    Max Bed Level Compensation
    Using Duet Controllers
    bl touch bed leveling compensation and calabration
    633
    • fcwiltundefined
      fcwilt @SignPostMan
      @signpostman said in Max Bed Level Compensation:
      What is the Max bed level compensation? is it adjustable? I am running a 2.5mm nozzle and do not require the precision level of a .4 mm nozzle. My bed is stationary and 2600x1300 so bed level perfection is a difficult.
      I don't understand the question.
      What do you mean by "bed level compensation"?
      Thanks.
      SignPostManundefined 1 Reply Last reply Reply Quote 0
      • SignPostManundefined
        SignPostMan @fcwilt
        @fcwilt When I run the Mesh Bed Leveling, what variation in height across my bed is allowable? When running the mesh bed leveling, Randomly in different locations, I get a Error: Z Probe was not triggered during probing move. This of course stops the probing.
        jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @SignPostMan
          @signpostman double the probing H value.
          So if your probe has a H value of 5mm, it'll continue a further 5 mm and if the bed isn't found at that point you'll get that error
          • fcwiltundefined
            fcwilt @SignPostMan
            So you are talking about Mesh Bed Compensation (G29) , not Auto/Manual Bed Leveling (G32)?
            As mention by @jay_s_uk increase the H parameter (Dive Height) in your M558 command.
              SignPostMan @fcwilt
              This post is deleted!
                SignPostMan @SignPostMan
                @signpostman Not G29 not G30
                • fcwiltundefined
                  fcwilt @SignPostMan
                  So G32?
                  The solution is the same if the probe is not triggering, increase the Dive Height.
                  But there is also the S parameter in M671 which determines that maximum correction that will be applied.
                  M671 Documentation
                  If you are interested here is a quick and dirty video I made of my triple Z printer doing some serious correction to level the bed.
                  Auto Bed Leveling
                    SignPostMan @fcwilt
                    @fcwilt How do I define the S parameter in M671? I would like to raise it to 2mm instead of 1mm
                    tecnoundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                    • tecnoundefined
                      tecno @SignPostMan
                      @signpostman
                      Edit bed.g
                      • engikeneerundefined
                        engikeneer @SignPostMan
                        @signpostman it literally is as simple as adding S2 to the end of your M671 line (replacing the S1 if you have it). You'll have probably put your M671 command in your config.g file, but might be in your bed.g file instead as @tecno suggests
                        i3 clone with a bunch of mods
