    Duet 2 with Duex 5, cannot get BLtouch to function
    753
    • Macgyverundefined
      Macgyver
      Hi Everyone and thanks in advance for the help.
      Doing a from scratch enclosed machine and want to eventually use the 4 point bed levelling offered while using the Duex 5.
      have an issue with the BLtouch, Originally I plugged it into the 4 pin header next to the LCD, and put the ground from the Zprobe to pin 2 of the panel Duo connector. in this configuration the pin would deploy and stow twice on startup but would not get any blue light at all.
      Originally, I thought it may be a wiring issue, but I think I may have a pin assignment wrong somewhere. I am ok with moving the BLtouch over to a PWM channel on the Duex not sure what may be easier at this point.
      I eventually want to add a heated chamber to the printer so I at least what to keep a heater channel or 2 available for future expansion.
      Maybe a suggestion from you guys with more experience as to the best place for the BLtouch?
      when I tried to run a BLtouch test I was getting an error of (the P option in the M42 command is too high) I changed the P option to , error went away but no probe on the BL. Again I still think this is original wiring issue. I you need a pic o the wiring just let me know.
      BLtouch macro is here:
      M291 S3 R"BL-Touch self-test" P"The BL-Touches pin will be deployed and retracted ten times - Press OK to continue"
      M280 P7 S60 I1
      ;M280 P3 S60 I1
      M42 P8 S100 ; Turn on LED
      ;M42 P22 S100
      G4 S1
      M280 P7 S120 I1
      ;M280 P3 S120 I1
      G4 S9
      M291 R"Thank you" P"BL-Touch self-test has been accomplished" T46
      I am going to paste my configuration below, I think I may have made a mess of it.
      M569 P0 S0 ; physical drive 0 goes backward (Y)
      M569 P1 S1 ; physical drive 1 goes forwards (Y)
      M569 P2 S0 ; physical drive 2 goes forwards (X)
      M569 P3 S1 ; physical drive 3 goes forwards (E0)
      M569 P4 S1 ; Physical Drive 4 goes Forwards (E1)
      M569 P5 S1 ; Physical Drive 5 goes forward (Z-LR)
      M569 P6 S1 ; Physical Drive 6 goes forward (Z-LF)
      M569 P7 S1 ; Physical Drive 7 goes forward (Z-LF)
      M569 P8 S1 ; Physical Drive 8 goes forward (Z-LF)
      M584 X2 Y0:1 Z5:6:7:8 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S180 ; Set idle timeout
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X5 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:485 Y15:485 S20 ; define mesh grid
        jay_s_uk @Macgyver
        @macgyver said in Duet 2 with Duex 5, cannot get BLtouch to function:
        you're setting the servo as servo 0 in M950
        but in M280 you're using servo 7 (P7).
        You should be using P0
        • Macgyverundefined
          Macgyver
          HI Jay
          THanks for the reply. I've updated the test Macro file as below
          M280 P0 S60 I1
          ;M280 P3 S60 I1
          ;M42 P22 S100
          G4 S1
          M280 P0 S120 I1
          ;M280 P3 S120 I1
          G4 S9
          I'm still not getting the blue light to come on when the machine is booted, therefore no pin is being deployed when I attempt to home Z.
          when I run the BLTouch test macro its tells me it's running but it actually does not. That tells me that there is a pin assigned just not the right one to trigger the probe.
          My Wiring is as follows: in the Z probe header on the Duet 2, Pin closest to the Panel Due header heading away from it, THis is a true Antlabs BLtouch, White, Brown, Yellow, Red. The Black wire is again on the gnd (2) of the conn_SD header. Maybe I have a wire messed up?
            jay_s_uk @Macgyver
            @macgyver can you post a photo of your wiring?
            Macgyverundefined 1 Reply Last reply Reply Quote 0
            • Macgyverundefined
              Macgyver @jay_s_uk
              @jay_s_uk
              HI Jay
              Absolutely Pic is attached
                jay_s_uk
                @macgyver ok, you're wiring doesn't look correct to me. I suggest you read through this link
                https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_2_WiFi_Ethernet_with_Duex_2_Duex_5_or_Expansion_Breakout_Board
                • Macgyverundefined
                  Macgyver @jay_s_uk
                  HI @jay_s_uk
                  I was suspecting that I was considering moving the 3 wires over to the PWM5 on the Deux. what I am unsure of is how do I tell the firmware that's where the BLtouch probe is located? is there a pins diagram somewhere to tell me the pin number?
                  I'm used to building marlin firmware and there is just something I'm missing in this translation to Duet.
                  I guess the question now becomes, Currently I have my config.g Its setup and S0 or pin0, how do I find out the pin number for PWM5 so I can update the S0?
                  Maybe I am missing something, Do I change the Duex.pwm1 to Duex.pwm5 to reallocate the pin. Then I lease S0 alone? sorry just losing something in firmware translation.
                    Here are your pin names.
                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                    And here is the Duex wiring diagram
                    https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
                    Duex.pwm5
                    Would be correct if you want to use the PWM5 port on the duex.
                    M950 S0 C"duex.pwm5"
                    All else would stay the same.
                    Also make sure your deployprobe.g and retractprobe.g files have the correct M280 P0 commands to deploy and retract, and make sure those files are in the /sys folder. Test with M401 and M402 before trying to do a G30.
                    See here for further guidance on safely testing the probe.
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    • Macgyverundefined
                      Macgyver @Phaedrux
                      HI @phaedrux
                      so just to make sure that I understand, the P0 ref is just a arbraturary number that you assign to PWM5 by ref both in the same M950 command?
                      Similar in Marlin to making a ref call to the pins file, but instead of pins you call the Duex.pwm5 file?
                      instead of just fixing it trying to understand where the call is coming from that's all.
                      I think this is correct?
                        Phaedrux Moderator @Macgyver
                        @macgyver basically. M950 S0 creates servo pin 0. It's an index number. You can have many servo pins. S1 S2 S3 etc. And each one has a physical pin assigned to it. In this case duex.pwm5.
                        And when you want to target that servo pin you target the index number in your servo movement command. M280 p0 or p1 p2 etc.
                        • Macgyverundefined
                          Macgyver @Phaedrux
                          @phaedrux
                          that's awesome, thank you for the info,
                          I appreciate the time 2 you both.
                          • Macgyverundefined
                            Macgyver
                            still have a bit of an issue, when I am doing the dynamic testing I run the M401 and M402 and now the probe deploys and retracts as it should,
                            • (note; the blue light only comes on after I deploy the first time, will not come on at boot)
                            The Probe status in the dashboard shows zero "0"
                            when I run the M401 / M402 the BLtouch status does not change
                            However when I unplug one of the white/black wire the BLtouch status the status goes to "1000"
                            this tells me that the BLtouch is triggering however the input is not being seen by the Duet.
                            My M574 is defined with a type S2, and I have removed the M307 from the config.g as I am using firmware version 3X.
                            M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                            M557 X15:485 Y15:485 S23.5 ; define mesh grid
                            • Macgyverundefined
                              Macgyver
                              Looks like I may have it,
                              originally in my config.g I had the following
                              I read in a note about version 3 firmware that the S2 switch is intended for non-Z axis only.
                              Updated the command to
                              M574 Z1 S1 ; configure Z-probe endstop for low end on Z
                              now when the probe is triggered the bed stops and pulls down as it should.
                              Still no blue light on boot up but all functionality tests appear to work. After the first deployment of the BLtouch the blue light comes on not an issue. is this something I should rectify?
                                That's not what the trigger status is watching for. Deployment is totally separate. It will only show triggered very briefly when the pin is deployed and gets pushed back up. It will only change the display for a split second and go back to un triggered. You may not even see it there.
                                M574 will have no effect on the probe settings. Just M558 and G31 apply to the probe.
                                That's all that matters.
                                • Macgyverundefined
                                  Macgyver
                                  ok, thanks again for your time, I appreciate it.
                                    dc42 administrators @Macgyver
                                    @macgyver is it working now?
                                    matej1006undefined 1 Reply Last reply Reply Quote 0
                                    • matej1006undefined
                                      matej1006 @dc42
                                      @dc42 Hello sorry for stealing this topic but i have same problem and on web shows 1000 for Z-PROBE
                                      when i unplug bl touch goes to zero?
                                        Phaedrux Moderator @matej1006
                                        @matej1006 said in Duet 2 with Duex 5, cannot get BLtouch to function:
                                        Please create a new thread.
                                        • Macgyverundefined
                                          Macgyver
                                          Hi Guys
                                          Sorry, I missed the update, Yes all is working now. thanks again for your help.
                                          Up to the last tests I was doing it was a coding issue, as it turns out somewhere along the line the BLtouch sensor went bad. I wrote a script to probe 10 times and report the divination. the number was never the same, or even close for that point. turned out the touch was bad.
                                          • Macgyverundefined Macgyver referenced this topic
