    Solved [3.3] 6HC+3HC+SBC Stuttering Motion on Small Contiguous Segments
    250
    • poofjunior
      poofjunior last edited by poofjunior
      Hey folks, I've got an issue that looks eerily similar to this one. In a nutshell, a series of small contiguous line segments (like the hull of a Benchy) cause the printer head's XY motion to "stutter" as it travels through those moves. For slow speeds, this manifests as blobs. For faster speeds, this looks like smaller blobs but can also look like weird discolorations (testing on a somewhat translucent filament).
      I've tried:
      • running prints with XY Jerk cranked up to 3000 mm/sec
      • running prints with the firmware on 3.3 on both the 6HC and 3HC expansion
      but the problem persists, and I can visually observe the print head stuttering (and hear motion slow down too) during these sorts of moves.
      My setup is:
      • 1x Duet 6HC Mainboard + 1x Raspberry Pi 4 (SBC Mode) connecting to XYZZZU motor outputs on a Jubilee
      • 1x 3HC Expansion board connected to an Orbiter Extruder and copper E3D V6 Hotend
      Diagnostic outputs for firmware versions are:
      M122 B0
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J1FG-3SJ6L-KB6UG
      Used output buffers: 1 of 40 (15 max)
      Static ram: 150904
      Dynamic ram: 61808 of which 456 recycled
      Never used RAM 141024, free system stack 202 words
      Tasks: SBC(ready,5.0%,328) HEAT(delaying,0.0%,331) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.2%,93) MAIN(running,87.8%,922) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:01:40 ago, cause: power up
      Last software reset at 2021-08-23 12:37, reason: User, none spinning, available RAM 138136, slot 0
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 155
      MCU temperature: min 36.2, current 36.5, max 36.5
      Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 17703, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 0, standstill, reads 17701, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 0, standstill, reads 17701, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, standstill, reads 17701, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, standstill, reads 17702, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, standstill, reads 17702, writes 0 timeouts 0, SG min/max not available
      Date/time: 2021-08-30 19:18:23
      Slowest loop: 0.29ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP* is doing "M122 B0" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 27, received 39, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 4, free buffers 49 (min 49), ts 15/15/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 2755/2755
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c810
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 36.08, max wait times: 18.2ms/0.0ms
      Codes per second: 0.31
      Maximum length of RX/TX data transfers: 3592/868
      on the mainboard and
      M122 B1
      Diagnostics for board 1:
      Duet EXP3HC firmware version 3.3 (2021-06-15 16:12:41)
      Bootloader ID: not available
      Never used RAM 158696, free system stack 4400 words
      Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,104) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.3%,63) MAIN(running,91.4%,338) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0%
      Last reset 00:01:41 ago, cause: software
      Last software reset data not available
      Driver 0: position 0, 420.0 steps/mm,  standstill, reads 63628, writes 15 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 1: position 0, 80.0 steps/mm,  standstill, reads 63633, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 2: position 0, 80.0 steps/mm,  standstill, reads 63633, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 0/13, peak Rx sync delay 178, resyncs 0/0, no step interrupt scheduled
      VIN: 24.3V, V12: 12.2V
      MCU temperature: min 30.2C, current 31.4C, max 31.7C
      Ticks since heat task active 141, ADC conversions started 101669, completed 101668, timed out 0, errs 0
      Last sensors broadcast 0x00000002 found 1 146 ticks ago, loop time 0
      CAN messages queued 947, send timeouts 0, received 832, lost 0, free buffers 37, min 37, error reg 110000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      on the 3HC expansion board.
      Finally, I should mention that this setup prints some good-looking small parts with simple geometry like XYZ calibration cubes.
      If anyone has any suggestions, I'm happy to give them a go. Cheers, and thanks!
        Can you post your config.g file?
        Have you tested with 3.4 Beta 3 yet? It's available on the unstable branch.
        https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#unstable-package-feed
        poofjunior 1 Reply Last reply Reply Quote 0
        • poofjunior
          poofjunior @Phaedrux last edited by
          @phaedrux can do! Here's my config.g file.
          I'll mention that I'm currently just printing PLA at ambient bed temp, and the bed heater is completely unplugged. A couple extra notes on hardware:
          • This is a toolchanger, so the U-axis is devoted to the tool locking mechanism
          • 3 Drives are devoted to Z axis motion
          • Only 1 tool (Orbiter + E3DV6 Copper Hotend) is currently provisioned (at the bottom of the config)
          ; Jubilee CoreXY ToolChanging Printer - Config File
          ; General setup
          M111 S0                    ; Debug off
          M929 P"eventlog.txt" S1    ; Start logging to file eventlog.txt
          ; General Preferences
          M555 P2                    ; Set Marlin-style output
          G21                        ; Set dimensions to millimetres
          G90                        ; Send absolute coordinates...
          M83                        ; ...but relative extruder moves
          ; Stepper mapping
          ; Connected to the MB6HC as the table below.
          ; Note: first row is numbered left to right and second row right to left
          ; _________________________________
          ; | U(Lock) | Y(Right) | X(Left)  |
          ; | Z(Back)  | Z(Right) | Z(Left) |
          M584 X0.2 Y0.1            ; X and Y for CoreXY
          M584 U0.0                 ; U for toolchanger lock
          M584 Z0.3:0.4:0.5         ; Z has three drivers for kinematic bed suspension.
          M569 P0.1 S0              ; X stepper reverse direction
          M569 P0.2 S0              ; Y Stepper reverse direction
          M906 X{0.9*sqrt(2)*2000}  ; LDO XY 2000mA RMS the TMC5160 driver on duet3
          M906 Y{0.9*sqrt(2)*2000}  ; generates a sinusoidal coil current so we can
                                    ; multply by sqrt(2) to get peak used for M906
                                    ; Do not exceed 90% without heatsinking the XY
                                    ; steppers.
          M569 P0.0 S0                ; U Toolchanger Lock reverse direction
          M906 U{0.7*sqrt(2)*670} I60 ; 70% of 670mA RMS idle 60%
                                      ; Note that the idle will be shared for all drivers
          M906 Z{0.7*sqrt(2)*1680}  ; 70% of 1680mA RMS
          ; Kinematics
          M669 K1                   ; CoreXY mode
          ; Kinematic bed ball locations.
          ; Locations are extracted from CAD model assuming lower left build plate corner
          ; is (0, 0) on a 305x305mm plate.
          M671 X297.5:2.5:150 Y313.5:313.5:-16.5 S10 ; Front Left: (297.5, 313.5)
                                                     ; Front Right: (2.5, 313.5)
                                                     ; Back: (150, -16.5)
                                                     ; Up to 10mm correction
          ; Axis and motor configuration
          M350 X1 Y1 Z1 U1       ; Disable microstepping to simplify calculations
          M92 X{1/(0.9*16/180)}  ; step angle * tooth count / 180
          M92 Y{1/(0.9*16/180)}  ; The 2mm tooth spacing cancel out with diam to radius
          M92 Z{360/0.9/4}       ; 0.9 deg stepper / lead (4mm) of screw
          M92 U{13.76/1.8}       ; gear ratio / step angle for tool lock geared motor.
          ; Enable microstepping all step per unit will be multiplied by the new step def
          M350 X16 Y16 I1        ; 16x microstepping for CoreXY axes. Use interpolation.
          M350 U4 I1             ; 4x for toolchanger lock. Use interpolation.
          M350 Z16 I1            ; 16x microstepping for Z axes. Use interpolation.
          ; Speed and acceleration
          M201 X2500 Y2500       ; Accelerations (mm/s^2)
          M201 Z100              ; LDO ZZZ Acceleration
          M201 U800              ; LDO U Accelerations (mm/s^2)
          M203 X18000 Y18000 Z1600 U9000    ; Maximum axis speeds (mm/min)
          M566 X500 Y500 Z500 U50           ; Maximum jerk speeds (mm/min)
          ; Endstops and probes
          ; | X | U |
          ; | Y | - |
          ; | Z | - |
          M574 X1 S1 P"0.io0.in"  ; homing position U1 = low-end, type S1 = switch
          M574 Y1 S1 P"0.io1.in"  ; homing position X1 = low-end, type S1 = switch
          M574 U1 S1 P"0.io3.in"  ; homing position Y1 = low-end, type S1 = switch
          M574 Z0               ; we will use the switch as a Z probe not endstop
          M558 P8 C"0.io2.in" H3 F360 T6000 ; H = dive height F probe speed T travel speed
          G31 K0 X0 Y0 Z-2    ; Set the limit switch position as the  "Control Point."
                              ; Note: the switch free (unclicked) position is 7.2mm,
                              ; but the operating position (clicked) is 6.4 +/- 0.2mm.
                              ; A 1mm offset (i.e: 7.2-6.2 = 1mm) would be the
                              ; Z to worst-case free position, but we add an extra 1mm
                              ; such that XY travel moves across the bed when z=0
                              ; do *not* scrape or shear the limit switch.
          ; Set axis software limits and min/max switch-triggering positions.
          ; Adjusted such that (0,0) lies at the lower left corner of a 300x300mm square
          ; in the 305mmx305mm build plate.
          M208 X-13.75:313.75 Y-44:341 Z0:295
          M208 U0:200            ; Set Elastic Lock (U axis) max rotation angle
          ; Machine Heaters and temperature sensors
          ; Bed
          M308 S0 P"0.temp0" Y"thermistor" T100000 B3950 A"Bed" ; Keenovo thermistor
          M950 H0 C"0.out0" T0                  ; H = Heater 0
                                              ; C is output for heater itself
                                              ; T = Temperature sensor
          M143 H0 S130                        ; Set maximum temperature for bed to 130C
          M307 H0 A589.8 C589.8 D2.2 V24.1 B0 ; Keenovo 750w 230v built in thermistor
                                              ; mandala rose bed
          M140 H0                             ; Assign H0 to the bed
          ; Tool definitions
          M92 E681            ; Orbiter 0 steps per mm
          M350 E16 I1         ; 16x microstepping for Orbiter 0 Axis. Use interpolation
          ; Tool steppers on expansion board 1 (adapt this to your own set up)
          M201 E3600                ; Orbiter 0 Max Speed (mm/min)
          M203 E600                 ; Orbiter 0 Max Accel (mm/s^2)
          M566 E300                 ; Orbiter 0 Max Jerk (mm/min)
          M584 E1.0                 ; Orbiter 0 on 3HC Board 1
          M569 P1.0 S0 D2           ; Orbiter 0 Reverse Direction and Spreadcycle Mode
          M906 E450                 ; 500mA peak
                                    ; E does not support expressions in 3.2.0-beta4
          ; Tool Thermistors and Heaters
          M308 S1 P"1.temp0" Y"thermistor" T100000  B4725 C7.060000e-8 A"t0_heater" ; Orbiter 0 thermistor
                                                    ; Sx = Sensor Number
          M950 H1 C"1.out0" T1                      ; Heater for extruder out tool 0
                                                    ; Hx = Heater number
                                                    ; Tx = temp sensor number for this heater
          ; M307 H1 A1252.3 C361.3 D5.3 V24.0 B0    ; from pid tuning without sock
          M307 H1 A811.4 C309.4 D4.7 V24.0 B0       ; With sock
          M143 H1 S300                              ; Maximum temp for hotend to 300C
          M950 F1 C"1.out3"                     ; Define Hotend Fan output
          M106 P1 S255 H1 T45 C"HeatBreakCool0" ; S = Speed of fan Px
                                                ; Hxx = heater for thermo mode
                                                ; T = temps for thermo mode.
          M950 F2 C"1.out6"                     ; Define Part Cooling Fan output
          M106 P2 C"t0_part_cooling_fan"
          M563 P0 S"Tool 0" D0 H1 F2  ; Px = Tool number
                                      ; Dx = Drive Number
                                      ; H1 = Heater Number
                                      ; Fx = Fan number part cooling fan
          G10  P0 S0 R0               ; Set tool 0 operating and standby temperatures
                                      ; (-273 = "off")
          M572 D0 S0.05               ; Set pressure advance
          G10  P0  X0 Y36.62 Z-3.3    ; Set Tool 0 XYZ Carriage Offsets
          M501                        ; Load saved parameters from non-volatile memory
          Ooh--I was wondering if there was a way to use the package manager to get the unstable packages. I'll give that a whirl now. Thanks for the pro-tip and the quick reply!
          • deckingman
            deckingman @poofjunior last edited by
            @poofjunior The usual cause of that kind of behaviour is extruder jerk set too low. there may be other reasons, but that;s the most common one. You have yours set to 300 mm/min (5mm/sec) which isn't desperately low but might be low enough to cause your issue. Remember that any print move will be a combination of XY and E (and maybe Z) and that each of those axes and the extruder have to be synchronised to begin and end at the same time. So at the end of every short segmented move, X and Y will continue to slow down until the extruder reaches it's instantaneous speed threshold (jerk) before it starts the next short segment and so the entire machine can end up running really slowly and appear to stutter. Suggest you try setting extruder jerk to 3000 or some other high values (I use 3600) and then moves will complete using the lowest of XY jerk values, rather than being constrained by the extruder setting. Setting it "silly high" will do no harm because unless it too low, extruder jerk pretty much only applies to extruder only moves which also involve a change of direction (of which there are no such moves).
              Sometimes our configs can get a little too convoluted and complex for our own good. Can you verify that the values are actually as you expect them by sending M92 M350 M201 M203 M566 M906 M913 by themselves to see what the firmware reports back as the current settings?
              I'd say Deckingman is also spot on about the low jerk values.
              • poofjunior
                @deckingman I tried bumping jerk up to 3000mm/min before posting since that's what I suspected also.
                @Phaedrux can do! (Yeah, this config confuses me too. I'm open to structural feedback there though!)
                M92
                Steps/mm: X: 200.000, Y: 200.000, Z: 1600.000, U: 30.578, E: 681.000
                M350
                Microstepping - X:16(on), Y:16(on), Z:16(on), U:4(on), E:16(on)
                M201
                Accelerations (mm/sec^2): X: 10000.0, Y: 10000.0, Z: 100.0, U: 800.0, E: 10000.0
                M203
                Max speeds (mm/min)): X: 18000.0, Y: 18000.0, Z: 1600.0, U: 9000.0, E: 8000.0, min. speed 0.60
                M566
                Maximum jerk rates (mm/min): X: 1000.0, Y: 1000.0, Z: 500.0, U: 50.0, E: 3000.0, jerk policy: 0
                M906
                Motor current (mA) - X:2546, Y:2546, Z:1663, U:670, E:450, idle factor 60%
                M913
                Motor current % of normal - X:100, Y:100, Z:100, U:100, E:100
                I'll mention that these get overwritten in the slicer, so this is what the Slicer is currently printing the part at. Superslicer is also lowering acceleration on outer perimeters to about 1500mm/sec^2 and then bumping it back up to 10000mm/sec^2 for everything else.
                Finally, I just updated to 3.4 Beta 3, and I'm partway through a benchy hull. I can say that, audibly, I can't hear the stuttering anymore. And visually, the hull just looks wayy better overall so far. I'll post again for the final verdict, but updating to the latest unstable release may very well have fixed it!
                • poofjunior
                  poofjunior @poofjunior last edited by
                  And it looks like switching to 3.4beta3 has totally fixed the stuttering! Thanks a bunch for the hand folks!
                  • deckingman
                    @poofjunior Glad it's fixed. On the structure of your config.g file, it's generally best to put each command on a single line or at least on separate lines but consecutively. The reason being that there are some dependencies and orders of sequences. For example the motor mapping must come before any commands which affect those motors. You seem to have got away with it but mapping the extruder motors way later in the file to the axes motors might come back to bite you in the future. I divide my config into sections such as "motors", "sensors", "heaters", "fans", "tools" etc and put all related commands in each section.
