Fans in Firmware 3.xx
I've gotten to the point of creating the fans, extruder, and heaters. I am reading that the method has changed a lot, and I have some doubts:
A- The fans are "created" with the gcode M950, in my case (M950 F0 C "! Fan0")
B- The fan is configured with the gcode M106, in my case (M106 P0 S0 I0 F500 H-1)Doubts:
- In the M950, the (!), Implies that the signal is inverted, so if when I turn on the Duet board, the fan starts spinning, I have to remove the fan, leaving (M950 F0 C "fan0")
- If in M950 I say that it is inverted, with the (!) and in M106 I put the modifier (I1), it is the same as NOT putting admiration (!) and putting I0 (or nothing) in M106 ...
- The fan that in M950 is F0, in M106 it is P0. Do not?
- If you wanted to configure the F0, as controlled by temperature, you would have to change the M106 to (M106 P0 T50)
@peirof i'm not sure what you're asking.
But I can tell you the use of I in M106 isn't valid in RRF3
Innn Invert PWM (I1), disable fan (I-1), or normal mode (I0, default) (not supported in RRF3, use M950)
If M106 its not valid RRF3.... How create and setup fans in RRF3?
@peirof here's what I have for my 2 fans on my ender 3
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
@jay_s_uk thx
