    Solved Mini 5+ Eth./Win10/can't connect to DWC
    Using Duet Controllers
    • Yurk_12
      Yurk_12 last edited by
      I'm failing at Step 11 of the Getting Connected doc.
      Config
      Duet 3 Mini 5+ Ethernet freshly received, first time trying.
      Windows 10
      Board connected and powered by USB computer port
      Ethernet cable connected to computer directly: tried both normal and crossover cables
      Firmware 3.2.2 (I could not update the firmware in step #7 because it needs access to DWC)
      The green and yellow network LEDs on the board are ON. The green one sometimes blinks.
      Problem
      In YAT I have:
      M552 S0
      Network stopped
      ok
      M552 S1 P120.20.20.20
      ok
      Ethernet running, IP address = 120.20.20.20
      M552
      Ethernet is enabled, configured IP address: 120.20.20.20, actual IP address: 120.20.20.20
      ok
      Putting the IP in Chrome does not work. Going to duettest.local does not work either.
      Below is the diagnostics M122. Am I doing something wrong?
      Thanks for any help
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: 5DNBA-B296U-D65J0-40KM6-2503Z-HSDTT
      Used output buffers: 1 of 40 (15 max)
      Static ram: 98732
      Dynamic ram: 101112 of which 404 recycled
      Never used RAM 44968, free system stack 124 words
      Tasks: NETWORK(ready,454) ETHERNET(blocked,652) HEAT(blocked,362) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,362) TMC(blocked,123) MAIN(running,400) IDLE(ready,20) AIN(blocked,260)
      Owned mutexes: USB(MAIN)
      Last reset 00:33:15 ago, cause: power up
      Last software reset time unknown, reason: HardFault bfarValid precise, GCodes spinning, available RAM 44968, slot 0
      Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000040 SP 0x2000a7e0 Task MAIN Freestk 779 ok
      Stack: 00000000 00000571 0000056d 00000000 ffffffff 000664e9 000781ca 61010000 00000000 ffffffff 2001c8dc 20009b54 2001c6d8 2000a850 000914f0 200095b4 2000a8ec 0007dca3 00000001 2000a850 20000008 0007b369 0008bd6c 0006d049 20028928 20000008 20000008
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Supply voltage: min 0.9, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Cache data hit count 3907942329
      Slowest loop: 4.47ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.45ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      Socket states: 2 2 2 2 2 0 0 0
      === CAN ===
      Messages queued 8774, send timeouts 8774, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
      ok
        Phaedrux Moderator @Yurk_12 last edited by
        @yurk_12 said in Mini 5+ Eth./Win10/can't connect to DWC:
        And what IP address does your computer have? Is it in the same subnet as 120.20.20.x?
        Updating the firmware on the mini5 is a bit different over USB.
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
        Yurk_12 1 Reply Last reply Reply Quote 1
        • Yurk_12
          Yurk_12 @Phaedrux last edited by
          @phaedrux
          Oh, it was not in the same subnet indeed.
          Autoconfiguration IPv4 Address. . : 169.254.163.65
          I changed the IP of the board as follows:
          M552 S0
          Network stopped
          ok
          M552 S1 P169.254.163.66
          ok
          Ethernet running, IP address = 169.254.163.66
          M552
          Ethernet is enabled, configured IP address: 169.254.163.66, actual IP address: 169.254.163.66
          ok
          and now it works:
          Oh great, thanks, I had missed it.
          Thanks a lot for your help
