    Check hotend FAN RPM
    Gcode meta commands
    378
    • PetrKroupa
      PetrKroupa last edited by
      I have hotend fan conected to 1LC tool board. It is noctua 3 wire fan. I configure tacho input and see around 4000 rpm. No problem. Is there way to pause/stop print when fan is stoped/slow down to some rpm? Or run some macro when this happend...
      Many thanks.
      BigOne:Duet3 6HC +1LC + Rpi4, mosquito hotend, 400x400x420
      SmallOne : Duet3 6HC +1LC + Rpi4, mosquito hotend, 210x250x210
      Petr
      cosmowave 1 Reply Last reply Reply Quote 0
      • cosmowave
        cosmowave @PetrKroupa last edited by
        @petrkroupa You can check the rpm in daemon.g
        Mankati FSXT+, DeltaTowerV2, CBot3D
        • tecno
          tecno last edited by
          Why bother with more than 2 wires and full speed as you need the air flow.
          My noctua starts at 45°C
          PetrKroupa 1 Reply Last reply Reply Quote 1
          • PetrKroupa
            PetrKroupa @tecno last edited by
            @tecno - Mine also starts at 45 degrees. Basically, you're right. That is, provided that everything works. The moment the fan is broken or blocked by some dirt, you have a problem. I wouldn't start dealing with it until it happened to me. For example, PRŮŠA checks both fans.
            Petr
            cosmowave 1 Reply Last reply Reply Quote 1
            • cosmowave
              @petrkroupa like i said.
              Create the deamon.g file in sys folder. Check there your rpm from object model.
              Note: deamon.g will run every 10sec, so your check can be delayed 10sec. But i think, this should not be a problem...
              PetrKroupa dc42 3 Replies Last reply Reply Quote 1
              • PetrKroupa
                PetrKroupa @cosmowave last edited by
                @cosmowave - OK, thanks. I will try.
                Petr
                • PetrKroupa
                  @cosmowave - I can not find "fans" or RPM in objects. Do you please have some link with right sintax. Many thanks.
                  Petr
                  • cosmowave
                    @petrkroupa I think the rpm is somewhere in the "sensors"
                    i'm not at the machine now...
                      dc42 administrators @cosmowave last edited by dc42
                      @cosmowave said in Check hotend FAN RPM:
                      If you want it to run more frequently, use a while-loop in daemon.g - but include a G4 delay command (e.g. G4 S2 to delay two seconds) within the loop, to prevent it using too much CPU time.
                      • PetrKroupa
                        I tried to find the right object but I was not successful. Please send where to look. Thanks
                        Petr
                          dc42 administrators @PetrKroupa last edited by
                          @petrkroupa it's fans[N].rpm where N is the fan number.
                          • PetrKroupa
                            PetrKroupa @dc42 last edited by
                            @dc42 - Many thanks! I will put here whole code when it works.
                            Petr
                            • PetrKroupa
                              PetrKroupa last edited by PetrKroupa
                              It can definitely be improved a lot, but it is enough for the basic function. Thanks to everyone for the help.
                              daemon.g
                              G4 S1
                              if heat.heaters[1].current > 55	&&	heat.heaters[1].current < 1000	; hotend temp more than 55c ?
                              		; hotend temp more than 55c ?, termostacic fan set to 45c (fan have time to start spin)
                              	if fans[1].rpm < 500.0 				; hotend fan spining faster than 500rpm?
                              		M150 R128						; Neopixel red!
                              		M104 S0							; set hotend temp to 0c
                              		M291 P"Hotend fan error!!!"  S1
                              		M98 P"pause.g"					; run pause.g
                              	else
                              		;M150 U128						; Neopixel green
                              else
                              G4 S1
                              Petr
