    BL TOUCH ONLY DEPLOYS WHEN I USE THE DEPLOY/RETRACT MACROS...
    Accessories and Add-ons
    467
    • dakingofhearts2003undefined
      dakingofhearts2003
      BL TOUCH WORKS WHEN I USE THE MACROS BUT WHEN HOMING Z OR TRYING TO SEND G30 COMMANDS IT SAYS "Z PROBE WAS NOT TRIGGERED..
      config.g homeall.g homez.g
        Please post the results of sending M122 and M98 P"config.g" in the gcode console.
        Does M401 and M402 work to deploy and retract the probe?
        Post the contents of your deployprobe.g and retractprobe.g files and confirm that they are located in the /sys folder and not the /macros folder.
        Please fix your caps lock key before posting again.
        dakingofhearts2003undefined 3 Replies Last reply Reply Quote 0
          dakingofhearts2003 @Phaedrux
          @phaedrux said in BL TOUCH ONLY DEPLOYS WHEN I USE THE DEPLOY/RETRACT MACROS...:
          M122
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS0-6J1FJ-3S46M-KSTRP
          Used output buffers: 3 of 24 (10 max)
          Static ram: 23460
          Dynamic ram: 73420 of which 48 recycled
          Never used RAM 15152, free system stack 191 words
          Tasks: NETWORK(ready,162) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:41 ago, cause: software
          Last software reset at 2021-08-08 21:07, reason: User, GCodes spinning, available RAM 15116, slot 0
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 24.7, current 25.4, max 25.7
          Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-08-08 21:08:20
          Cache data hit count 48716574
          Slowest loop: 7.78ms; fastest: 0.21ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.0ms, write time 6.2ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.56ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address 98:f4:ab:d1:f0:18
            WiFi Vcc 3.39, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 25360
            WiFi IP address 192.168.0.37
            WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            M98 P"config.g"
            M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: Pin 'fan1' is not free
            Error: Fan number 2 not found
            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
              @phaedrux No, M401 and M402 dont work i have M280 in my retract and deploy folders.
              generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 14:46:02 GMT-0400 (Eastern Daylight Time)
              M280 P7 S10 ; deploy BLTouch
              M280 P7 S90 ; retract BLTouch
              • PHaveyundefined
                PHavey
                I'm not an expert so I may be wrong,
                In your config.g file, you created the BLtouch servo pin using
                M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                Note 'S0'
                In your deploy and retract files, you are calling for servo pin7
                Note 'P7'
                In the G-Code Wiki
                "RRF3: Before you can use M280 you must create a GPIO port using M950. Then in the M280 command, the P parameter is the GPIO port number, not the logical pin number. Duet 2 supports up to 10 GPIO ports, numbers 0 to 9. No GPIO ports are allocated by default."
                Try changing the P7 to P0 in both retractprobe.g and deployprobe.g files
                --Pat
                They say you learn from your mistakes.
                If that were true, I'd be a genius - Me
                Phaedruxundefined 1 Reply Last reply Reply Quote 1
                  Phaedrux Moderator @PHavey
                  @phavey said in BL TOUCH ONLY DEPLOYS WHEN I USE THE DEPLOY/RETRACT MACROS...:
                  Bingo.
                  dakingofhearts2003undefined 1 Reply Last reply Reply Quote 0
                    @phaedrux You can close this one out but i have another question about how to level the bed manually. I cant use g32 if i dont have multiple z motors can i ?
                      Phaedrux Moderator @dakingofhearts2003
                      @dakingofhearts2003 said in BL TOUCH ONLY DEPLOYS WHEN I USE THE DEPLOY/RETRACT MACROS...:
                      You can use this to make a manual adjustment assistant if you don't have independent motors and drivers.
                      https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
