    X axis will not home
    • frankfisk4undefined
      frankfisk4
      X axis will not home.
      I have a D2 WIFI.
      When I try to home X it moves 3mm in + direction and stops.
      I swapped X and Y wiring and the problem persists.
      The firmware is updated.
      The X will move a limited amount (30mm?) when using the web control.
      Any Ideas?
        jay_s_uk
        @frankfisk4 check your endstop status using M119
        frankfisk4undefined 1 Reply Last reply Reply Quote 0
          Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
          Can you post your config.g, homeall.g, homex.g, homey.g, homez.g as well?
          It sounds like your endstop may be sensed as triggered when it's not, and the move to back off the endstop is happening because it thinks it's already at the endstop.
          Checking your endstop status as jay suggests, once with the switch not pressed, and again with the switch pressed will give an idea of what's happening.
            frankfisk4 @jay_s_uk
            Thanks! Bad wire. Fixed.
