Solved Single wall tower test FAILED: vertical sin wave pattern
@carl
Sorry, I don't get it. What was the reason for the curved print and how did you cure it?
It sounds, like you had wrong delta geometry in config-override and coincidently found out that you had to delete and rebuild it to cure the printer?
Or was it a bug in rrf3.2.2? -
@o_lampe
I'm curious too. The first config.g had the same setting that produce the malfunction that make the printer unusable (the M579 set to zero). Was Carl using a different config.g at first? The problem of the print should be the heat , but we miss the (good) print that confirm the fact. -
Did we actually solve the wall print quality problem as well? I thought we just solved the homing issue that came up suddenly.
