    Cant Connect Maestro
    Duet Web Control
    345
    • EricKindiundefined
      EricKindi
      Hello!
      For some reason, I cant connect my new Maestro board, I followed the guide with no luck.
      I know the board is ok, becase I have 2 Maestros and I have the same result with both...
      With the M115 command I have this:
      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1
      With M552:
      Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
      ok T0:2000.0 /0.0 T1:2000.0 /0.0 B:2000.0 /0.0
      The ethernet cable is working because I tested with my computer.
      I also have a Duet 2 ethernet wotking in the same network, but I think the Mac address is different.
      Mestro: MAC: be:76:48:38:53:34
      Ethernet: MAC: be:ef:de:ad:fe:ee
      I could not find anywhere in the forum the same issue.
      Thanks in advance!!
        jay_s_uk @EricKindi
        @erickindi if you're setting up as a new board, update the firmware to 3.3
        The quickest was to do this would be with bossa.
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2
        EricKindiundefined 1 Reply Last reply Reply Quote 0
          EricKindi @jay_s_uk
          @jay_s_uk Thanks for the reply! But I can connet with YAT or Pronterface, I just cant connect to the network...
            jay_s_uk @EricKindi
            @erickindi still worth upgrading.
            If you can use YAT, use fallback procedure 1 to upgrade, taking note that you should go to 2.05.1, then 3.0 and then 3.3
              EricKindi
              @jay_s_uk
              It is reporting that the "iap4s.bin" is not found, I tried renaming the "DuetMaestroIAP.bin" file to "iap4s.bin" but it still reports the same old firmware with the M115 commmand.. Is this the correct procedure? Thanks
                jay_s_uk @EricKindi
                @erickindi no. which firmware are you trying to upgrade from/to?
                still at 2.01beta1?
                  EricKindi @jay_s_uk
                  @jay_s_uk From 2.01beta1(RTOS) to 3.0
                    jay_s_uk @EricKindi
                    @erickindi i believe its this one https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetMaestroIAP.bin
                      EricKindi
                      @jay_s_uk do I have to rename to "iap4s.bin" in the sys folder? I tried both ways, and it does not update..
                      Why it is important to update to 3.0 now?
                      Thanks again
                        jay_s_uk @EricKindi
                        @erickindi sorry, i gave you the wrong one
                        go for this one https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap4s.bin
                        there have been lots of updates to improve the ethernet so its worth making sure you are running up to date firmware first
                          EricKindi
                          @jay_s_uk Thankyou so much! Now it is updated to the 3.3 firmware! (3.0 and then to 3.3).
                          But I get the same error connecting to the web control..
                          The command line I use:
                          SENDING:M552 S1 P192.168.1.158
                          Network running, IP address = 192.168.1.158
                          M552
                          SENDING:M552
                          Network is enabled, configured IP address: 192.168.1.158, actual IP address: 192.168.1.158
                          But there is nothing in the 192.168.1.158 Ip
                          If I change to 0.0.0.0 it is the same thing...
                            jay_s_uk @EricKindi
                            @erickindi what OS are you on?
                            Can you try and load the page using an incognito tab?
                            Can you also try adding the subnet mask and gateway?
                            EricKindiundefined 2 Replies Last reply Reply Quote 0
                              EricKindi @jay_s_uk
                              @jay_s_uk Im on Windows using chrome. But I am using my Duet Ethernet in my other printer with no problems.
                                EricKindi @jay_s_uk
                                @jay_s_uk Thank you so much for your help!!!
                                For some reason, when I conected to another router, it worked!!
