    Compressed / Aquarium Air pump tubing
    535
    • laelundefined
      lael
      So, just about to experiment with using an aquarium pump / berd air pump (will test both options) for a new install. I'm wondering if anyone has used larger diameter (6-8mm) silicone tube for the run to the print head and then split into two cooling jets?
      I'm thinking something like 8mm ID, and 10mm OD (IE 1mm wall) to keep the weight down, but wasn't sure if that would collapse too easily, or if the pressure from the pump would keep it from kinking. Then split to 6mm ID for each tusk. 8mm Area is ~50mm^2 and 2x6mm is ~28mm^2x2 / 56. So there might be a small pressure drop into the 6mm tube, before considering the split and the actual air jet outlet size that will add pressure.
      Or... is a 2mm wall thickness actually a much better idea?
      cosmowaveundefined deckingmanundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @lael
        @lael i think, if the hose collapse or not will more depend on the material as on the diameter!?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        laelundefined 1 Reply Last reply Reply Quote 0
        • deckingmanundefined
          deckingman @lael
          @lael Can you print at 300mm/sec? The reason I ask is because I can and the moving mass of my 6 input hot end is 2.5Kgs. I'm limited to 300mm/sec because that is the maximum melt rate of my hot end, not because of the mass. So use thicker wall tubing and don't get hung up about the mass.
          • laelundefined
            lael @cosmowave
            @cosmowave Right, so that's why I'm debating between 1mm wall thickness vs 2mm wall thickness.
            • laelundefined
              lael @deckingman
              @deckingman pretty impressive, but surely you are getting a whole lot of ringing if you are attempting to print those speeds with that mass?
              • o_lampeundefined
                o_lampe @lael
                @lael I have a lot of experience with aquarium air pumps and IMHO it's almost impossible to split the airstream equally without adding an adjuster valve.
                laelundefined 1 Reply Last reply Reply Quote 1
                  deckingman @lael
                  @lael said in Compressed / Aquarium Air pump tubing:
                  Nope - none at all. I have a theory that ringing is caused by resonance. If that is indeed the case, then increasing the mass will reduce the resonant frequency which is why I have never seen any sign on ringing, ghosting, or any other surface defects which seem to afflict a lot of people.
                  • laelundefined
                    lael @o_lampe
                    @o_lampe Thanks, that makes some sense. I'll get some valves ordered.
