    PanelDue Firmware 3.3.0 released
    PanelDue
    • mfs12undefined
      mfs12
      Hey,
      finally we manged to build a new official release.
      Big thank you to all who helped testing, reporting bugs and bringing up new ideas! 🙂
      Release Notes 3.3.0
      This release requires RepRapFirmware 3.3 or later.
      Version 2 (after August 2016) and Version 3 PanelDue are supported.
      Features:
      • added Russian translation
      • added support for emerging backlight mp3302 chip
      • renamed 'Print' tab into 'Status'
      • added slicer time
      • added simulated time
      • removed layer time
      • faster and consistent display of printer status
      • display IP address of printer in Setup tab
      • adaption to changes of object model
      • allow assignment of fans, extruders and heaters to multipls beds, chambers or tools
      • added debugging interface to write debugging information as gcode comments to the reprap uart
      • increase request timeouts to constant 2s
      • added support for new printer state cancelling
      • deactivate screensaver when a new M291 message arrives; S0 and S1 leave the screensaver active, S2 and S3 leave screensaver deactivated until user action
      Bug fixes:
      • gracefully handle parsing errors in M409 K"<key>" requests
      • show warning instead of error when JSON parsing errors occur
      • fix displaying of percent sign
      • fix displaying of M291 dialogs
      • fix sending filename in M37
      • fix unresponsive screen when showing m291 message while screensaver is active
      • fix updating of simulated time left during print
      • fix displaying of standby temperature row
      • fix state reporting in JSON parser warning
      • fix polling interval handling of printer
      Downloads and flashing instructions:
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.3.0
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Visit me on github at https://github.com/mfs12/
      • oozeBotundefined
        oozeBot
        Thank you for this release. Overall, everything appears to be working well, but we just noticed an issue. The popup for setting temperatures is not modal - the buttons below it (control, status, console, setup) can still be clicked. I haven't checked if older firmware does this, but we've never experienced it before upgrading to 3.3.
        • mfs12undefined
          mfs12
          @oozeBot thanks for reporting.
          created an github issue for your reported problem. Any development will be reflected there.
          https://github.com/Duet3D/PanelDueFirmware/issues/180
          mfs12 created this issue in Duet3D/PanelDueFirmware
          closed Popup for setting temperatures is not modal #180
            dc42 administrators @oozeBot
            @oozebot AFAIR that is normal and deliberate behaviour since before version 1.24. You don't have to close a popup dialogue in order to change page. The popup dialogue will be cancelled automatically.
            oozeBotundefined 1 Reply Last reply Reply Quote 0
            • oozeBotundefined
              oozeBot @dc42
              My mistake.. I guess there isn’t a cancel button, so it shouldn’t be modal, but switching tabs when accidentally clicking elsewhere felt off. Surprised I hadn’t run across this before.
              Perhaps it can be considered for an enhancement. Thanks
              • resamundefined
                resam
                Is it just me, or is the Babystep button on the Setup page a few pixels to low in Y-axis?Screenshot 2021-08-14 at 22.29.24.png
                (thick straight red lines added via photo edit app on top of a smartphone photo)
                PanelDue v2 5.0
                All the other buttons seems to be nicely aligned in rows and columns, but this one is off... Happy hunting! 😎
                • mfs12undefined
                  mfs12
                  Hey @resam, thanks for reporting. I created an github issue which will reflect any further development on this topic.
                  https://github.com/Duet3D/PanelDueFirmware/issues/181
                  closed Correct alignement of baby step button on setup #181
                  • mfs12undefined mfs12 unpinned this topic
                  • mfs12undefined mfs12 pinned this topic
                  • mfs12undefined mfs12 locked this topic
