    3.4.0beta2 - delta printer prints crooked in y-direction
    Beta Firmware
    559
    • CaiJonasundefined
      CaiJonas
      Hello together,
      when I use 3.4.0beta2 my delta printer prints crooked in y-direction along the z-progress.
      I do not have this problem with 3.3 stable.
      Any suggestion for this problem?
      here is my config:
      c4d1f6bb-1c8a-49f5-b2a5-d04a6a8038fa-config.g
      Best Regards,
      Cai
      CaiJonasundefined 1 Reply Last reply Reply Quote 0
      • CaiJonasundefined
        CaiJonas @CaiJonas
        Have this problem also with Software bundle 3.4.0 beta 3.
        Any Ideas?
          @caijonas please run a few layers of that print and then send M122. Look for "step errors" under the heading Main DDA Ring. If the figure is nonzero, then please connect a laptop running YAT or another terminal emulator to the Duet via USB, and send:
          M111 S1 P4
          This will enable Move debugging. Then continue the print and watch out for debug info on the laptop. anticipate that you will see one or more blocks of debug data per layer. When you have collected a few, please post them here along with your config.g file and the GCode file you are printing.
            jay_s_uk @dc42
            @dc42 I also get this issue on 3.4b2 on the STM32 port.
            Unfortunately nothing shows up in an M122
            RepRapFirmware for STM32F4 based Boards (fly_e3_pro) version 3.4.0beta2_2 (2021-08-10 16:09:22) running on STM32F4
            Used output buffers: 3 of 40 (13 max)
            Static ram: 21252
            Dynamic ram: 77444 of which 28 recycled
            Never used RAM 31320, free system stack 214 words
            Tasks: NETWORK(ready,26.2%,225) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.0%,341) Move(notifyWait,1.7%,292) FSWRITE(notifyWait,0.0%,566) MAIN(running,71.9%,138) IDLE(ready,0.2%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 02:13:36 ago, cause: [software]
            Last software reset details not available
            Error status: 0x00
            Step timer max interval 0
            MCU temperature: min 29.2, current 37.9, max 47.8
            Supply voltage: min 18.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/86/86, gc cycles 0
            Driver 0: position 122979, 2209 standstill, reads 37139, writes 15, error r/w 0/1, ifcnt 38, timeout 0, SG min/max 0/416
            Driver 1: position 122979, 2209 standstill, reads 37139, writes 15, error r/w 0/1, ifcnt 38, timeout 0, SG min/max 0/428
            Driver 2: position 122979, 2209 standstill, reads 37139, writes 15, error r/w 0/1, ifcnt 38, timeout 0, SG min/max 0/434
            Driver 3: position 0, 2209 standstill, reads 37141, writes 13, error r/w 0/1, ifcnt 34, timeout 0, SG min/max 0/48
            Driver 4: position 0, 2209 standstill, reads 37144, writes 9, error r/w 0/1, ifcnt 19, timeout 0, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Date/time: 2021-08-25 18:41:44
            Slowest loop: 21.88ms; fastest: 0.06ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected
            SD card longest read time 2.7ms, write time 0.0ms, max retries 0
            DMs created 83, segments created 21, maxWait 433006ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 94096, completed moves 94096, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Bed heaters = 0, chamberHeaters = -1
            Heater 0 is on, I-accum = 0.3
            Heater 1 is on, I-accum = 0.9
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty
            === Network ===
            Slowest loop: 29.17ms; fastest: 0.00ms
            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0)
            HTTP sessions: 1 of 8
            Uploads/Errors: 0/0
            - WiFi -
            Network state is active
            Bad header: 0/0
            WiFi firmware version 1.26-05S-D
            WiFi MAC address 70:3a:cb:2a:71:1b
            WiFi Vcc 3.42, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 31888
            WiFi IP address 192.168.1.28
            WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00004002
            Socket states: 0 4 0 0 0 0 0 0
            The issue doesn't occur on 3.3.0
              dc42 administrators @jay_s_uk
              @jay_s_uk @CaiJonas please can you both post/make available your config.g file (and any macros that it calls) and the GCode file the exhibits the problem.
                jay_s_uk @dc42
                ; Configuration file for Fly-E3-Pro (firmware version 3)
                ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC+17 on Wed Jun 30 2021 09:24:28 GMT+0100 (British Summer Time)
                G90                                            ; send absolute coordinates...
                M83                                            ; ...but relative extruder moves
                M550 P"Predator"                             ; set printer name
                M665 R227 L450 B185 H400                       ; Set delta radius, diagonal rod length, printable radius and homed height
                M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
                M552 S1                                        ; enable network
                M586 P0 S1                                     ; enable HTTP
                M586 P1 S0                                     ; disable FTP
                M586 P2 S0                                     ; disable Telnet
                M569 P0 S1 D3 V40                                   ; physical drive 0 goes forwards using TMC2209 driver timings
                M569 P1 S1 D3 V40                                     ; physical drive 1 goes forwards using TMC2209 driver timings
                M569 P2 S1 D3 V40                                     ; physical drive 2 goes forwards using TMC2209 driver timings
                M569 P3 S1                                     ; physical drive 3 goes forwards using TMC2209 driver timings
                M584 X0 Y1 Z2 E3                               ; set drive mapping
                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                M92 X160.00 Y160.00 Z160.00 E415.00               ; set steps per mm
                M566 X1500.00 Y1500.00 Z1500.00 E1000.00       ; set maximum instantaneous speed changes (mm/min) next try 3000
                M203 X18000.00 Y18000.00 Z18000.00 E10000.00    ; set maximum speeds (mm/min)
                M201 X1100.00 Y1100.00 Z1100.00 E3000.00       ; set accelerations (mm/s^2) next try 6000
                M906 X1344 Y1344 Z1344 E560 I30                ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                        ; Set idle timeout
                M208 Z0 S1                                     ; set minimum Z
                M574 X2 S1 P"e1stop"                           ; configure active-high endstop for high end on X via pin e1stop
                M574 Y2 S1 P"pson"                             ; configure active-high endstop for high end on Y via pin pson
                M574 Z2 S1 P"e0stop"                           ; configure active-high endstop for high end on Z via pin e0stop
                M558 P8 C"probe" H5 R0.4 F1200 T6000 A9                ; set Z probe type to switch and the dive height + speeds
                G31 P100 X0 Y0 Z-0.25                            ; set Z probe trigger value, offset and trigger height
                M557 R180 S20                                  ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"e1heat" T0                           ; create bed heater output on e1heat and map it to sensor 0
                M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                        ; map heated bed to heater 0
                M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                M308 S2 P"boardtemp" Y"thermistor" T100000 B4092
                M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                M563 P0 D0 H1 F0                               ; define tool 0
                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                M207 S5.0 F2400 Z0.5
                M572 D0 S0.4
                M955 P0 C"B.1+E.8" I50
                M501
                T0                                             ; select first tool
                AP_Voron_Design_Cube_v7.gcode
                The left is 3.4b2 and the right is 3.3.0
                dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  @jay_s_uk I printed your file on my Duet WiFi powered delta, and it came out straight.
                  @CaiJonas which Duet are you running 3.4beta3 on? Please share the GCode file.
                  • gloomyandyundefined
                    gloomyandy @dc42
                    @dc42 Was that using beta2 or beta3?
                      dc42 administrators @gloomyandy
                      @gloomyandy said in 3.4.0beta2 - delta printer prints crooked in y-direction:
                      Beta3.
                        gloomyandy @dc42
                        @dc42 Thanks, I should have a build for jay to try of beta3 shortly, just testing it at the moment.
                        • T3P3Tonyundefined
                          T3P3Tony administrators @jay_s_uk
                          @jay_s_uk are you still having this issue with the 3.4b3 build the @gloomyandy did for you?
                          @CaiJonas which Duet are you using and can you share the gcode that causes the issue. please
                          I have tested this using 3.4b3 and do not get a leaning issue.
                          www.duet3d.com
                            jay_s_uk @T3P3Tony
                            @t3p3tony yes, I am.
                            The left one is 3.4b3 and the right one is 3.3.0
                            Only change is the firmware version
                            • T3P3Tonyundefined
                              @jay_s_uk can you post your config please. Also if possible try a simple hollow cube to see if that also displays the issue please.
                              www.duet3d.com
