    Spindle not showing in DWC-CNC RRF3 on Duet WiFi
    CNC
    spindle control m950 web control tool cnc speed control setup cnc setup duet wifi
    2.5k
    • cjmundefined
      cjm @Wurke
      @Wurke According to the Duet GCode directory, the R parameter in M950 is the spindle number, so R0 defines the spindle as spindle 0. My understanding is that this allows M563 to map the spindle to a tool and give a name to that specific spindle.
      Wurkeundefined 1 Reply Last reply Reply Quote 0
      • Wurkeundefined
        Wurke @Phaedrux
        @phaedrux said in Spindle not showing in DWC-CNC RRF3 on Duet WiFi:
        M98 P"config.g"
        The reason why I couldn't R0 as a valid parameter is because I was looking at the reprap Gcode page and not the duet3d one. Lesson learnt.
        Yes there are errors
        M98 P"config.g"
        Error: in file macro line 6 column 100: M950: control character in string
        Error: unconfigured spindle
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Tool 0 offsets: X0.000 Y0.000 Z0.000
        Good shout. Thank you
        • Wurkeundefined
          Wurke @cjm
          @cjm Thank you for that. I think the quote after exp.13 is curly not straight.
          cjmundefined 1 Reply Last reply Reply Quote 0
          • cjmundefined
            cjm @Wurke
            @Wurke Sorry about that - I pasted the code in from my CNC's config.g and then edited it using my iPad so perhaps I picked the wrong quotation mark? I've corrected my other post with this code in it.
            • Wurkeundefined
              Wurke
              @cjm No problem I just appreciate some help with it. Still no spindle showing up but at least when you run M98 P"config.g" there are no errors now.
              • cjmundefined
                cjm @Wurke
                @Wurke I have the same issue. My spindle responds to M3/M4/M5 correctly but is not shown on DWC, although it was in a previous version.
                Interestingly, the object model reports the spindle's state correctly (i.e. shows the selected RPM and whether it is running, stopped etc) but always reports "configured = false":
                I suspect that DWC sees "configured = false" and then decides not to show any information in the spindle panel.
                Wurkeundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                • Wurkeundefined
                  Wurke @cjm
                  @cjm That sounds likely. How do I access the objects model? Is it worth adding this as an issue on the Github? It's not currently on there. Just as a reminder.
                  • cjmundefined
                    cjm @Wurke
                    @Wurke Its available under the Settings menu item in DWC:
                    I've raised the issue with @sindarius who generated the CNC version of DWC and understand he's working on a fix.
                    However, it's not entirely clear to me whether the root cause for the issue lies with DWC or the Duet firmware so perhaps worth raising on the Github.
                    • Wurkeundefined
                      Wurke
                      @cjm odd. I don't have object model in the side bar.
                      • cjmundefined
                        cjm @Wurke
                        @Wurke Maybe we're using different versions of DWC ?
                        • Wurkeundefined
                          Wurke @cjm
                          @cjm mine shows as Duet Web Control 3.3.0-CNC07
                          • cjmundefined
                            cjm @Wurke
                            @Wurke Interesting, so does mine...
                            • cjmundefined
                              cjm @cjm
                              @cjm I've just noticed that the CNC version of DWC has been merged into the latest "mainstream" DWC beta [Duet Web Control 3.4-b2] and have loaded this, but the spindle is still invisible.
                              I can see the object model menu in this new version so perhaps worth your trying this?
                              • cjmundefined
                                cjm @dc42
                                @dc42 I've tried placing M453 before and after the spindle configuration but the spindle is still not shown in DWC.
                                Although my spindle appears to be configured correctly in that it responds properly to M3/M4/M5 and the object model shows the RPM and spindle state , I note that the object model always reports spindle "configuration = false".
                                Could it be that this is why DWC doesn't display the spindle state on the Dashboard?
                                • Wurkeundefined
                                  Wurke @cjm
                                  @cjm Updated that. Still nothing. So frustrating. Its probably all working but the UI is letting everything down.
                                  • cjmundefined
                                    cjm @Wurke
                                    @Wurke I believe that to show the object model, you need to enable the "Object Model Browser". This is found under the "Integrated Plugins" section of the General Settings page:
                                    • Wurkeundefined
                                      Wurke
                                      @cjm I almost asked if it was a plugin. Got it. I can now see that under spindle I have the same as you. configured = false. The other values match my config.g
                                      R4ffersundefined 1 Reply Last reply Reply Quote -1
                                      • R4ffersundefined
                                        R4ffers @Wurke
                                        @bonjipoo evening guys, mine also shows the same under the object model. I do have a spindle section under the DRO section in the UI but doesn't show any info.
                                        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                                        • chrishammundefined
                                          chrishamm administrators @cjm
                                          @cjm @Sindarius spindle.configured is a left-over property from an earlier RRF version and it has been replaced with state -> unconfigured. I'll make sure it will be removed from the next DWC version.
                                          Duet software engineer
                                          Sindariusundefined 1 Reply Last reply Reply Quote 0
                                          • Sindariusundefined
                                            Sindarius @chrishamm
                                            There is a new version of the DWC-CNC with an updated spindle panel
                                            https://github.com/Duet3D/DWC-CNC/releases/tag/3.3.0-CNC08
                                            Future updates will be done on the main Duet Web Control
                                            cjmundefined R4ffersundefined Wurkeundefined 4 Replies Last reply Reply Quote 2
