Solved M81 command RRF 3.3
Hey guys , short Question,
does anyone know what´s wrong with this message?Error: in GCode file line 194152 column 8: M81: expected number after 's'
Finished printing file 0:/gcodes/CFFFP_Copy of Diamond_Hotend_CapProx_wFan.gcode, print time was 2h 30m
In the past the automatic switch of the printer after printing with M81 command works fine.
But now anymore.So what´s wrong???
The command with Hand via display works fine. -
Hi, is there anyone who knows the cause?
@uneumann36 whats in your end gcode?
I am just at work.
So something like - set bed temp to 50 degress , if reached M81
I don´t changed settings (start and endcode) it is since a half year same.
But since 2 weeks i get this failure message.If print is ending, extruder drive home, bed temp setting goes to 50 degress, if 50 degrees is reached the failure above is coming.
@uneumann36 best of posting your end gcode.
Theres no documented changes for M81 but it doesn't hurt to check what you're sending -
Ok, here is my cura start code :
M80
G28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X5.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X5.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X5.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X5.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 E4 F300 ; Extrude 4mm of Filament
G1 Z2.0 F3000 ;Move Z Axis upAnd here the end code :
M104 S0
M140 S0
;Retract the filament
G92 E1
G1 E-1 F300
G28 X0 Y0
M84
M190 R50.000000
M81 abschalten ; Herunterfahren NetzteilHope this helps to identify my problem.
@uneumann36 said in M81 command RRF 3.3:
M81 abschalten
There's your issue. The word abschalten is before the comment indicator ;
I think gcode parsing has been improved which is why this now thrown as an error.
Remove it or move the ; to the left of it -
@jay_s_uk
Thank´s , i will try it.
But i never change the end code, and it works in the past ! -
Yeah, it works!
I do not know why it also work in the past.
Anyway, thank you !
@uneumann36 there was a change to GCode parsing. Previously, if a parameter letter was not followed by a number when a number was expected, zero was assumed. The parsing has been tightened up so that an error is flagged instead. I've added this to the upgrade notes for RRF 3.3.
Thank you DC , now i understand why this happens now !
