    Red background in web controller
    3.3k
    • Nylkosundefined
      Nylkos
      What could cause the red background in web controller?
      My Z probe is a BLTouch and it has always been red, never been able to have a 0 there either…
      Any suggestion?
        It changes to red when the value in the box is above the trigger threshold set in the G31 command.
        If it never reads 0 then you have the Z probe incorrectly wired, or incorrectly configured with M558.
        • Nylkosundefined
          Nylkos
          I unplugged everything, check the resistance in each wire and reinstalled…
          I am using Duet 0.8.5
          Black wire to the GND pin in the Z Probe section
          White wire to the AD12 pin in the Z Probe section
          Orange wire to the pin 21 in the expansion section
          Red wire to the pin 1 in the expansion section
          Brown wire to the pin 2 in the expansion section
          Here are my config.g modifications...
          M307 H3 A-1 C-1 D-1
          M558 P5 X0 Y0 Z1 H5 F100 T2000
          G31 X3 Y-1.8 Z2 P25 ; Set Z probe trigger value, offset and trigger height
          M557 X15:285 Y15:285 S20 ; Define mesh grid
          I did notice one thing… while I had nothing wired up and no modification in my config.g, I had some 433 in the Z-Probe sensor and it wasn't red... could my board be damaged or defective?
          • number40fanundefined
            number40fan
            With my IR Probe disconnected, I still have a reading of 236 (P500 trigger), so I doubt your board is bad.
            • Nylkosundefined
              Nylkos
              Thanks you, I will contact BLTouch
              • Nylkosundefined
                Nylkos
                I rechecked the wire and the Config.g / Bed.g / Homez.g /…
                Still Red Background...
                The only way that I found not to have the red background was to add I1 to the
                But then I never get anything in Z-probe sensor, even when triggered.
                Do we have to declare the BLTouch as active low or high?
                do we need anything that isn't in https://duet3d.com/wiki/Connecting_a_Z_probe?
                Thanks you for your help.
                • fcwiltundefined
                  fcwilt
                  I had a BL unit and after one bed strike (not that hard) it ceased to work correctly.
                  • funkfingerundefined
                    funkfinger
                    I am going through the same problem. New build with a Duet Wifi and BLTouch - the BLTouch was working with ramps 1.4. When I get a chance (and can't get anywhere with the Duet), I will plug it back into the ramps and see if it's the device or the settings. Any updates on your situation are much appreciated.
                    • T3P3Tonyundefined
                      T3P3Tony administrators
                      I don't have a Bl touch however there is a long thread here with loads of people's experiences:
                      https://www.duet3d.com/forum/thread.php?id=459#p13924
                      www.duet3d.com
                        number40fan
                        One thing to remember is that with the newest firmware revisions, deployprobe and retract probe folders are not needed any more.
                        • fulgundefined
                          fulg
                          Try to debug this one step at a time. Is the BLTouch getting 5V, can you manually deploy/retract, did you use the resistor for 3.3V logic (as per the BLTouch documentation)? If you forgot the resistor then the BLTouch sent 5V into a 3.3V input and possibly damaged it. This could be why you are seeing a triggered probe all the time.
                          On my setup I did not have to invert the input for my BLTouch (no I1 on M558).
                          BTW emailing me directly was not ok, I did not sell the Duet nor the BLTouch to you. I am happy to help here but if you want private support I will send you an invoice for my time.
                          Cheers,
                          Ben.
                          VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                          • Nylkosundefined
                            Nylkos
                            Yes
                            No, I cut the wire for the 3.3V logic.
                            I apologize if my message was unwanted… you just seemed active, knowledgeable, you posted your files... Worst case scenario I expected to be treated like spam. Do not worry, I won't contact you again.
                            But thanks you for the answer.
                              @number40fan:
                              The change in the 1.19 firmware is that those files are invoked automatically if you do a G29 or G30 command and the probe is not already deployed. The files are needed if you use a probe that needs to be deployed, such as the Bltouch, and need to be set up correctly for whatever type of probe it is.
                                @Nylkos:
                                M307 H3 A-1 C-1 D-1
                                Check the connection from the Bltouch to the input pin on the Z probe connector (white wire).
                                With probe type 5 selected (P5 in the M558 command), with nothing connected to the input pin you should get a reading of 1000. If you connect that pin to ground, you should get a reading of zero. But with probe type 1 selected, when nothing is connected to the input pin you might see anything between 0 and 1000 because the pin is floating.
                                • Nylkosundefined
                                  Nylkos
                                  @dc42:
                                  I will do the test.
                                  I will also try with a 240 Ohms transistor… it's really hard to see if the connection was properly cut for the 3.3V logic, Worst case scenario with the 240 Ohms, I assume that I would see a red blinking light...
                                  @fulg:
                                  Do you have a store?
                                  • Nylkosundefined
                                    Nylkos
                                    @dc42:
                                    I must admit that I am a little embarrassed, but when you are asking to check the connection, I assume that you are asking me to measure the Amps. To measure the amps, I require to add in my multi-meter into a closed circuit. So how could I read the amps of the white wire while it's unplugged?
                                    While being unsure of what you meant here is what I did…
                                    Resistance Black to white wire 1000 Ohms
                                    Amps on the black wire while the white is not connected will be of 10-20ma when triggered
                                    Volt on the red wire (pins 1) 4.89V
                                    Amps on the red wire (pin 1) varies 2.2-3.5
                                    I noticed something weird... IF I unplug the BLTouch completely, I still get the 1000 in the Z-Probe sensor... with the red background...
                                    I tried adding the 240 transistor and got a red blinking light.
                                      number40fan
                                      @dc42:
                                      @number40fan:
                                      Ah, sorry about that. I thought they needed to be deleted no matter what. I'll keep that in mind in the future when trying to help out when/if I can.
                                        No problem, I have seen that your replies have been very helpful to a number of Duet users. Please keep it up!
                                        • Nylkosundefined
                                          Nylkos
                                          I had the time to run some additional testing:
                                          Voltage for the white wire, when pin is down 3,2V, pin up 0,10V
                                          For the Amps on the white I assume that the pulse is coming too fast I can't seem to catch it on the multi-meter
                                          From that and the 240 homs resistor causing the blinking red led, I assume that the wire for the 3.3v logic was properly cut.
                                          The Z-Probe sensor in the web controller, it's source, I assume would be the In pin from the Z-Probe (duet Wifi or Ethernet) or the AD12 (duet 0.8.5 & 0.6).
                                          How come is the Z-Probe background remain with 1000 value when my BLTouch is unplugged…
                                          I was able to remove the red background by changing the P value in the G31
                                          The background turned yellowish around P1000 and back to white around P1500
                                          However I can't seem to get the value to 0 with any of the M280 commands.
                                            When the output voltage is 0.10V, you should get a reading of around 30 if the connections are good and the configuration is correct.
