Reset from reset botton
My printer keeps resetting and i am trying to narrow the issuse down.
My M122 says reset button has caurse it. This happens in both standalone and SBC,Yesterday i did update to b3 firmware but have since dropped back to 3.3 stable. Before i updated the printer was fine. and i did not try to print last night , It was late and bed time !
It resets as soon as i start printing . So i have tried a old Gcode which printed fine before but same again.
Anyone got anyideas.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: 9Y0D5-4396U-D65J0-40KM2-LF03Z-ZRMYB Used output buffers: 3 of 40 (20 max) === RTOS === Static ram: 102724 Dynamic ram: 106152 of which 36 recycled Never used RAM 34792, free system stack 198 words Tasks: NETWORK(ready,11.6%,226) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,1.1%,115) MAIN(running,84.8%,412) IDLE(ready,1.6%,29) AIN(delaying,0.8%,273), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:14 ago, cause: reset button Last software reset at 2021-08-25 19:52, reason: User, GCodes spinning, available RAM 34792, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 14341, completed 14340, timed out 0, errs 0 Step timer max interval 751 MCU temperature: min 40.1, current 41.2, max 41.2 Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 1273, writes 9, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 22, reads 1272, writes 9, timeouts 0, DMA errors 0 Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 21, reads 1272, writes 9, timeouts 0, DMA errors 0 Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 1272, writes 9, timeouts 0, DMA errors 0 Date/time: 2021-08-25 20:22:37 Cache data hit count 27239000 Slowest loop: 5.09ms; fastest: 0.12ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 0.5ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 128, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 72/0/0 Tx timeouts 0,0,71,0,0,55 last cancelled message type 30 dest 127 === Network === Slowest loop: 15.87ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address f4:cf:a2:70:32:3b WiFi Vcc 3.40, reset reason Power up WiFi flash size 2097152, free heap 25624 WiFi IP address 10.174.1.101 WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
How is your reset button connected? Perhaps you are responding to the wrong button state.
@fcwilt I have not wired a reset in .
Have you tried pressing/inspecting the button yourself? Is it stuck in or something?
@phaedrux It looks fine . when i press it it clicks as it should. and pops out again as it should.
I dont think its the button itself.. -
@lodger said in Reset from reset botton:
I dont think its the button itself..So you have a button but it is not connected?
@fcwilt Sorry i was thinking about the small button on the board itself. i have not wired or connected anything external
So after a bit of hair pulling . I thought to myself ....It only resets when it starts to extrude.
So i powered the printer off and unpluged the exturders cable.And she started happy printing in mid air. I quick dug out a spare stepper cable poorly tie rap it place and plug her in..Yes she is printer happy as can be.
So i did not know a crappy stepper cable can reset the duet.
Was the stepper cable shorting out to anything else?
@phaedrux No not really . I think it was just a lose joint / bad crimp. I did not get any driver errors nothing .
