Duet 3 Configuration/Wiring issues
I am working on using Duet 3 and Duet 3 extension board to my core xy printer (based off railcore II) however i am having a few issues with wiring/configuring
Issue 1: For my z endstop i have a mechanical endstop (2 pin) plugged into pin 2 and 3 of IO_3 port but it won't stop the z axis when homing.
Issue 2: How can i set up fans as always on for hot ends?
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode
M552 S1 P0.0.0.0; Drives
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M569 P1.0 S0 ; physical drive 1.0 goes forwards
M569 P1.1 S0 ; physical drive 1.1 goes forwards
M569 P1.2 S0 ; physical drive 1.2 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M584 X0.5 Y0.4 Z1.0:1.1:1.2 E0.2:0.1:0.0 C0.3 ; set drive mapping
M350 1 I0 ; configure microstepping without interpolation
M350 X16 Y16 Z16:16:16 E16:16:16 I1 ; configure microstepping with interpolation
M92 X100 Y100 Z3205:3205:3205 E405:405:405 C100 ; set steps per mm
M566 X1000 Y1000 Z100100 E1500:1500:1500 C2 ; set maximum instantaneous speed changes (mm/min)
M203 X24000 Y24000 Z900:900:900 E3600:3600:3600 C5000 ; set maximum speeds (mm/min)
M201 X3000 Y3000 Z100100 E1500:1500:1500 C400 ; set accelerations (mm/s^2)
M906 X1400 Y1400 Z900:900:900 E1000:1000:1000 C400 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout;Stall Detection - Used for homing
M915 C S5 F0 H200 ; Coupler
M915 X Y S5 F0 H400 ; X / Y Axes;Leadscrew locations
M671 X-43.9:-48.23:304 Y5:262:140 S25 ;Front left, Rear Left, Right S7.5 is the max correction; Axis Limits
M208 X-15 Y-20 Z0.5 S1 ; set axis minima
M208 X310 Y310 Z700 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P8 C"^io3.in" X0 Y0 Z1 H5 F100 T3000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X5:275 Y5:290 S15 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S300 ; set temperature limit for heater 2 to 300C
M308 S3 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 3 as thermistor on pin temp3
M950 H3 C"out3" T3 ; create nozzle heater output on out3 and map it to sensor 3
M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H3 S300 ; set temperature limit for heater 3 to 300C; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M106 P0 C"HotEnd0Always" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 C"HotEnd1Always" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
M106 P2 C"HotEnd2Always" S1 H-1 ; set fan 2 name and value. Thermostatic control is turned off
M950 F3 C"1.out6" Q500 ; create fan 3 on pin 1.out6 and set its frequency
M106 P3 C"HotEnd0Temp" S0 H1 T45 ; set fan 3 name and value. Thermostatic control is turned on
M950 F4 C"1.out7" Q500 ; create fan 4 on pin 1.out7 and set its frequency
M106 P4 C"HotEnd1Temp" S0 H2 T45 ; set fan 4 name and value. Thermostatic control is turned on
M950 F5 C"1.out8" Q500 ; create fan 5 on pin 1.out8 and set its frequency
M106 P5 C"HotEnd2Temp" S0 H3 T45 ; set fan 5 name and value. Thermostatic control is turned on; Tools
M563 P0 S"HotEnd0" D2 H1 F0 ; define tool 0
G10 P0 X0 Y0 Z-6.3 ; set tool 0 axis offsets
M563 P1 S"HotEnd1" D3 H2 F1 ; define tool 1
G10 P1 X0 Y0 Z-6.12 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
M563 P2 S"HotEnd2" D4 H3 F2 ; define tool 2
G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C; Custom settings are not defined
M575 P1 S1 B57600 ; enable support for PanelDue -
@ddunn If you're using a microswitch as a Z endstop I think it should be
M574 Z1 S1
Z1 because it's at the low end assuming it probes for Z0
S1 because it's a microswitch not an actual Z probe(not 100% on this one though)If your endstops are wired as NC(which they should be) I don't think you need to invert(^) i03.in
@ddunn said in Duet 3 Configuration/Wiring issues:
I don't understand why this keeps showing up.
From the docs for M574 for firmware v3:
The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. The only printers known that do this using Duet electronics are the RepRapPro Ormerod, Huxley Duo, and Mendel Tricolour machines. When using the Z probe to home Z, M574 Z has no bearing on the probe setup or usage. A Z probe and a Z endstop can both be configured at the same time. G30 calling the probe setup with M558, and G1 H1 Z moves calling the endstop configured with M574 Z.
Are you trying to home Z with a G1 H1 command or a G30 command?
When asking questions regarding homing you should post your homing files - please use the </> tag when you post files.
@dhusolo
I should have mentioned this is about the 30th modification that i made to try to figure it out on my own that is why i had z2 s2. I tried z1 s1 before , i did it again to make sure still but allas it is still not working. -
M106 P5 C"HotEnd2Temp" S0 H3 T45 ; set fan 5 name and value. Thermostatic control is turned onWhich of these fans is supposed to be the hotend heatsink fan or fans?
For thermostatic fans (the ones with an H# and T#) the S value should be S1 so that the fans turn on full power when the temp is reached.
@phaedrux
i was trying to get the F0,1,2 as always on and F3,4,5 (there are 3 hot ends) to be turned on based on temperature (if i have them backwards i can move cables easily)as of right now none of them are always on. -
If you want the fans always on maybe the easiest way is to just connect them directly to the PSU voltage and ground. That would free up your PWM controllable outputs, but if you wanted the option to control them as well the config you have looks correct.
What kind of fans are you using? Do they work if they are connected directly to a power source?
@phaedrux they are just standard two pin connectors on the fans i would prefer to have them connected to the board via connector vs directly to the psu i know the fans do work as they used to be connected to duet wifi
How do you have the fans wired to the port?
What voltage are the fans?
