Spindle not showing in DWC-CNC RRF3 on Duet WiFi
CNC
spindle control m950 web control tool cnc speed control setup cnc setup duet wifi
2.4k
  • undefined
    Wurke
    I am setting up a new CNC machine with a fresh install of RRF3.3, DWC-CNC07 on a Duet WiFi.
    I have used the reprap config to get all the basic system files in place and added the following at the top of the config.g file for the spindle support and to put it into CNC mode.
    M950 R0 C"exp.13” Q2000 L0:22000 ; Create spindle index 0, PWM frequency 2KHz,
    ; Lmin:max rpm ranges from 0rpm at PWM=0% to 22000rpm at 100% PWM
    ; spindle speed PWM pin : exp.13
    M563 P0 R0 S"Spindle" ; Create Tool 0 with Spindle 0 and call it Spindle
    T0 ; Select Tool 0 (or make sure generated by CAM)
    M453 ; CNC Mode
    DWC doesn't show the spindle in the 'spindles' section of the dashboard however. Is this normal or am I missing more configuration for the spindle? I actually plan to use the AMB FME-U 1050 DI motor so will be using a PWM to analogue converter for speed control.
    undefined undefined 2 Replies Last reply 6 Aug 2021, 17:46 Reply Quote 0
    • undefined
      dc42 administrators @Wurke
      @bonjipoo I'm not certain, but you may need to switch into CNC mode using M453 before you configure the spindle using M950.
      undefined undefined 2 Replies Last reply 6 Aug 2021, 18:33 Reply Quote 0
      • undefined
        Wurke @dc42
        @dc42 So I moved the M453 command to the top of the config.g file. The M950 and M563 come next and then the rest of the RepRap code ie General preferences, network, drives etc
        But this has not resolved the issue. I assume this is not expected behaviour? Could it be browser related? Or maybe I need to wait and see if the spindle pwm to analogue converter works as expected.
        One last mention... The board has been used before for a workbee machine. I erased the board but not sure if that erases the EPROM and any date stored on it. The SD card has been wiped and fresh reprap config files added. Could this be an issue?
        undefined 1 Reply Last reply 6 Aug 2021, 19:30 Reply Quote 0
        • undefined
          Phaedrux Moderator @Wurke
          @bonjipoo said in Spindle not showing in DWC-CNC RRF3 on Duet WiFi:
          No, as long as you've got a new firmware version flashed to the board and a compatible config.g on the SD card you're good to go.
          Have you tried moving the M950 and M563 to the bottom of config.g yet?
          • undefined
            cjm @Wurke
            @Wurke If you're using the preview version of the excellent "CNC optimised DWC" then I believe this is a known issue and @Sindarius plans to resolve it in a future release:
            @sindarius said in Preview version of CNC optimized DWC.:
            @cjm The structure of the spindle in the object model has changed so I will be making some adjustments to fix it.
            • undefined
              Wurke
              @phaedrux I haven't tried this but will. Also not sure why I have R0 parameter in the M950? Cant see that that is actually a valid parameter? Could be this.
              undefined undefined 2 Replies Last reply 6 Aug 2021, 19:56 Reply Quote 0
              • undefined
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M950_Create_heater_fan_spindle_or_GPIO_servo_pin
                It's spindle number.
                If you send M98 P"config.g" do you get any error messages back?
                undefined 1 Reply Last reply 6 Aug 2021, 20:01 Reply Quote 0
                • undefined
                  cjm @Wurke
                  @Wurke According to the Duet GCode directory, the R parameter in M950 is the spindle number, so R0 defines the spindle as spindle 0. My understanding is that this allows M563 to map the spindle to a tool and give a name to that specific spindle.
                  undefined 1 Reply Last reply 6 Aug 2021, 20:05 Reply Quote 0
                  • undefined
                    Wurke @Phaedrux
                    @phaedrux said in Spindle not showing in DWC-CNC RRF3 on Duet WiFi:
                    M98 P"config.g"
                    The reason why I couldn't R0 as a valid parameter is because I was looking at the reprap Gcode page and not the duet3d one. Lesson learnt.
                    Yes there are errors
                    M98 P"config.g"
                    Error: in file macro line 6 column 100: M950: control character in string
                    Error: unconfigured spindle
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    Tool 0 offsets: X0.000 Y0.000 Z0.000
                    Good shout. Thank you
                    • undefined
                      Wurke @cjm
                      @cjm Thank you for that. I think the quote after exp.13 is curly not straight.
                      undefined 1 Reply Last reply 6 Aug 2021, 20:08 Reply Quote 0
                      • undefined
                        cjm @Wurke
                        @Wurke Sorry about that - I pasted the code in from my CNC's config.g and then edited it using my iPad so perhaps I picked the wrong quotation mark? I've corrected my other post with this code in it.
                        • undefined
                          Wurke
                          @cjm No problem I just appreciate some help with it. Still no spindle showing up but at least when you run M98 P"config.g" there are no errors now.
                          undefined 1 Reply Last reply 6 Aug 2021, 20:21 Reply Quote 0
                          • undefined
                            cjm @Wurke
                            @Wurke I have the same issue. My spindle responds to M3/M4/M5 correctly but is not shown on DWC, although it was in a previous version.
                            Interestingly, the object model reports the spindle's state correctly (i.e. shows the selected RPM and whether it is running, stopped etc) but always reports "configured = false":
                            I suspect that DWC sees "configured = false" and then decides not to show any information in the spindle panel.
                            undefined chrishammundefined 2 Replies Last reply 6 Aug 2021, 20:25 Reply Quote 0
                            • undefined
                              Wurke @cjm
                              @cjm That sounds likely. How do I access the objects model? Is it worth adding this as an issue on the Github? It's not currently on there. Just as a reminder.
                              undefined 1 Reply Last reply 6 Aug 2021, 20:29 Reply Quote 0
                              • undefined
                                cjm @Wurke
                                @Wurke Its available under the Settings menu item in DWC:
                                I've raised the issue with @sindarius who generated the CNC version of DWC and understand he's working on a fix.
                                However, it's not entirely clear to me whether the root cause for the issue lies with DWC or the Duet firmware so perhaps worth raising on the Github.
                                • undefined
                                  Wurke
                                  @cjm odd. I don't have object model in the side bar.
                                  undefined 1 Reply Last reply 6 Aug 2021, 20:32 Reply Quote 0
                                  • undefined
                                    cjm @Wurke
                                    @Wurke Maybe we're using different versions of DWC ?
                                    undefined 1 Reply Last reply 6 Aug 2021, 20:33 Reply Quote 0
                                    • undefined
                                      Wurke @cjm
                                      @cjm mine shows as Duet Web Control 3.3.0-CNC07
                                      • undefined
                                        cjm @Wurke
                                        @Wurke Interesting, so does mine...
                                        undefined 1 Reply Last reply 6 Aug 2021, 20:42 Reply Quote 0
                                        • undefined
                                          cjm @cjm
                                          @cjm I've just noticed that the CNC version of DWC has been merged into the latest "mainstream" DWC beta [Duet Web Control 3.4-b2] and have loaded this, but the spindle is still invisible.
                                          I can see the object model menu in this new version so perhaps worth your trying this?
                                          undefined 1 Reply Last reply 6 Aug 2021, 21:03 Reply Quote 0
                                          1 out of 35
