    InputShaping-Plugin-0.1.0-rc4 released
    Plugins for DWC and DSF
    396
    • mfs12undefined
      mfs12
      Release Notes inputshaping-plugin-0.1.0-rc4
      Features
      • setting parameters for recording accelerometer profile
      • start recording accelerometer profile
      • automated download and analysis of the recorder profile
      • preset of ringing frequency with the maximum amplitude
      • setting of input shaping parameters
      • added german translation
      • improved setting of initial record profile parameters
      • changed order of profile commands
      Bugs
      • fixed list of available input shaping algorithm
      Downloads
      Downloads can be found at https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.1.0-rc4
      Visit me on github at https://github.com/mfs12/
      • oliofundefined
        oliof
        installing RC4 on top of RC3, it seems the i18n info is missing:
        • mfs12undefined
          mfs12
          Hey @oliof, thanks for pointing this out. I repacked the plugin. Now translation are fine.
          If you downloaded the zip before this post, please re-download it again. Thanks.
          SIamundefined 1 Reply Last reply Reply Quote 1
          • SIamundefined
            SIam @mfs12
            @mfs12 The translation is working with the latest build. With the 1hz spike, it is the same as in the first release, I can't see a difference. BTW it seems that it make no sense to use frequencies under 7 Hz because this will throw an error: Error: M593: parameter 'F' too low.
            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
            Duet WiFi 1.02 or later + DueX5
            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
            Duet WiFi Server: 1.26
            Duet Web Control 3.4.0beta4 (2021-09-27)
            dc42undefined 1 Reply Last reply Reply Quote 1
            • mfs12undefined
              mfs12
              @SIam thanks. I didn't want to hide any data for now so we get a full picture.
                dc42 administrators @SIam
                @siam please can you post a screenshot of the raw data, also the command string that it generated.
                SIamundefined 1 Reply Last reply Reply Quote 0
                • SIamundefined
                  SIam @dc42
                  @dc42 here we go 😉
                  The command:
                  Movement command: M204 P10000 T10000 G1 X9 F30000 G4 S2 M400 M956 P0 S1000 A2 F"input-shaping-0-X-none.csv" G1 X259
                  The raw data:
                  and the analyzed data:
                  and the CSV:
                    @siam the command isn't right. I'll liaise with @mfs12.
                    • SIamundefined
                      SIam @dc42
                      @dc42 okay, thank you!
                      • mfs12undefined
                        mfs12
                        Thanks for testing and reporting. New release candidate is available.
                        https://forum.duet3d.com/topic/24698/inputshaping-plugin-0-1-0-rc5-released
