    Why does my Toolchange not work?
    • AS-3D Druckundefined
      AS-3D Druck
      Hey Guys,
      i've found a Toolchange Script for a 2 Extruder to 1 Hotend Solution and tweaked it a bit that it works better on my Printer. (Only a few Delays and extrusion lenght)
      If i use that gcode it don't select T1 (if we are first on T0).
      It only uses 1 Extruder.
      Here is it:
      [[language]]
      T[old_tool] ; use the current Tool
      G92E0 ; zero extrusion lenght
      G1 E-10 F2800 ; retract the filament from melting zone
      G1 X20 Y20 F3000 ;move the hotend to bed edges or corners to finish the filament swap job. normally over the prim pillar is ideal
      G4 S20 ;wait for X seconds to reduce the filament stringing
      G1 E-112 F2800 ; retract the filament cross the intersection back to the its own tube waiting for the Gcode summon. distance is depending on your hardware setup
      M400
      T[new_tool] ; use the next Tool
      G92 E0 ; zero extrusion lenght
      G1 E45 F1500 ; extrude 45mm in to the Hotend from the Splitter
      G4 S2 wait 2 Seconds
      G1 E15 F1500 ; extrude 15mm and pass the Hotend
      G4 S1 ; wait 1 Second
      G1 E62 F1500 ;extrude the new selected filament to the nozzle
      M400
      Any Idea what
      Best regards
      AS-3D Druck / Andre
        AS-3D Druck
        I got the now.
        The Toolchange needs to be sliced and cann not be executed by a Macro.
        Best regards
        AS-3D Druck / Andre
        • fmaundefined
          fma
          You can also use tpre_.g and tpost_.g (and tfree_.g) macros (where _ is the num of the tool) to execute G-Codes before a tool is selected, after it is selected, and when it is released.
          Frédéric
