the 12V rail reading low. That in turn could be caused by overloading the 12V rail, for example if a device connected to an OUT port that is set for 12V output was drawing too much current.
              Heartleander81 @dc42
              @dc42 I have found the problem.
              After I have turn off my accelerometer Was 16V on 12V side. Next Day I turn on the printer and have 12V on 12V side. At Moment looks all good.
                Heartleander81 @Phaedrux
                @phaedrux thanks for your Info.
                I hope the board was not damaged by the accelerometer error.
                If necessary, I have a new Duet3 6HC board at home since yesterday as a replacement.
