    Tool Length Switch
    610
    • bubblevisorundefined
      bubblevisor
      I have added a tool length switch to my core xy much like voron 2.4 machines. I did this as I have never managed to get reliable and accurate first layers with induction probes alone (I print multi materials with heated chamber). Even with pinda v2 with temp compensation.
      My question: I understood that with the tool length sensor I can eliminate the thermal drift problem I've been plagued with as the TLS is mechanical and fixed to the bed. In other words I thought that I could combine the induction probe bed mesh with the superior TLS based Z offset. Is this possible? Is this just a Klipper/Voron feature?
      Alex.crundefined 1 Reply Last reply Reply Quote 0
      • Alex.crundefined
        Alex.cr @bubblevisor
        @bubblevisor
        It is possible to do this and there are several different ways as well. For instance on my Voron 2.4 running RRF I use the tool height sensor as my Z end stop and my inductive probe is defined as the probe. You can also use multiple probes with the newer firmware. I believe 3.2.2 and newer you can use the "K" parameter in G31 and M558 commands to set up multiple probes.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        bubblevisorundefined 1 Reply Last reply Reply Quote 0
          bubblevisor @Alex.cr
          @alex-cr Hmm... I do currently use the tool length sensor as endstop but perhaps I have implemented it wrong? Still seem to get variable first layers when operating at different temps eg abs to pla. I am suspecting firmware is still regarding the G28 Z probe home at the start of my bed.g. even though I do a G1 H1 Z home via switch afterwards. Here's my code...
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jul 20 2021 13:11:51 GMT+0100 (British Summer Time)
          ;M561 ; clear any bed transform
          ;G28 ; home all axes
          ;3 Pass auto X levelling
          G28 XY ; home XY
          G28 Z ;centre bed probe home Z
          ;First pass
          M558 H9
          G30 P0 X80 Y150 Z-99999 ; probe near left leadscrew
          G30 P1 X220 Y150 Z-99999 S2 ; probe near right leadscrew and calibrate 2 motors
          ;Second Pass
          M558 H10
          G30 P0 X10 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X290 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          ;Third Pass
          M558 H2
          G30 P0 X290 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X10 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          G29 ; mesh probe the bed and enable compensation
          M98 P"homez-switch.g" ;home z via switch again
          Here's my homez-switch.g.....
          ; homez-switch.g
          ; called to home the Z axis according to bed switch (only run after bed.g)
          G91 ; relative positioning
          G1 H2 Z10 F6000 ; lift Z relative to current position
          G90 ; absolute positioning
          G1 X285.2 Y296.4 ; move to switch position
          G1 H1 Z-450 F300 ; move Z until the endstop is triggered
          G92 Z1.05 ; set Z position to axis minimum (higher number closer to bed)
          G1 Z5 F2000
          G1 X150 Y150 F20000
            @bubblevisor said in Tool Length Switch:
            You should be using the probe to set the Z position before the print unless you have the exact height set perfectly via the switch.
            bubblevisorundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              bubblevisor @Phaedrux
              @phaedrux said in Tool Length Switch:
              I'm a little confused. I am trying to achieve a setup that ignores the induction probe z offset entirely and relies only on the tool length switch. Indeed the voron guys don't even bother accurately setting the induction probe trigger height in the config as they don't use it. The probe is just used to create the contour (delta z) map and the switch to set the global height. My goal is to avoid the heat drift problem with probes.
                Phaedrux Moderator @Phaedrux
                • Alex.crundefined
                  Alex.cr
                  @bubblevisor
                  So there is very little you can do to comp for different temperatures without having different code in some regard. For instance you could use variables to pick different offsets(or in your case, G92 values) based upon current temp.
                  Or you can have a temperature compensated probe in some way. These exist but can be pricey.
                  Are you actually using your other probe to build a mesh compensation? Is this probe height set perfectly?
                    @alex-cr Yes my tool length switch has an offset that perfectly sets the nozzle height hence the reason why I want the firmware to ignore any PINDA probe readings for Z offset.
                    I have now changed the way I home Z using only the tool switch. I am also defining the two sensors via M558 K command. Seems to be working....
                    M550 P"Saphire" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P4 S1 ; physical drive 4 goes forwards
                    M569 P2 S0 ; physical drive 2 goes forwards
                    M569 P3 S0 ; physical drive 3 goes forwards
                    M569 P1 S0
                    M584 X0 Y4 Z1:2 E3 ; set drive mapping
                    M350 X128 Y128 Z128 E16 I0 ; configure microstepping without interpolation
                    M92 X640.00 Y640.00 Z3200.00:3200.00 E679.00 ; set steps per mm
                    M566 X1500.00 Y1500.00 Z1200.00:1200 E520.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X20000.00 Y20000.00 Z800.00:800.00 E70000.00 ; set maximum speeds (mm/min)
                    M201 X7000.00 Y7000.00 Z100.00:100.00 E4000.00 ; set accelerations (mm/s^2)
                    M906 X1100 Y1100 Z1100 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X300 Y298 Z340 S0 ; set axis maxima
                    ;M556 S100 X0 Y0 Z0:0:0 ; set skew x.xxmm on 100mm square x-y obtuse
                    M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin !xstop
                    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                    M574 Z0 P"nil" ; No Z endstop
                    ; Z-Probe PINDA
                    M558 K0 P8 C"^zprobe.in" I1 H2 F1000 T6000 A20 S0.005 ; set Z probe type to effector and the dive height + speeds, max number of probes per point, tolerance(MM)
                    M308 S2 P"e1temp" A"PINDA" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
                    G31 K0 P1000 X0 Y-30 Z0.28 H2 S27 T0.020 ; set Z probe trigger value, xy offset, z trigger height(higher=closer to bed)don't care, temp sensor number, reference temp, compensation coefficient mm/degree(higher more close when hot)
                    ;Bed Levelling
                    M671 X-21:170 Y314:170 S25 ;leadscrew locations and max allowable deviation
                    M557 X10:300 Y1:290 S56 ; define mesh grid
                    ; Z Tool Length probe
                    M558 K1 P8 C"^zstop" T8000 F600 H2 A10 S0.005 R0.2 ;set second (K1) Z probe: pin in, travel speed to probe, probing speed, dive height, max number of probes, tolerance(MM), rest time
                    G31 K1 P500 X0 Y0 Z1.6 ;set second (K1) Z probe: trigger value (higher value = closer nozzle)
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                    M307 H0 B0 R1.028 C177.2 D6.82 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                    M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                    M307 H1 B0 R3.001 C201.0 D8.90 S1.00 V24.2 ; disable bang-bang mode for heater and set PWM limit
                    M308 S3 A"Chamber" P"exp.thermistor3" Y"thermistor" T100000 B3950 ; configure sensor 3 as "thermistor" type on pin "thermistor3" (Henry added for chamber monitoring)
                    M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency (Henry add chamber fan)
                    M106 P2 S0 H-1 C"Chamber fan" ; set fan 0 value. Thermostatic control is turned off
                    ;LED Lights
                    M950 P0 C"e1heat"
                    M42 P0 C"LEDs"
                    M563 P0 S"Dragon" D0 H1 F0:1 ; define tool 0
                    M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                    T0 ; select first tool
                      Phaedrux Moderator @bubblevisor
                      Well the heightmap is created with the probe, so it's a list of values showing the relative difference in height compared to the z0 point established by that probe. As long as your probe Z0 point and the switch Z0 point agree, you don't have an issue. Does that make sense?
                      If it's working, that's the important thing. Can you also share your homing files?
