    need help xand y wont move when homed but z does
    330
    • kevinlallshouseundefined
      kevinlallshouse
      config.json
      x and y will not home onle z axis moves when you home all axis please help on a 300x300x400 cartesian.
        Can you post your config.g, homeall.g, homez.g, etc?
        Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
          kevinlallshouse
          wont let me upload anything telling me its flaged as spam by askmet.com im lost?
            Try copy and paste the text into a post after waiting a few minutes.
              kevinlallshouse
              config.g homeall.g homez.g homey.g homex.g resume.g pause.g tpre0.g tpost0.g tfree0.g stop.g sleep.g bed.g config.g
              kevinlallshouseundefined 1 Reply Last reply Reply Quote 0
                kevinlallshouse @kevinlallshouse
                M122
                8/10/2021, 1:35:48 PM	M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID: 0JD0M-9K662-MGPSS-6J9DL-3S46R-1SUYY
                Used output buffers: 3 of 24 (7 max)
                Static ram: 25712
                Dynamic ram: 93140 of which 0 recycled
                Exception stack ram used: 272
                Never used ram: 11948
                Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:11:09 ago, cause: software
                Last software reset at 2021-08-10 13:24, reason: User, spinning module GCodes, available RAM 11772 bytes (slot 0)
                Error status: 0
                Free file entries: 10
                MCU temperature: min 36.2, current 36.6, max 36.9
                Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                Date/time: 2021-08-10 13:35:43
                Cache data hit count 2033298794
                Slowest loop: 8.26ms; fastest: 0.06ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 20.17ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is running
                WiFi firmware version 1.21
                WiFi MAC address 40:f5:20:0d:1d:54
                WiFi Vcc 3.42, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 11248
                WiFi IP address 192.168.0.13
                WiFi signal strength -51dBm, reconnections 0, sleep mode modem
                  Where are your endstops physically located?
                    ; generated by RepRapFirmware Configuration Tool v3.3.0 on Tue Aug 10 2021 13:34:29 GMT-0700 (Pacific Daylight Time)
                    G90                                     ; send absolute coordinates...
                    M83                                     ; ...but relative extruder moves
                    M550 P"My Printer"                      ; set printer name
                    M552 S1                                 ; enable network
                    M586 P0 S1                              ; enable HTTP
                    M586 P1 S0                              ; disable FTP
                    M586 P2 S0                              ; disable Telnet
                    M569 P0 S1                              ; physical drive 0 goes forwards
                    M569 P1 S1                              ; physical drive 1 goes forwards
                    M569 P2 S1                              ; physical drive 2 goes forwards
                    M569 P3 S0                              ; physical drive 3 goes backwards
                    M584 X0 Y1 Z2 E3                        ; set drive mapping
                    M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z960.00 E104.77       ; set steps per mm
                    M566 X1500.00 Y1500.00 Z60.00 E120.00   ; set maximum instantaneous speed changes (mm/min)
                    M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                    M906 X1500 Y1500 Z1500 E800 I30         ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                 ; Set idle timeout
                    M208 X0 Y0 Z0 S1                        ; set axis minima
                    M208 X300 Y300 Z400 S0                  ; set axis maxima
                    M574 X2 Y1 Z1 S1                        ; set active high endstops
                    M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
                    M557 X15:215 Y15:195 S20                ; define mesh grid
                    M307 H0 B0 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
                    M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
                    M143 H0 S120                            ; set temperature limit for heater 0 to 120C
                    M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
                    M143 H1 S280                            ; set temperature limit for heater 1 to 280C
                    M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 F0                        ; define tool 0
                    G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                    G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                    M501                                    ; load saved parameters from non-volatile memory
                    ; homeall.g
                    ; called to home all axes
                    G91                    ; relative positioning
                    G1 H2 Z5 F6000         ; lift Z relative to current position
                    G1 H1 X305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X-5 Y5 F6000     ; go back a few mm
                    G1 H1 X305 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
                    G1 H1 Z-405 F360       ; move Z down stopping at the endstop
                    G90                    ; absolute positioning
                    G92 Z0                 ; set Z position to axis minimum (you may want to adjust this)
                    ;G91                   ; relative positioning
                    ;G1 Z5 F100            ; lift Z relative to current position
                    ;G90                   ; absolute positioning
                      kevinlallshouse @Phaedrux
                      @phaedrux x axis is left if your looking at the printer i believe neg. end of x and back for y axis so positive end and z axis is low end or neg. just basic longer lk1 Cartesian fairly new to all this and appreciate the help been at it for a week
                        If the X endstop is on the left side and Y at the back where the bed has to move back to hit it, then your homing moves and endstop definitions are not correct.
                        the homing move for both X and Y should be negative and the endstop definition should be M574 X1 Y1.
                        You may also have to change the motor rotation direction to get the correct movement.
                        -X should move left, +X should move right
                        -Y should move to the nozzle to the front of the bed, +Y to the back.
                          kevinlallshouse
                          ok so i want -x and + y how can i change this? in RepRap config?
                          sorry new to duet
                            Also, I notice you're still using firmware 2.05 which is quite old. I suggest that since you're starting fresh anyway you update to RRF3.
                            If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                            That will get your firmware and DWC up to date.
                            You can see the change logs here:
                            https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                            For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                            https://configtool.reprapfirmware.org/Start
                            Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                            These documents will come in handy during the conversion.
                            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                            https://duet3d.dozuki.com/Wiki/Gcode
                            I've taken your config.json from the first post and opened it in the config tool and switched it to RRF3 and made some corrections.
                            configforyou.json
                            config.zip.txt
                            You can either open the configforyou.json file in the tool to take a look and export the files again, or download the config.zip.txt file, change the extension back to .zip and extract it for the same files.
                              Phaedrux Moderator @kevinlallshouse
                              @kevinlallshouse said in need help xand y wont move when homed but z does:
                              sorry new to duet
                              No, you want -x and -y. Don't think of the bed moving back or forth, think of the nozzle position on the bed. 0,0 is in the front left corner of the bed. So to move the nozzle to 0,0 the bed has to move back.
                                kevinlallshouse
                                oh ok i see what your saying and thank you so much for all the help i cant tell ou how much it means i been trying to get it right for a week. ill post how it goes and thanks again
