    Can't use emergency stop button after update
    500
    • Bennyundefined
      Benny
      The emergency stop button in web control causes wifi to turn off or something blue light just blinks.
      the only way to get it back on is to power usb, And it instantly recovers.
      Any help would be appreciated.
      cheers
      Ben
        jay_s_uk @Benny
        @benny that's normal. It resets the board
        Bennyundefined 1 Reply Last reply Reply Quote 0
        • Bennyundefined
          Benny @jay_s_uk
          @jay_s_uk It used to come back on after
            jay_s_uk @Benny
            @benny make sure you have M552 S1 in your config and it should. What board and firmware are you running?
            • Bennyundefined
              Benny @jay_s_uk
              @jay_s_uk said in Can't use emergency stop button after update:
              M552 S1
              Yea thats in there, wifi 1.4
              I've had it years now
                jay_s_uk @Benny
                @benny post and output of M115.
                Also confirm the version of WiFi firmware you are running. This can be obtained from M122
                • Bennyundefined
                  Benny @jay_s_uk
                  @jay_s_uk
                  m115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2021-06-15 21:45:03
                  m122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S86K-9AZVF
                  Used output buffers: 3 of 24 (14 max)
                  Static ram: 23876
                  Dynamic ram: 76072 of which 12 recycled
                  Never used RAM 14456, free system stack 112 words
                  Tasks: NETWORK(ready,14.2%,236) HEAT(delaying,0.0%,208) Move(notifyWait,0.2%,309) DUEX(notifyWait,0.0%,24) MAIN(running,85.3%,420) IDLE(ready,0.3%,29), total 100.0%
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:20:22 ago, cause: software
                  Last software reset at 2021-08-02 19:06, reason: User, GCodes spinning, available RAM 14456, slot 1
                  Error status: 0x10
                  Step timer max interval 0
                  MCU temperature: min 39.0, current 41.4, max 41.8
                  Supply voltage: min 24.0, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max 0/1023
                  Driver 1: position 0, standstill, SG min/max 0/1023
                  Driver 2: position 22271, standstill, SG min/max 0/107
                  Driver 3: position 0, standstill, SG min/max 0/1023
                  Driver 4: position 0, standstill, SG min/max 0/102
                  Driver 5: position 0, standstill, SG min/max not available
                  Driver 6: position 0, standstill, SG min/max not available
                  Driver 7: position 0, standstill, SG min/max not available
                  Driver 8: position 0, standstill, SG min/max not available
                  Driver 9: position 0, standstill, SG min/max not available
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2021-08-02 19:26:56
                  Slowest loop: 220.39ms; fastest: 0.07ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 1.9ms, write time 409.6ms, max retries 0
                  DMs created 83, maxWait 218101ms, bed compensation in use: mesh, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 471, completed moves 471, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 48], CDDA state -1
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === DueX ===
                  Read count 1, 0.05 reads/min
                  === Network ===
                  Slowest loop: 413.84ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.26
                    WiFi MAC address 84:f3:eb:42:b0:cb
                    WiFi Vcc 3.36, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 25600
                    WiFi IP address 192.168.50.163
                    WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
                    Clock register 00002002
                    Post your full config.g?
                    Can you verify that your DWC version is also 3.3?
                    • Bennyundefined
                      Benny @Phaedrux
                      @phaedrux yea 3.3
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 22 2020 17:33:54 GMT+0100 (British Summer Time)
                      M550 P"HevORT" ; set printer name
                      M669 K1 ; select CoreXY mode
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      ;BED LEVEL
                      M671 X-30:330 Y200:200 S6
                      M569 P0 S0 ; physical drive 0 goes forwards
                      M569 P2 S0 ; physical drive 2 goes forwards
                      M569 P4 S0
                      M569 P5 S1 ; physical drive 5 goes forwards
                      M584 X0 Y1 Z2:4 E3:5 ; set drive mapping
                      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z400.00 E397.28:419.00 ; set steps per mm
                      M566 X1500.00 Y1500.00 Z105.00 E900.00:3000.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X30000.00 Y30000.00 Z1200.00 E10000.00:18000.00 ; set maximum speeds (mm/min)
                      M201 X9000.00 Y9000.00 Z120.00 E4000.00:2000.00 ; set accelerations (mm/s^2)
                      M906 X1200 Y1200 Z1000 E1100:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                      ;M593 F34.2
                      M84 S30 ; Set idle timeout
                      ;M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
                      ;M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
                      ;M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
                      ;M906 X1800 Y1800 Z1330 I30 ; Idle motion motors to 30%
                      M208 X-30 Y0 Z-5 S1 ; set axis minima
                      M208 X280 Y280 Z300 S0 ; set axis maxima
                      M574 X1 S3 ; configure sensorless endstop for low end on X
                      M574 Y1 S3 ; configure sensorless endstop for low end on Y
                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                      M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T10000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P25 X60 Y-10 Z2.45 ; set Z probe trigger value, offset and trigger height
                      M557 X80:280 Y20:280 S60 ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0
                      M143 H0 S140 ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                      M143 H1 S280
                      M563 P0 S"BMG" D0 H1 F0 ; define tool 0
                      M563 P1 S"TITAN" D1 H1 F0 ; define tool 1
                      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                      T0 ; select first tool
                      M564 H0
                        You say "after update" What firmware version were you using before?
                        You say when you connect USB power that the module instantly connects. What LEDs are lit before and after connecting USB?
                        Do you have multiple access points saved? Check with M587 by itself to see a list of added APs.
                        • Bennyundefined
                          Benny @Phaedrux
                          @phaedrux 3.2 i think , blue red and green.
                          yes Ive got multiple AP's on there.
                            Phaedrux Moderator @Benny
                            @benny said in Can't use emergency stop button after update:
                            I would suggest removing all APs except the one you want it to connect to since it may be trying to connect to a different one that isn't actually able to connect for some reason. It tries to prioritize the AP with the highest signal strength.
