    Dead SSR heatbed wont heat no more
    624
    • Dad003undefined
      Dad003
      In the last week i printed a lots working on another star war helmet , printer was working yesterday but had to stop it because of a mistake of my own , today i open it up to print again after fixing the print file lol ! . The bed wont heat up start checking wire and all with tester , seem like the SSR 40a relay failed , light show the gate as open but cannot get any voltage across , so it dead . Back to finding a better one this cheap one lasted around 6 month. I went looking at the duet wiki for suggestion couldnt find the exact model from Auber instrument but settle for these 2 :
      ended up ordering this 80A DC SSR (50V), Low On-Resistance, High Switching Speed, PWM
      https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=674
      and this one as well
      https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288
      didnt seem like they had lower AMp rated one unfortunately . That heatbed overall as always been a pain. Ive try 2-3 different model of mosfet and they always ended up failing quick or get really hot that they fail . really curious of trying that that PWM SSR hopefully it work and fix my problem and lasted for a long period of time. Cheap SSR of amazon are sketchy ....
        dc42 administrators @Dad003
        @dad003 what is the specification of the bed heater?
        Make sure that you set the PWM frequency for the bed heater low in the M950 command that sets up the output, for example use Q10 to set it to 10Hz.
          Is it an AC or DC heated bed?
          For AC, I use this one: https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=30
          For DC I have this one, but never ended up using it: https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288
          • kb58undefined
            kb58
            A few dumb questions:
            1. Is the heater LED on the main board flashing or at least lit?
            2. Have you disconnected the heater and checked continuity/resistance?
            3. What resistance was measured?
            Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
            • Dad003undefined
              Dad003
              Sorry for the late response didnt had much time lately and i got this week the new SSR from auber
              Swapped out the SSR and all is good now . it was just the cheap SSR that was causing the problem.
              Checked the config as well added "Q"parameter at the M950 for the bed heater didnt had it apaprantly
              The high switching speed allows this SSR to be operated in pulse width modulation (PWM) mode up to 2 KHz.
              Here the next question which number should be optimal for the "Q" parameter since this SSR can do a pwm of 2KHz ?
              • fcwiltundefined
                fcwilt @Dad003
                @dad003
                Assuming your bed has significant thermal mass you don't need to worry much about switching speed.
                I use Q10 on all my bed heaters which are heating 6mm of aluminum and have seen no reason to change it.
                Dad003undefined 1 Reply Last reply Reply Quote 1
                • Dad003undefined
                  Dad003 @fcwilt
                  @fcwilt okay thank you
                  giostarkundefined 1 Reply Last reply Reply Quote 0
                  • giostarkundefined
                    giostark @Dad003
                    @dad003
                    Could have sense cool it down ... also if the peak is higher just at the start of the heating. At least it will not be stressed. Maybe will last much more.
                    (ex not cooled on 12V 28A 340Watt - SSR 60A DC/DC - placed on a small aluminium bar)
                    fcwiltundefined Dad003undefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @giostark
                      @giostark
                      It's best to use a proper heatsink.
                      giostarkundefined 1 Reply Last reply Reply Quote 1
                      • giostarkundefined
                        giostark @fcwilt
                        @fcwilt
                        I solved in a old style way 😁
                        https://forum.duet3d.com/topic/24785/cooling-ssr
                        • Dad003undefined
                          Dad003 @giostark
                          @giostark it was on a aluminum heatsink , it was never hot either has well when i checked it , it was just a cheap bad quality ssr
